Loading...
Pages: [1] 2   Go Down
Author Topic: Semaphores, Mutex and RTOS on Arduino (ChibiOS Help?)  (Read 1311 times)
Long Island, NY
Offline Offline
Newbie
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself.
View Profile
WWW
I am using the wonderful ChibiOS port developed by FatLib16 to attempt to make and arduino project I have multitask.
The original single task code is this:
Code:
#include <Servo.h>
#define EnableServo 13
#define BuzzerPin 4
#define ButtonPin 2
#define Red 3
#define Green 5
#define Blue 6
Servo Lleg;  // create servo object to control a servo
Servo Rleg;
Servo Lfoot;
Servo Rfoot;
Servo Neck;
int RFcenter = 80;    // variables to store the center servo positions
int LLcenter = 80;
int RLcenter = 80;
int LFcenter = 80;
int Neckcenter = 90;
// Setup variables to store sensor readings
int obstacleDistance = 0;
int obstacleLeft = 0;
int obstacleCenter = 0;
int obstacleRight = 0;
int presentDistance = 0;
// declare reaction distances on object preception
int obstacleAhead = 20;
int obstacleWarning = 10;
int obstacleAlert = 8;
// declare angle values for walking
int tAngle = 25; //tilt angle
int uAngle = 30; //turn angle
int sAngle = 30; //swing angle
const int pingPin = 12; // define sensor pin
  // initialize serial communication:
  Serial.begin(19200);
  Lleg.attach(7);  // attaches the servo on pin x to the servo object
  Rleg.attach(10);  // attaches the servo on pin x to the servo object
  Lfoot.attach(8);  // attaches the servo on pin x to the servo object
  Rfoot.attach(9);  // attaches the servo on pin x to the servo object
  Neck.attach(11);  // attaches the servo on pin x to the servo object
  pinMode(EnableServo,OUTPUT);
  digitalWrite(EnableServo,HIGH); //this turns on the power to the servos
  CenterServos(); //center the servos
  digitalWrite(EnableServo,LOW); //turn power off after centering
  pinMode(Red, OUTPUT);
  digitalWrite(Red, LOW);
  pinMode(Blue, OUTPUT);
  digitalWrite(Blue, LOW);
  pinMode(Green, OUTPUT);
  digitalWrite(Green, LOW);
    pinMode(BuzzerPin, OUTPUT);
  digitalWrite(BuzzerPin, LOW);
  //Buzzer.PlayMelody();
  pinMode(ButtonPin, INPUT);
  digitalWrite(ButtonPin, HIGH); //pull up activated
  Serial.print("Ready");
  //while (digitalRead(ButtonPin) != LOW){
    //do nothing until the button pressed
    BuzzerBeep();
  for(int i=0;i<5;++i){
    BuzzerBeep();
  //check for obstacles, if none, go Forward, if found, turn the other way
  CheckObstacle();
void CheckDistance(){
    // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  cm = microsecondsToCentimeters(duration);
  obstacleDistance = cm;
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
void CheckObstacle(){
  int Obstacle=0;
  Neck.write(Neckcenter);
  delay(100);
  CheckDistance();
  if (obstacleDistance > 20){ //no obstacle nearby
    Obstacle=0;
    Serial.print(obstacleCenter);
    Serial.print("cm center over 20");
  if (obstacleDistance <= 20){ //check sensor
    BuzzerBeep();
  digitalWrite(Red, HIGH);
  delay(100);
  CheckDistance();
  obstacleCenter = obstacleDistance;
  Serial.print("cm center");
  Neck.write(Neckcenter+30); //turn head left
  delay(200);
  digitalWrite(Green, HIGH);
  CheckDistance();
  obstacleLeft = obstacleDistance;
  Serial.print(obstacleLeft);
  Serial.print("cm left");
  Neck.write(Neckcenter-30); //turn head right
  digitalWrite(Blue, HIGH);
  delay(200);
  CheckDistance();
  obstacleRight = obstacleDistance;
  Serial.print(obstacleRight);
  Serial.print("cm right");
    if ((obstacleLeft <= obstacleAhead) && (obstacleRight >= obstacleLeft)){
    Obstacle=1;
    if ((obstacleRight <= obstacleAhead) && (obstacleLeft >= obstacleRight)){
      Obstacle=2;
      if (((obstacleLeft <= obstacleAhead && obstacleRight <= obstacleAhead && obstacleCenter <= obstacleAhead) && (obstacleCenter == obstacleLeft && obstacleCenter == obstacleRight)) || (obstacleLeft <= obstacleWarning && obstacleRight <= obstacleWarning && obstacleCenter <= obstacleWarning)){
      Obstacle=3;
      if ((obstacleLeft <= obstacleAlert) || (obstacleRight <= obstacleAlert) || (obstacleCenter <= obstacleAlert)) {
      Obstacle=4;
  Serial.print(Obstacle);
  Serial.print(" Case");
  switch (Obstacle){
    case 0: //no object
      Forward(1,30); //one step Forward
    case 1: //object on Left
      TurnRight(2,30);
    case 2: //object on Right
      TurnLeft(2,30);
    case 3: //obect in Front (both Left and Right detect the object)
      TurnLeft(4,30); //turn around
    case 4: //obect in Front (both Left and Right detect the object)
      Reverse(2,30); //turn around
Logged
Looking to host an Arduino related site? Check us out:
http://www.bitronictech.net/
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
The rest:
Code:
void CenterServos() // center the servos on powerup
    Lleg.write(LLcenter);              // tell servo to go to position in variable 'center'
    Rleg.write(RLcenter);              // tell servo to go to position in variable 'center'
    Lfoot.write(LFcenter);              // tell servo to go to position in variable 'center'
    Rfoot.write(RFcenter);              // tell servo to go to position in variable 'center'
    Neck.write(Neckcenter);              // tell servo to go to position in variable 'center'
    delay(100);                     // waits 100ms for the servos to reach the position
void BuzzerBeep(){ //beep the buzzer on event
    digitalWrite(BuzzerPin, HIGH);
    delay(100);
//Servo Primatives
void TiltRightUp(byte ang, byte sp){
  //tilt right up
  for (int i=0; i<=ang; i+=5){
    Lfoot.write(LFcenter+i);
    Rfoot.write(RFcenter+i);
    delay(sp);
void TiltRightDown(byte ang, byte sp){
  //tilt right down
  for (int i=ang; i>0; i-=5){
    delay(sp);
void TiltLeftUp(byte ang, byte sp){
  //tilt left up
    Lfoot.write(LFcenter-i);
    Rfoot.write(RFcenter-i);
    delay(sp);
void TiltLeftDown(byte ang, byte sp){
  //tilt left down
    delay(sp);
void LeftFootUp(char ang, byte sp){
  //tilt left up
    delay(sp);
void LeftFootDown(byte ang, byte sp){
  //tilt left down
    delay(sp);
void RightFootUp(byte ang, byte sp){
  //tilt right up
    delay(sp);
void RightFootDown(byte ang, byte sp){
  //tilt right down
    delay(sp);
void SwingRight(byte ang, byte sp){
  //swing right
    Lleg.write(LLcenter-i);
    Rleg.write(RLcenter-i);
    delay(sp);
void SwingRcenter(byte ang, byte sp){
  //swing r->center
    delay(sp);
void SwingLeft(byte ang, byte sp){
  //swing left
  for (byte i=0; i<=ang; i=i+5){
    Lleg.write(LLcenter+i);
    Rleg.write(RLcenter+i);
    delay(sp);
void SwingLcenter(byte ang, byte sp){
  //swing l->center
  for (byte i=ang; i>0; i=i-5){
    delay(sp);
void RightLegIn(byte ang, byte sp){
  //swing right
    delay(sp);
void RightLegIcenter(byte ang, byte sp){
  //swing r->center
    delay(sp);
void RightLegOut(byte ang, byte sp){
  //swing right
    delay(sp);
void RightLegOcenter(byte ang, byte sp){
  //swing r->center
    delay(sp);
void LeftLegIn(byte ang, byte sp){
  //swing left
    delay(sp);
void LeftLegIcenter(byte ang, byte sp){
  //swing l->center
    delay(sp);
void LeftLegOut(byte ang, byte sp){
  //swing left
    delay(sp);
void LeftLegOcenter(byte ang, byte sp){
  //swing l->center
    delay(sp);
void NeckLeft(byte ang, byte sp){
  //swing left
    Neck.write(Neckcenter+i);
    delay(sp);
void NeckRight(byte ang, byte sp){
  //swing right
    Neck.write(Neckcenter-i);
    delay(sp);
void NeckIcenter(byte ang, byte sp){
  //swing neck->center
    delay(sp);
void NeckOcenter(byte ang, byte sp){
    delay(sp);
//Walk Functions
void Forward(byte Steps, byte Speed){
  TiltRightUp(tAngle, Speed);
  for (byte j=0; j<Steps; ++j){
    SwingRight(sAngle, Speed);
    TiltRightDown(tAngle, Speed);
    TiltLeftUp(tAngle, Speed);
    SwingRcenter(sAngle, Speed);
    SwingLeft(sAngle, Speed);
    TiltLeftDown(tAngle, Speed);
    SwingLcenter(sAngle, Speed);
void Reverse(byte Steps, byte Speed){
void TurnLeft(byte Steps, byte Speed){
  TiltLeftUp(uAngle, Speed);
  delay(20);
    LeftLegIn(sAngle, Speed);
    TiltLeftDown(uAngle, Speed);
    TiltRightUp(uAngle, Speed);
    delay(20);
    LeftLegIcenter(sAngle, Speed);
    RightLegOut(sAngle, Speed);
    TiltRightDown(uAngle, Speed);
    delay(20);
    RightLegOcenter(sAngle, Speed);
void TurnRight(byte Stps, byte Speed){
  delay(20);
  for (byte f=0; f<=Stps; ++f){
    RightLegIn(sAngle, Speed);
    delay(20);
    RightLegIcenter(sAngle, Speed);
    LeftLegOut(sAngle, Speed);
    delay(20);
    LeftLegOcenter(sAngle, Speed);
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
The multithreaded code looks like this:
Code:
#include <Servo.h>
#include <ChibiOS_AVR.h>
#define BuzzerPin 4
#define ButtonPin 2
#define Red 3
#define Green 5
#define Blue 6
Servo Rleg;
Servo Lfoot;
Servo Rfoot;
Servo Neck;
int LLcenter = 80;
int RLcenter = 80;
int LFcenter = 80;
//Setup Variable to Store Switch Value
int Obstacle=0;
// remember thread pointers
Thread* tp1;
Thread* tp2;
// thread 1 - high priority for walking motion
// 200 byte stack beyond task switch and interrupt needs
static WORKING_AREA(waThread1, 200);
static msg_t Thread1(void *arg) {
  while (TRUE) {
  WalkDirection();
// thread 2 - scan for obstacles as walking
static WORKING_AREA(waThread2, 200);
static msg_t Thread2(void *arg) {
  while (TRUE) {
    ScanObstacle();
  // end task
  // read any input
  delay(200);
  while (Serial.read() >= 0) {}
  Serial.print("Ready... ");
  chBegin(mainThread);
  // chBegin never returns, main thread continues with mainThread()
  // shouldn't return
  while(1) {}
// main thread runs at NORMALPRIO
void mainThread() {
  // start walk thread
  tp1 = chThdCreateStatic(waThread1, sizeof(waThread1),
                          NORMALPRIO + 2, Thread1, NULL);
  // start object scan thread
  tp2 = chThdCreateStatic(waThread2, sizeof(waThread2),
                          NORMALPRIO + 2, Thread2, NULL);
 // not used
  long duration, cm;
  delay(2);
  delay(5);
  delay(10);
void ScanObstacle(){
  chThdSleepMilliseconds(100);
  CheckDistance();
    Obstacle=0;
    BuzzerBeep();
  CheckDistance();
  chThdSleepMilliseconds(10);
  CheckDistance();
  CheckDistance();
    Obstacle=1;
      Obstacle=2;
      Obstacle=3;
      Obstacle=4;
    // print memory use
  Serial.println("Memory use");
  Serial.println("Area,Size,Unused");
  Serial.print("Thread 1,");
  // size of stack for thread 1
  Serial.print(sizeof(waThread1) - sizeof(Thread));
  Serial.write(',');
  // unused stack for thread 1
  Serial.println(chUnusedStack(waThread1, sizeof(waThread1)));
  Serial.print("Thread 2,");
  // size of stack for thread 2
  Serial.print(sizeof(waThread2) - sizeof(Thread));
  Serial.write(',');
  // unused stack for thread 2
  Serial.println(chUnusedStack(waThread2, sizeof(waThread2)));
  // print stats for heap/main thread area
  Serial.print("Heap/Main,");
  Serial.print(chHeapMainSize());
  Serial.print(",");
  Serial.println(chUnusedHeapMain());
  // end task
void WalkDirection(){
  switch (Obstacle){
    case 0: //no object
      TurnRight(2,30);
      TurnLeft(2,30);
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
The rest:
Code:
//Servo Primatives
  //tilt right up
    chThdSleepMilliseconds(sp);
  //tilt right down
  //tilt left up
  //tilt left down
  //tilt left up
  //tilt left down
  //tilt right up
  //tilt right down
  //swing right
  //swing r->center
  //swing left
  //swing l->center
  //swing right
  //swing r->center
  //swing right
  //swing r->center
  //swing left
  //swing l->center
  //swing left
  //swing l->center
  //swing left
  //swing right
//Walk Functions
  chThdSleepMilliseconds(20);
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
So the single threaded original code works as expected, the bot walks until it sees an obstacle, stops turns it head and checks how to go around the obstacle or if it's too close to back up.
The idea of the mutithread is that it could check for obstacle while walking and adjust without stopping. The problem being that my sensor values are returning as 0 iun the multi thread version. I've been at this for some hours now, and any input on how to fix it would be MUCH appreciated.
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Variables that are shared between threads should be typed volatile.
Also you need to insure access to variables is atomic.  A context switch can happen during a multi-byte fetch or store.
See count in the the chBlinkPrint example.
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
okay I have updated the code to reflect this:
Code:
#include <Servo.h>
#define BuzzerPin 4
#define ButtonPin 2
#define Red 3
#define Green 5
#define Blue 6
Servo Rleg;
Servo Lfoot;
Servo Rfoot;
Servo Neck;
int LLcenter = 80;
int RLcenter = 80;
int LFcenter = 80;
volatile uint32_t Obstacle=0;
// pin to trigger interrupt
Thread* tp1;
Thread* tp2;
  while (TRUE) {
  WalkDirection();
  while (TRUE) {
    ScanObstacle();
  // end task
  // read any input
  delay(200);
  // shouldn't return
  while(1) {}
void mainThread() {
 // not used
  long duration, cm;
  delay(2);
  delay(5);
  delay(10);
  CheckDistance();
    Obstacle=0;
    BuzzerBeep();
  CheckDistance();
  CheckDistance();
  CheckDistance();
  noInterrupts();
    Obstacle=1;
      Obstacle=2;
      Obstacle=3;
      Obstacle=4;
  interrupts();
  Serial.write(',');
  Serial.write(',');
  Serial.print(",");
  // end task
  noInterrupts();
  switch (Obstacle){
    case 0: //no object
      TurnRight(2,30);
      TurnLeft(2,30);
      interrupts();
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
The rest:
Code:
//Servo Primatives
  //tilt right up
  //tilt right down
  //tilt left up
  //tilt left down
  //tilt left up
  //tilt left down
  //tilt right up
  //tilt right down
  //swing right
  //swing r->center
  //swing left
  //swing l->center
  //swing right
  //swing r->center
  //swing right
  //swing r->center
  //swing left
  //swing l->center
  //swing left
  //swing l->center
  //swing left
  //swing right
//Walk Functions
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
However the sensor reading are still volatile, thanks for the help and forgive my newb-ish-ness
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
The latest version not including servo primatives (which remain unchanged):
Code:
#include <Servo.h>
#define BuzzerPin 4
#define ButtonPin 2
#define Red 3
#define Green 5
#define Blue 6
Servo Rleg;
Servo Lfoot;
Servo Rfoot;
Servo Neck;
int LLcenter = 80;
int RLcenter = 80;
int LFcenter = 80;
Thread* tp1;
Thread* tp2;
  while (TRUE) {
  WalkDirection();
  while (TRUE) {
    ScanObstacle();
  // end task
  // read any input
  delay(200);
  // shouldn't return
  while(1) {}
void mainThread() {
 // not used
  long duration, cm;
  delay(2);
  delay(5);
  delay(10);
  CheckDistance();
    Obstacle=0;
    BuzzerBeep();
  CheckDistance();
  CheckDistance();
  chThdSleepMilliseconds(200);
  CheckDistance();
  noInterrupts();
    Obstacle=1;
      Obstacle=2;
      Obstacle=3;
      Obstacle=4;
  interrupts();
  Serial.write(',');
  Serial.write(',');
  Serial.print(",");
  // end task
  noInterrupts();
  switch (Obstacle){
    case 0: //no object
      TurnRight(2,30);
      TurnLeft(2,30);
      interrupts();
Now only the "left" reading isn't working, it always returns a 0 value.
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Are all the shared variables volatile like this?
Code:
volatile int sharedVar;
Otherwise the compiler sometimes fails to store or fetch values correctly.
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
I believe the only shared variable is "Obstacle" should I make them all volatile for good measure?
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
The serial outputs I added for diagnostics give me this:
Code:
Memory use
Area,Size,Unused
Thread 1,269,161
Thread 2,269,161
Heap/Main,1393,1338
0cm center over 20
0cm center over 20
0cm center over 20
0cm center over 20
0cm center over 20
0cm center over 20
0cm center over 20
0 Case
177cm center
70cm left
0 Case
0cm right
Memory use
Area,Size,Unused
Thread 1,269,161
Thread 2,269,161
Heap/Main,1393,1338
177cm center over 20
0 Case
0 Case
0cm center
0 Case
0cm left
0 Case
0cm right
Memory use
Area,Size,Unused
Thread 1,269,161
Thread 2,269,145
Heap/Main,1393,1338
20cm center
4 Case
0cm left
0cm right
Memory use
Area,Size,Unused
Thread 1,269,161
Thread 2,269,145
Heap/Main,1393,1338
4 Case
21cm center
0cm left
0cm right
4 Case
Memory use
Area,Size,Unused
Thread 1,269,161
Thread 2,269,145
Heap/Main,1393,1338
21cm center over 20
25cm center
0cm left
0 Case
0cm right
Memory use
Area,Size,Unused
Thread 1,269,161
Thread 2,269,145
Heap/Main,1393,1338
25cm center over 20
0 Case
22cm center
0 Case
0cm left
0 Case
0cm right
Memory use
Area,Size,Unused
Thread 1,269,161
Thread 2,269,145
Heap/Main,1393,1338
4 Case
0cm center
0cm left
4 Case
0cm right
Memory use
Area,Size,Unused
Thread 1,269,161
Thread 2,269,144
Heap/Main,1393,1338
21cm center
4 Case
0cm left
18cm right
Memory use
Area,Size,Unused
Thread 1,269,161
Thread 2,269,144
Heap/Main,1393,1338
14cm center
0cm left
4 Case
0cm right
Memory use
Area,Size,Unused
Thread 1,269,161
Thread 2,269,144
Heap/Main,1393,1338
It looks like its missing the sensor reading sometime. I could add a 5th case where if any of the readings is 0 it continues forward, but it would not be very accurate for obstacle avoidance. There has to be something I'm missing here.
Thanks for all of your help.
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
Is it possible that the arduino mini is just not powerful enough to do this all in real time?
Logged
Long Island, NY
Offline Offline
Newbie
View Profile
WWW
Or it could also be that while my 9v 170mAh rechargeable is providing enough current to drive 1 servo and the ping, 5 servos or 6 servos (and 2 RGB LEDs... It is not providing enough current to run 6 servos, the ping and 2RGB LEDs concurrently
Logged
Pages: [1] 2   Go Up
Print
Jump to:
