Topic: 1284P Bobuino conflicting declaration 'digital_pin_to_timer_PGM' (Read 1 time) previous topic - next topic
tack
I've spent the last 45 minutes hunting the forum and Google on this one. I can find some references to it but nothing clearly saying how to fix it.
I'm using IDE1.01 with the 1284P, optiboot 4.5 bootloader, and maniacbuig cores. I have some 1.0.1 core files for Arduino.h, wiring_analog.h and wiring_private.h, which was suggested as fixing this.
The error I am getting is this:
...\ATMega1284\variants\bobuino/pins_arduino.h:38: error: previous declaration of 'const uint8_t digital_pin_to_timer_PGM [32]' with 'C++' linkage
...\ATMega1284\cores\standard/Arduino.h:134: error: conflicts with new declaration with 'C' linkage
As a result of including SPI.h
Anyone got any ideas?
Many thanks
nickgammon
Locate SPI.cpp in your distribution. Comment out or remove the line "#include "pins_arduino.h" as below. Then it compiled for me.
* Copyright (c) 2010 by Cristian Maglie <c.maglie@bug.st>
* SPI Master library for arduino.
* This file is free software; you can redistribute it and/or modify
* it under the terms of either the GNU General Public License version 2
* or the GNU Lesser General Public License version 2.1, both as
* published by the Free Software Foundation.
//#include "pins_arduino.h"   <--- get rid of this
#include "SPI.h"
More info:
Federico_Vanzati
Hi tack,
Are you using include guards inside your pins_arduino.h file?
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
... //your pins configuration code
#endif
F
oric_dan
This was discussed in one of those humungously long threads about 1284 chips a couple of
months ago, but is probably just about impossible to track down. And 2 months ago, I posted
a comment to maniacbug's github page in regards fixing it, as well as other problems [see
especially the ADC callout error]. I also sent him emails, but he's unresponsive. You're on your
own when using that library.
https://github.com/maniacbug/mighty-1284p/issues/5
