Topic: servo problems (Read 567 times) previous topic - next topic
ponobill
Feb 05, 2013, 08:42 pm Last Edit: Feb 05, 2013, 09:05 pm by ponobill Reason: 1
I'm a noob, but I looked around the archives for an answer to this and couldn't find anything. I'm working on a little servo control problem and was making good progress when everything went a bit wrong. To test the input I added an LED, and when I did my servo went whacky. I backtracked a bunch and modified the demo program "sweep" to try to figure out what's going wrong.
Code: [Select]
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
               // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
#define LED 9     // the pin for the LED
#define BUTTON 11  // input pin of the pushbutton
int val = 0;      // stores the state of the input pin
int old_val = 0;  // stores the previous value of "val"
int state = 0;    // 0 = LED off while 1 = LED on
int brightness = 130;        // Stores the brightness value
unsigned long startTime = 0; // when did we begin pressing?
 myservo.attach(8);  // attaches the servo on pin 9 to the servo object
 pinMode(LED, OUTPUT);   // tell Arduino LED is an output
 pinMode(BUTTON, INPUT); // and BUTTON1 is an input
 for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
 {                                  // in steps of 1 degree
   myservo.write(pos);              // tell servo to go to position in variable 'pos'
   //analogWrite(LED, pos);   //*****************************************
   delay(15);                       // waits 15ms for the servo to reach the position
 for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
With the LED write statements commented out the servo operates smoothly.
Code: [Select]
// Sweep
#include <Servo.h>
 //myservo.attach(8);  // attaches the servo on pin 9 to the servo object   ************************************
   analogWrite(LED, pos);    // ****************************************
With the servo attachment commented out and the LED write uncommented, it cycles the LED up and down as you would expect
Code: [Select]
// Sweep
#include <Servo.h>
with both the LED write uncommented and the servo attached, the LED does not light and the servo moves jerkily. I thought it might be too much current draw, but I connected an external battery (four nicads) to the breadboard bus and no joy.
What gives. And how can I fix this.
AWOL
#1
Feb 05, 2013, 08:54 pm Last Edit: Feb 05, 2013, 09:03 pm by AWOL Reason: 1
Quote
On boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10,
From the Servo library reference page.
Please use code tags when posting code, or disable smileys
Code: [Select]
myservo.attach(8);  // attaches the servo on pin 9 to the servo object guess which of those statements the compiler believes.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
ponobill
Thanks, that go me on the right path. Lots to learn. this code worked as expected, time for a little more reading and another attempt at the real thing
Code: [Select]
// Sweep
#include <Servo.h>
#define LED 6     // the pin for the LED
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
Any idea why "copy code for forum" in the IDE doesn't seem to work?
AWOL
Quote
I don't know, but I never use it, and don't like it.
PeterH
Because that Arduino IDE feature is not suitable for the Arduino forum. As with many other aspects of the IDE, I wonder what they had in mind when they implemented that 'feature'. But hey, it was free.
