Long Island, NY
Offline
Newbie
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself.
« Reply #15 on: February 05, 2013, 04:50:22 am » |
After setting up a test task with 4 threads running concurrently I can say without a doubt that the power supply is the issue. The ping does not have sufficient current to send out the ultrasonic blast.
Logged
0
Offline
Edison Member
Arduino rocks
« Reply #16 on: February 05, 2013, 05:48:34 am » |
You need to check that the sensor data is being updated properly. Adding a time of reading would be helpful. Here is a demo sketch that shows data sharing with an accelerometer. The shared variable dataT is the time in milis() when the data was acquired. Note the mutex, volatile shared vatiables, and the use of temp variables to limit the time shared data is locked. // Simple demo of daata sharing. // Adafruit ADXL335 - 5V ready triple-axis accelerometer. #include <ChibiOS_AVR.h>
const uint8_t X_PIN = 0; const uint8_t Y_PIN = 1; const uint8_t Z_PIN = 2;
// approximate zero g value. const int dataOffset = 338; //------------------------------------------------------------------------------ // Shared data, use volatile to insure correct access.
// Mutex for atomic access to data. MUTEX_DECL(dataMutex);
// Time data was read. volatile uint32_t dataT;
// Data X value. volatile int dataX;
// Data Y value. volatile int dataY;
// Data Z value. volatile int dataZ; //------------------------------------------------------------------------------ // Thread 1, high priority to read accelerometer. // 64 byte stack beyond task switch and interrupt needs. static WORKING_AREA(waThread1, 64);
static msg_t Thread1(void *arg) {
// Read data every 10 ms. systime_t wakeTime = chTimeNow(); while (1) { // Add ticks for 10 ms. wakeTime += MS2ST(10); chThdSleepUntil(wakeTime); // Use temp variables to acquire data. uint32_t tmpT = millis(); int tmpX = analogRead(X_PIN); int tmpY = analogRead(Y_PIN); int tmpZ = analogRead(Z_PIN);
// Lock access to data. chMtxLock(&dataMutex);
// Copy tmp variables to shared variables. dataT = tmpT; dataX = tmpX; dataY = tmpY; dataZ = tmpX; // Unlock data access. chMtxUnlock(); } return 0; } //------------------------------------------------------------------------------ // thread 2 - print data every second. // 100 byte stack beyond task switch and interrupt needs static WORKING_AREA(waThread2, 100);
static msg_t Thread2(void *arg) {
// print count every second systime_t wakeTime = chTimeNow(); while (1) { // Sleep for one second. wakeTime += MS2ST(1000); chThdSleepUntil(wakeTime); // Lock access to data. chMtxLock(&dataMutex);
// Copy shared data to tmp variables. uint32_t tmpT = dataT; int tmpX = dataX; int tmpY = dataY; int tmpZ = dataZ;
// Unlock data access. chMtxUnlock(); Serial.print(F("dataAge: ")); Serial.print(millis() - tmpT); Serial.print(F(" ms, dataX: ")); Serial.print(tmpX -dataOffset); Serial.print(F(", dataY: ")); Serial.print(tmpY - dataOffset); Serial.print(F(", dataZ: ")); Serial.println(tmpZ - dataOffset); } } //------------------------------------------------------------------------------ void setup() { Serial.begin(9600); // wait for USB Serial while (!Serial) {} // read any input delay(200); while (Serial.read() >= 0) {}
chBegin(mainThread); // chBegin never returns, main thread continues with mainThread() while(1) {} } //------------------------------------------------------------------------------ // main thread runs at NORMALPRIO void mainThread() {
// start blink thread chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO + 2, Thread1, NULL);
// start print thread chThdCreateStatic(waThread2, sizeof(waThread2), NORMALPRIO + 1, Thread2, NULL); } //------------------------------------------------------------------------------ void loop() { // not used }
Here is output from the sketch. Note the data is never older than 10 milliseconds. dataAge: 4 ms, dataX: 0, dataY: 1, dataZ: 100 dataAge: 8 ms, dataX: -1, dataY: 1, dataZ: 99 dataAge: 3 ms, dataX: 4, dataY: -13, dataZ: 104 dataAge: 7 ms, dataX: 83, dataY: -5, dataZ: 183 dataAge: 2 ms, dataX: 90, dataY: -54, dataZ: 190 dataAge: 6 ms, dataX: 19, dataY: 65, dataZ: 119 dataAge: 1 ms, dataX: 112, dataY: 93, dataZ: 212
« Last Edit: February 05, 2013, 05:50:39 am by fat16lib »
Logged
Long Island, NY
Offline
Newbie
« Reply #17 on: February 05, 2013, 07:47:03 am » |
I did make that shared variable volatile and during use by a thread. I as able to execute the script correctly buy running it on an arduino with no servos attached, unfortunately I don't think it was a code issue but a power supply issue as the "ping" sensor itself was not lighting fully with the servos on but with them disabled I had no problems.
Logged
Long Island, NY
Offline
Newbie
« Reply #18 on: February 05, 2013, 08:01:17 am » |
This was my final code: #include <Servo.h> #include <ChibiOS_AVR.h>
MUTEX_DECL(lockMutex);
#define EnableServo 13 #define BuzzerPin 4 #define ButtonPin 2 #define Red 3 #define Green 5 #define Blue 6
Servo Lleg; // create servo object to control a servo Servo Rleg; Servo Lfoot; Servo Rfoot; Servo Neck;
int RFcenter = 80; // variables to store the center servo positions int LLcenter = 80; int RLcenter = 80; int LFcenter = 80; int Neckcenter = 90; // Setup variables to store sensor readings int obstacleDistance = 0; int obstacleLeft = 0; int obstacleCenter = 0; int obstacleRight = 0; int presentDistance = 0; // declare reaction distances on object preception int obstacleAhead = 20; int obstacleWarning = 10; int obstacleAlert = 8; // declare angle values for walking int tAngle = 25; //tilt angle int uAngle = 35; //turn angle int sAngle = 30; //swing angle int neckAngle = 30; //angle for meck turn const int pingPin = 12; // define sensor pin
// remember thread pointers Thread* tp1; Thread* tp2;
//------------------------------------------------------------------------------ // thread 1 - high priority for walking motion // 200 byte stack beyond task switch and interrupt needs static WORKING_AREA(waThread1, 200);
static msg_t Thread1(void *arg) { while (TRUE) { WalkDirection(); } }
//------------------------------------------------------------------------------ // thread 2 - scan for obstacles as walking // 200 byte stack beyond task switch and interrupt needs static WORKING_AREA(waThread2, 200);
static msg_t Thread2(void *arg) { while (TRUE) { ScanObstacle(); } // end task } //------------------------------------------------------------------------------
void setup() { // initialize serial communication: Serial.begin(19200); // read any input delay(200); while (Serial.read() >= 0) {} Lleg.attach(7); // attaches the servo on pin x to the servo object Rleg.attach(10); // attaches the servo on pin x to the servo object Lfoot.attach(8); // attaches the servo on pin x to the servo object Rfoot.attach(9); // attaches the servo on pin x to the servo object Neck.attach(11); // attaches the servo on pin x to the servo object
pinMode(EnableServo,OUTPUT); digitalWrite(EnableServo,HIGH); //this turns on the power to the servos CenterServos(); //center the servos delay(500); digitalWrite(EnableServo,LOW); //turn power off after centering pinMode(Red, OUTPUT); digitalWrite(Red, LOW); pinMode(Blue, OUTPUT); digitalWrite(Blue, LOW); pinMode(Green, OUTPUT); digitalWrite(Green, LOW); pinMode(BuzzerPin, OUTPUT); digitalWrite(BuzzerPin, LOW); //Buzzer.PlayMelody(); pinMode(ButtonPin, INPUT); digitalWrite(ButtonPin, HIGH); //pull up activated Serial.print("Ready... ");
chBegin(mainThread); // chBegin never returns, main thread continues with mainThread() // shouldn't return while(1) {} } //------------------------------------------------------------------------------ // main thread runs at NORMALPRIO void mainThread() { // start walk thread tp1 = chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO + 2, Thread1, NULL);
// start object scan thread tp2 = chThdCreateStatic(waThread2, sizeof(waThread2), NORMALPRIO + 2, Thread2, NULL); } //------------------------------------------------------------------------------ void loop() { // not used }
void CheckDistance(){ // establish variables for duration of the ping, // and the distance result in inches and centimeters: long duration, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds. // Give a short LOW pulse beforehand to ensure a clean HIGH pulse: pinMode(pingPin, OUTPUT); digitalWrite(pingPin, LOW); chThdSleepMilliseconds(2); digitalWrite(pingPin, HIGH); chThdSleepMilliseconds(5); digitalWrite(pingPin, LOW);
// The same pin is used to read the signal from the PING))): a HIGH // pulse whose duration is the time (in microseconds) from the sending // of the ping to the reception of its echo off of an object. pinMode(pingPin, INPUT); duration = pulseIn(pingPin, HIGH);
// convert the time into a distance chThdSleepMilliseconds(10); cm = microsecondsToCentimeters(duration); obstacleDistance = cm; }
long microsecondsToCentimeters(long microseconds) { // The speed of sound is 340 m/s or 29 microseconds per centimeter. // The ping travels out and back, so to find the distance of the // object we take half of the distance travelled. return microseconds / 29 / 2; }
void ScanObstacle(){ Neck.write(Neckcenter); chThdSleepMilliseconds(100); CheckDistance(); if (obstacleDistance > obstacleAhead){ //no obstacle nearby chMtxLock(&lockMutex); Obstacle=0; chMtxUnlock(); Serial.print(obstacleDistance); Serial.print("cm center over 20"); Serial.println(); } if (obstacleDistance <= obstacleAhead){ //check sensor BuzzerBeep(); Neck.write(Neckcenter); chThdSleepMilliseconds(100); digitalWrite(Red, HIGH); CheckDistance(); chThdSleepMilliseconds(10); obstacleCenter = obstacleDistance; Serial.print(obstacleCenter); Serial.print("cm center"); Serial.println(); Neck.write(Neckcenter+neckAngle); //turn head left chThdSleepMilliseconds(200); digitalWrite(Green, HIGH); CheckDistance(); obstacleLeft = obstacleDistance; Serial.print(obstacleLeft); Serial.print("cm left"); Serial.println(); digitalWrite(Green, LOW); Neck.write(Neckcenter-neckAngle); //turn head right chThdSleepMilliseconds(200); digitalWrite(Blue, HIGH); CheckDistance(); obstacleRight = obstacleDistance; Serial.print(obstacleRight); Serial.print("cm right"); Serial.println(); digitalWrite(Blue, LOW); Neck.write(Neckcenter); chMtxLock(&lockMutex); if ((obstacleLeft <= obstacleAhead) && (obstacleRight >= obstacleLeft)){ Obstacle=1; } if ((obstacleRight <= obstacleAhead) && (obstacleLeft >= obstacleRight)){ Obstacle=2; } if (((obstacleLeft <= obstacleAhead && obstacleRight <= obstacleAhead && obstacleCenter <= obstacleAhead) && (obstacleCenter == obstacleLeft && obstacleCenter == obstacleRight)) || (obstacleLeft <= obstacleWarning && obstacleRight <= obstacleWarning && obstacleCenter <= obstacleWarning)){ Obstacle=3; } if ((obstacleLeft <= obstacleAlert) || (obstacleRight <= obstacleAlert) || (obstacleCenter <= obstacleAlert)) { Obstacle=4; } chMtxUnlock(); } } void WalkDirection(){ chMtxLock(&lockMutex); int walkToggle = Obstacle; chMtxUnlock(); Serial.print(walkToggle); Serial.print(" Case"); Serial.println(); switch (walkToggle){ case 0: //no object digitalWrite(Green, HIGH); digitalWrite(Red, HIGH); Forward(1,30); //one step Forward digitalWrite(Green, LOW); digitalWrite(Red, LOW); break; case 1: //object on Left digitalWrite(Green, HIGH); TurnRight(2,30); digitalWrite(Green, LOW); break; case 2: //object on Right digitalWrite(Blue, HIGH); TurnLeft(2,30); digitalWrite(Blue, LOW); break; case 3: //obect in Front (both Left and Right detect the object) digitalWrite(Red, HIGH); TurnLeft(4,30); //turn around digitalWrite(Red, LOW); break; case 4: //obect in Front (both Left and Right detect the object) digitalWrite(Red, HIGH); Reverse(2,30); //turn around digitalWrite(Red, LOW); break; } } However the serial output and actions of the robot always reflect case 4 (0cm, 0cm, 0cm) If I power it with 9V and USB some of those readings come back with a value.
Logged
Long Island, NY
Offline
Newbie
« Reply #19 on: February 05, 2013, 08:07:10 am » |
Something like this running three threads including the scan thread works fine, plus I see that the ping is powered. #include <Servo.h> #include <ChibiOS_AVR.h>
MUTEX_DECL(serialMutex);
int RFcenter = 80; // variables to store the center servo positions int LLcenter = 80; int RLcenter = 80; int LFcenter = 80; int Neckcenter = 90; // Setup variables to store sensor readings int obstacleDistance = 0; int obstacleLeft = 0; int obstacleCenter = 0; int obstacleRight = 0; int presentDistance = 0; //Setup Variable to Store Switch Value volatile int Obstacle=0; //Non volatile int to limit time with no interrupt int walkToggle = 0; // declare reaction distances on object preception int obstacleAhead = 20; int obstacleWarning = 10; int obstacleAlert = 8; // declare angle values for walking int tAngle = 25; //tilt angle int uAngle = 30; //turn angle int sAngle = 30; //swing angle const int pingPin = 12; // define sensor pin // pin to trigger interrupt
const uint8_t LED_PIN = 6;
volatile uint32_t count = 0;
// remember thread pointers Thread* tp1; Thread* tp2; Thread* tp3; //------------------------------------------------------------------------------ // thread 1 - high priority for blinking LED // 64 byte stack beyond task switch and interrupt needs static WORKING_AREA(waThread1, 64);
static msg_t Thread1(void *arg) { pinMode(LED_PIN, OUTPUT); while (!chThdShouldTerminate()) { digitalWrite(LED_PIN, HIGH); chThdSleepMilliseconds(50); digitalWrite(LED_PIN, LOW); chThdSleepMilliseconds(150); } return 0; } //------------------------------------------------------------------------------ static WORKING_AREA(waThread2, 200);
Serial.println("Type any character for stack use");
// print count every second while (!Serial.available()) { Serial.println(count); count = 0; chThdSleepMilliseconds(1000); } // Terminate the LED thread chThdTerminate(tp1);
// print memory use Serial.println(); Serial.println("Memory use"); Serial.println("Area,Size,Unused"); Serial.print("Thread 1,"); // size of stack for thread 1 Serial.print(sizeof(waThread1) - sizeof(Thread)); Serial.write(','); // unused stack for thread 1 Serial.println(chUnusedStack(waThread1, sizeof(waThread1))); Serial.print("Thread 2,"); // size of stack for thread 2 Serial.print(sizeof(waThread2) - sizeof(Thread)); Serial.write(',');
// unused stack for thread 2 Serial.println(chUnusedStack(waThread2, sizeof(waThread2)));
// print stats for heap/main thread area Serial.print("Heap/Main,"); Serial.print(chHeapMainSize()); Serial.print(","); Serial.println(chUnusedHeapMain()); // end task return 0; } //------------------------------------------------------------------------------ // thread 3 - high priority for blinking LED // 64 byte stack beyond task switch and interrupt needs static WORKING_AREA(waThread3, 200);
static msg_t Thread3(void *arg) {
while (TRUE){ ScanObstacle(); } } //------------------------------------------------------------------------------ void setup() { Serial.begin(9600); // wait for USB Serial while (!Serial) {} // read any input delay(200); while (Serial.read() >= 0) {} Neck.attach(11); // attaches the servo on pin x to the servo object
pinMode(EnableServo,OUTPUT); digitalWrite(EnableServo,HIGH); //this turns on the power to the servos delay(100); digitalWrite(EnableServo,LOW); //turn power off after centering
chBegin(mainThread); while(1) {} } //------------------------------------------------------------------------------ // main thread runs at NORMALPRIO void mainThread() {
// start blink thread tp1 = chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO + 2, Thread1, NULL);
// start print thread tp2 = chThdCreateStatic(waThread2, sizeof(waThread2), NORMALPRIO + 1, Thread2, NULL); // start print thread tp3 = chThdCreateStatic(waThread3, sizeof(waThread3), NORMALPRIO + 1, Thread3, NULL);
// increment counter while (1) { noInterrupts(); count++; interrupts(); } } //------------------------------------------------------------------------------ void loop() { // not used }
Logged
Long Island, NY
Offline
Newbie
« Reply #20 on: February 05, 2013, 08:07:22 am » |
void ScanObstacle(){ Neck.write(Neckcenter); chThdSleepMilliseconds(100); CheckDistance(); if (obstacleDistance > 20){ //no obstacle nearby Obstacle=0; chMtxLock(&serialMutex); Serial.print(obstacleDistance); Serial.print("cm center over 20"); Serial.println(); chMtxUnlock(); } if (obstacleDistance <= 20){ //check sensor BuzzerBeep(); Neck.write(Neckcenter); chThdSleepMilliseconds(100); digitalWrite(Red, HIGH); CheckDistance(); chThdSleepMilliseconds(10); obstacleCenter = obstacleDistance; Neck.write(Neckcenter+30); //turn head left chThdSleepMilliseconds(200); digitalWrite(Green, HIGH); CheckDistance(); obstacleLeft = obstacleDistance; digitalWrite(Green, LOW); Neck.write(Neckcenter-30); //turn head right chThdSleepMilliseconds(200); digitalWrite(Blue, HIGH); CheckDistance(); obstacleRight = obstacleDistance; digitalWrite(Blue, LOW); Neck.write(Neckcenter); if ((obstacleLeft <= obstacleAhead) && (obstacleRight >= obstacleLeft)){ Obstacle=1; } if ((obstacleRight <= obstacleAhead) && (obstacleLeft >= obstacleRight)){ Obstacle=2; } if (((obstacleLeft <= obstacleAhead && obstacleRight <= obstacleAhead && obstacleCenter <= obstacleAhead) && (obstacleCenter == obstacleLeft && obstacleCenter == obstacleRight)) || (obstacleLeft <= obstacleWarning && obstacleRight <= obstacleWarning && obstacleCenter <= obstacleWarning)){ Obstacle=3; } if ((obstacleLeft <= obstacleAlert) || (obstacleRight <= obstacleAlert) || (obstacleCenter <= obstacleAlert)) { Obstacle=4; } } chMtxLock(&serialMutex); Serial.print(obstacleCenter); Serial.print("cm center"); Serial.println(); Serial.print(obstacleLeft); Serial.print("cm left"); Serial.println(); Serial.print(obstacleRight); Serial.print("cm right"); Serial.println(); Serial.print(Obstacle); Serial.print(" Case"); Serial.println(); Serial.println("Memory use"); Serial.println("Area,Size,Unused"); Serial.print("Thread 1,"); // size of stack for thread 1 Serial.print(sizeof(waThread1) - sizeof(Thread)); Serial.write(','); // unused stack for thread 1 Serial.println(chUnusedStack(waThread1, sizeof(waThread1))); Serial.print("Thread 2,"); // size of stack for thread 2 Serial.print(sizeof(waThread2) - sizeof(Thread)); Serial.write(',');
// unused stack for thread 2 Serial.println(chUnusedStack(waThread2, sizeof(waThread2))); Serial.print("Thread 3,"); // size of stack for thread 3 Serial.print(sizeof(waThread3) - sizeof(Thread)); Serial.write(','); // unused stack for thread 3 Serial.println(chUnusedStack(waThread3, sizeof(waThread3)));
// print stats for heap/main thread area Serial.print("Heap/Main,"); Serial.print(chHeapMainSize()); Serial.print(","); Serial.println(chUnusedHeapMain()); // end task chMtxUnlock(); }
void WalkDirection(){ noInterrupts(); Serial.print(Obstacle); Serial.print(" Case"); Serial.println(); walkToggle = Obstacle; interrupts(); switch (walkToggle){ case 0: //no object digitalWrite(Green, HIGH); digitalWrite(Red, HIGH); Forward(1,30); //one step Forward digitalWrite(Green, LOW); digitalWrite(Red, LOW); break; case 1: //object on Left digitalWrite(Green, HIGH); TurnRight(2,30); digitalWrite(Green, LOW); break; case 2: //object on Right digitalWrite(Blue, HIGH); TurnLeft(2,30); digitalWrite(Blue, LOW); break; case 3: //obect in Front (both Left and Right detect the object) digitalWrite(Red, HIGH); TurnLeft(4,30); //turn around digitalWrite(Red, LOW); break; case 4: //obect in Front (both Left and Right detect the object) digitalWrite(Red, HIGH); Reverse(2,30); //turn around digitalWrite(Red, LOW); break; } }
Logged
Long Island, NY
Offline
Newbie
« Reply #21 on: February 05, 2013, 08:08:22 am » |
So I guess I was scratching my head for 15 hours because I need a second power source for the servos... 6 servos, 2 RGB lights an Arduino Micro and a Ping Sensor cant run on one 9v 170mAh battery, plus I learned the ins and outs of ChibiOS  Thanks for the help
Logged
Long Island, NY
Offline
Newbie
« Reply #22 on: February 05, 2013, 08:16:00 am » |
My serial output with the battery and USB hooked up looks like this: 24cm center 22cm left 0cm right 4 Case 28cm center 29cm left 0cm right 4 Case 43cm center 62cm left 39cm right 6cm center 4 Case 0cm left 39cm right 4 Case 38cm center 16cm left 0cm right 4 Case 40cm center 0cm left 41cm right 80cm center over 20 59cm center over 20 42cm center over 20 40cm center over 20 0 Case 0 Case 0cm center 4cm left 69cm right 4 Case 0cm center 244cm left 70cm right 4 Case 220cm center 245cm left 69cm right 79cm center 246cm left 69cm right 210cm center over 20 0 Case 22cm center 246cm left 63cm right 0 Case 0 Case
It's still missing some sensor readings, although not all the time. Maybe i need to use a semaphore to get the two processes synchronized? I was moving the bot around during that to get different readings and the reported distances are accurate.
Logged
Rapa Nui
Offline
God Member
Pukao hats cleaning services
« Reply #23 on: February 05, 2013, 09:02:56 am » |
Or it could also be that while my 9v 170mAh rechargeable is providing enough current to drive 1 servo and the ping, 5 servos or 6 servos (and 2 RGB LEDs... It is not providing enough current to run 6 servos, the ping and 2RGB LEDs concurrently
You can hardly use that battery for running that stuff.. The above battery is intended for powering systems with 20mA current consumption. A single servo can take 500mA or more when acting. Better you use for example a 7.4V li-poly rechargeable battery pack..
« Last Edit: February 05, 2013, 09:05:03 am by pito »
Logged
Long Island, NY
Offline
Newbie
« Reply #24 on: February 05, 2013, 03:54:55 pm » |
What about a 9v li-po rechargable at 500mAh?
Logged
Rapa Nui
Offline
God Member
« Reply #25 on: February 06, 2013, 05:22:05 pm » |
500mAh - that is the capacity (C). The Q is how much current it can deliver (in a much shorter time of course). Li-po batteries can do 1C up to 60C current (C=capacity) afaik, based on type etc. If the li-po pack is 500mAh and for example its C=10, it can deliver ~5A for ~6minutes..
« Last Edit: February 06, 2013, 06:12:20 pm by pito »
Logged
Long Island, NY
Offline
Newbie
« Reply #26 on: February 06, 2013, 08:14:18 pm » |
I am using 9 gram HTX900 servos which at peak have 1.6kg of torque but at no time are they lifting more then 350 grams so I doubt they are using the 500 mA each, I know that wiring lithium batteries in parallel is supposed to be a no-no  I know we are off topic for software now! This thing was previously running on a single nickel rechargeable 170mAh and I think that is why with 5 servos and the sensor reading were fine but with servo six things got inconsistent because it could not supply the current even at full charge.
Logged
