Pages: 1 [2]   Go Down
Author Topic: Semaphores, Mutex and RTOS on Arduino (ChibiOS Help?)  (Read 1315 times)
Long Island, NY
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself.
After setting up a test task with 4 threads running concurrently I can say without a doubt that the power supply is the issue. The ping does not have sufficient current to send out the ultrasonic blast.
Looking to host an Arduino related site? Check us out:
http://www.bitronictech.net/
You need to check that the sensor data is being updated properly.  Adding a time of reading would be helpful.
Here is a demo sketch that shows data sharing with an accelerometer.  The shared variable dataT is the time in milis() when the data was acquired.
Note the mutex, volatile shared vatiables, and the use of temp variables to limit the time shared data is locked.
// Simple demo of daata sharing.
// Adafruit ADXL335 - 5V ready triple-axis accelerometer.
#include <ChibiOS_AVR.h>
const uint8_t X_PIN = 0;
const uint8_t Y_PIN = 1;
const uint8_t Z_PIN = 2;
// approximate zero g value.
const int dataOffset = 338;
// Shared data, use volatile to insure correct access.
// Mutex for atomic access to data.
MUTEX_DECL(dataMutex);
// Time data was read.
volatile uint32_t dataT;
// Data X value.
volatile int dataX;
// Data Y value.
volatile int dataY;
// Data Z value.
volatile int dataZ;
// Thread 1, high priority to read accelerometer.
// 64 byte stack beyond task switch and interrupt needs.
static WORKING_AREA(waThread1, 64);
static msg_t Thread1(void *arg) {
  // Read data every 10 ms.
  systime_t wakeTime = chTimeNow();
  while (1) {
    // Add ticks for 10 ms.
    wakeTime += MS2ST(10);
    chThdSleepUntil(wakeTime);
    // Use temp variables to acquire data.
    uint32_t tmpT = millis();
    int tmpX = analogRead(X_PIN);
    int tmpY = analogRead(Y_PIN);
    int tmpZ = analogRead(Z_PIN);
    // Lock access to data.
    chMtxLock(&dataMutex);
    // Copy tmp variables to shared variables.
    dataT = tmpT;
    dataX = tmpX;
    dataY = tmpY;
    dataZ = tmpX;
    // Unlock data access.
    chMtxUnlock();
  return 0;
// thread 2 - print data every second.
// 100 byte stack beyond task switch and interrupt needs
static WORKING_AREA(waThread2, 100);
static msg_t Thread2(void *arg) {
  // print count every second
  while (1) {
    // Sleep for one second.
    wakeTime += MS2ST(1000);
    // Copy shared data to tmp variables.
    uint32_t tmpT = dataT;
    int tmpX = dataX;
    int tmpY = dataY;
    int tmpZ = dataZ;
    chMtxUnlock();
    Serial.print(F("dataAge: "));
    Serial.print(millis() - tmpT);
    Serial.print(F(" ms, dataX: "));
    Serial.print(tmpX -dataOffset);
    Serial.print(F(", dataY: "));
    Serial.print(tmpY - dataOffset);
    Serial.print(F(", dataZ: "));
    Serial.println(tmpZ - dataOffset);
  // wait for USB Serial
  while (!Serial) {}
  // read any input
  delay(200);
  while (Serial.read() >= 0) {}
  chBegin(mainThread);
  // chBegin never returns, main thread continues with mainThread()
  while(1) {}
// main thread runs at NORMALPRIO
void mainThread() {
  // start blink thread
  chThdCreateStatic(waThread1, sizeof(waThread1),
                          NORMALPRIO + 2, Thread1, NULL);
  // start print thread
  chThdCreateStatic(waThread2, sizeof(waThread2),
                          NORMALPRIO + 1, Thread2, NULL);
 // not used
Here is output from the sketch.  Note the data is never older than 10 milliseconds.
dataAge: 4 ms, dataX: 0, dataY: 1, dataZ: 100
dataAge: 8 ms, dataX: -1, dataY: 1, dataZ: 99
dataAge: 3 ms, dataX: 4, dataY: -13, dataZ: 104
dataAge: 7 ms, dataX: 83, dataY: -5, dataZ: 183
dataAge: 2 ms, dataX: 90, dataY: -54, dataZ: 190
dataAge: 6 ms, dataX: 19, dataY: 65, dataZ: 119
dataAge: 1 ms, dataX: 112, dataY: 93, dataZ: 212
« Last Edit: February 05, 2013, 05:50:39 am by fat16lib » Logged
Long Island, NY
I did make that shared variable volatile and during use by a thread. I as able to execute the script correctly buy running it on an arduino with no servos attached, unfortunately I don't think it was a code issue but a power supply issue as the "ping" sensor itself was not lighting fully with the servos on but with them disabled I had no problems.
Long Island, NY
This was my final code:
#include <Servo.h>
MUTEX_DECL(lockMutex);
#define EnableServo 13
#define BuzzerPin 4
#define ButtonPin 2
#define Red 3
#define Green 5
#define Blue 6
Servo Lleg;  // create servo object to control a servo
Servo Rleg;
Servo Lfoot;
Servo Rfoot;
Servo Neck;
#define BuzzerPin 4
#define ButtonPin 2
#define Red 3
#define Green 5
#define Blue 6
Servo Rleg;
Servo Lfoot;
Servo Rfoot;
Servo Neck;
int RFcenter = 80;    // variables to store the center servo positions
int LLcenter = 80;
int RLcenter = 80;
int LFcenter = 80;
int Neckcenter = 90;
// Setup variables to store sensor readings
int obstacleDistance = 0;
int obstacleLeft = 0;
int obstacleCenter = 0;
int obstacleRight = 0;
int presentDistance = 0;
// declare reaction distances on object preception
int obstacleAhead = 20;
int obstacleWarning = 10;
int obstacleAlert = 8;
// declare angle values for walking
int tAngle = 25; //tilt angle
int uAngle = 35; //turn angle
int sAngle = 30; //swing angle
int neckAngle = 30; //angle for meck turn
const int pingPin = 12; // define sensor pin
// remember thread pointers
Thread* tp1;
Thread* tp2;
// thread 1 - high priority for walking motion
// 200 byte stack beyond task switch and interrupt needs
static WORKING_AREA(waThread1, 200);
  while (TRUE) {
  WalkDirection();
// thread 2 - scan for obstacles as walking
static WORKING_AREA(waThread2, 200);
  while (TRUE) {
    ScanObstacle();
  // end task
  // initialize serial communication:
  Serial.begin(19200);
  // read any input
  delay(200);
  Lleg.attach(7);  // attaches the servo on pin x to the servo object
  Rleg.attach(10);  // attaches the servo on pin x to the servo object
  Lfoot.attach(8);  // attaches the servo on pin x to the servo object
  Rfoot.attach(9);  // attaches the servo on pin x to the servo object
  Neck.attach(11);  // attaches the servo on pin x to the servo object
  pinMode(EnableServo,OUTPUT);
  digitalWrite(EnableServo,HIGH); //this turns on the power to the servos
  CenterServos(); //center the servos
  digitalWrite(EnableServo,LOW); //turn power off after centering
  pinMode(Red, OUTPUT);
  digitalWrite(Red, LOW);
  pinMode(Blue, OUTPUT);
  digitalWrite(Blue, LOW);
  pinMode(Green, OUTPUT);
  digitalWrite(Green, LOW);
    pinMode(BuzzerPin, OUTPUT);
  digitalWrite(BuzzerPin, LOW);
  //Buzzer.PlayMelody();
  pinMode(ButtonPin, INPUT);
  digitalWrite(ButtonPin, HIGH); //pull up activated
  Serial.print("Ready... ");
  // shouldn't return
  while(1) {}
void mainThread() {
  // start walk thread
  tp1 = chThdCreateStatic(waThread1, sizeof(waThread1),
  // start object scan thread
  tp2 = chThdCreateStatic(waThread2, sizeof(waThread2),
                          NORMALPRIO + 2, Thread2, NULL);
 // not used
void CheckDistance(){
    // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  chThdSleepMilliseconds(2);
  digitalWrite(pingPin, HIGH);
  chThdSleepMilliseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  chThdSleepMilliseconds(10);
  cm = microsecondsToCentimeters(duration);
  obstacleDistance = cm;
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
void ScanObstacle(){
  Neck.write(Neckcenter);
  chThdSleepMilliseconds(100);
  CheckDistance();
  if (obstacleDistance > obstacleAhead){ //no obstacle nearby
    chMtxLock(&lockMutex);
    Obstacle=0;
    chMtxUnlock();
    Serial.print(obstacleDistance);
    Serial.print("cm center over 20");
    Serial.println();
  if (obstacleDistance <= obstacleAhead){ //check sensor
    BuzzerBeep();
  digitalWrite(Red, HIGH);
  CheckDistance();
  obstacleCenter = obstacleDistance;
  Serial.print(obstacleCenter);
  Serial.print("cm center");
  Serial.println();
  Neck.write(Neckcenter+neckAngle); //turn head left
  chThdSleepMilliseconds(200);
  digitalWrite(Green, HIGH);
  CheckDistance();
  obstacleLeft = obstacleDistance;
  Serial.print(obstacleLeft);
  Serial.print("cm left");
  Serial.println();
  Neck.write(Neckcenter-neckAngle); //turn head right
  digitalWrite(Blue, HIGH);
  CheckDistance();
  obstacleRight = obstacleDistance;
  Serial.print(obstacleRight);
  Serial.print("cm right");
  Serial.println();
  if ((obstacleLeft <= obstacleAhead) && (obstacleRight >= obstacleLeft)){
    Obstacle=1;
    if ((obstacleRight <= obstacleAhead) && (obstacleLeft >= obstacleRight)){
      Obstacle=2;
      if (((obstacleLeft <= obstacleAhead && obstacleRight <= obstacleAhead && obstacleCenter <= obstacleAhead) && (obstacleCenter == obstacleLeft && obstacleCenter == obstacleRight)) || (obstacleLeft <= obstacleWarning && obstacleRight <= obstacleWarning && obstacleCenter <= obstacleWarning)){
      Obstacle=3;
      if ((obstacleLeft <= obstacleAlert) || (obstacleRight <= obstacleAlert) || (obstacleCenter <= obstacleAlert)) {
      Obstacle=4;
  chMtxUnlock();
void WalkDirection(){
  int walkToggle = Obstacle;
  chMtxUnlock();
  Serial.print(walkToggle);
  Serial.print(" Case");
  Serial.println();
  switch (walkToggle){
    case 0: //no object
      Forward(1,30); //one step Forward
      break;
    case 1: //object on Left
      TurnRight(2,30);
      break;
    case 2: //object on Right
      TurnLeft(2,30);
      break;
    case 3: //obect in Front (both Left and Right detect the object)
      TurnLeft(4,30); //turn around
      break;
    case 4: //obect in Front (both Left and Right detect the object)
      Reverse(2,30); //turn around
      break;
However the serial output and actions of the robot always reflect case 4 (0cm, 0cm, 0cm)
If I power it with 9V and USB some of those readings come back with a value.
Long Island, NY
Something like this running three threads including the scan thread works fine, plus I see that the ping is powered.
#include <Servo.h>
MUTEX_DECL(serialMutex);
#define BuzzerPin 4
#define ButtonPin 2
#define Red 3
#define Green 5
#define Blue 6
Servo Rleg;
Servo Lfoot;
Servo Rfoot;
Servo Neck;
int LLcenter = 80;
int RLcenter = 80;
int LFcenter = 80;
//Setup Variable to Store Switch Value
volatile int Obstacle=0;
//Non volatile int to limit time with no interrupt
int walkToggle = 0;
int uAngle = 30; //turn angle
// pin to trigger interrupt
const uint8_t LED_PIN = 6;
volatile uint32_t count = 0;
Thread* tp1;
Thread* tp2;
Thread* tp3;
// thread 1 - high priority for blinking LED
  pinMode(LED_PIN, OUTPUT);
  while (!chThdShouldTerminate()) {
    digitalWrite(LED_PIN, HIGH);
    chThdSleepMilliseconds(50);
    digitalWrite(LED_PIN, LOW);
    chThdSleepMilliseconds(150);
  return 0;
  Serial.println("Type any character for stack use");
  while (!Serial.available()) {
    Serial.println(count);
    count = 0;
    chThdSleepMilliseconds(1000);
  // Terminate the LED thread
  chThdTerminate(tp1);
  // print memory use
  Serial.println();
  Serial.println("Memory use");
  Serial.println("Area,Size,Unused");
  Serial.print("Thread 1,");
  // size of stack for thread 1
  Serial.print(sizeof(waThread1) - sizeof(Thread));
  Serial.write(',');
  // unused stack for thread 1
  Serial.println(chUnusedStack(waThread1, sizeof(waThread1)));
  Serial.print("Thread 2,");
  // size of stack for thread 2
  Serial.print(sizeof(waThread2) - sizeof(Thread));
  Serial.write(',');
  // unused stack for thread 2
  Serial.println(chUnusedStack(waThread2, sizeof(waThread2)));
  // print stats for heap/main thread area
  Serial.print("Heap/Main,");
  Serial.print(chHeapMainSize());
  Serial.print(",");
  Serial.println(chUnusedHeapMain());
  // end task
  return 0;
// thread 3 - high priority for blinking LED
static WORKING_AREA(waThread3, 200);
static msg_t Thread3(void *arg) {
while (TRUE){
  ScanObstacle();
  while (!Serial) {}
  // read any input
  delay(200);
  delay(100);
  while(1) {}
void mainThread() {
  tp3 = chThdCreateStatic(waThread3, sizeof(waThread3),
                          NORMALPRIO + 1, Thread3, NULL);
  // increment counter
  while (1) {
    noInterrupts();
    count++;
    interrupts();
 // not used
Long Island, NY
  CheckDistance();
  if (obstacleDistance > 20){ //no obstacle nearby
    Obstacle=0;
    chMtxLock(&serialMutex);
    Serial.println();
    chMtxUnlock();
  if (obstacleDistance <= 20){ //check sensor
    BuzzerBeep();
  CheckDistance();
  Neck.write(Neckcenter+30); //turn head left
  CheckDistance();
  Neck.write(Neckcenter-30); //turn head right
  CheckDistance();
    Obstacle=1;
      Obstacle=2;
      Obstacle=3;
      Obstacle=4;
  Serial.println();
  Serial.println();
  Serial.println();
  Serial.print(Obstacle);
  Serial.println();
  Serial.write(',');
  Serial.write(',');
    Serial.print("Thread 3,");
  // size of stack for thread 3
  Serial.print(sizeof(waThread3) - sizeof(Thread));
  Serial.write(',');
  // unused stack for thread 3
  Serial.println(chUnusedStack(waThread3, sizeof(waThread3)));
  Serial.print(",");
  // end task
  chMtxUnlock();
  long duration, cm;
  noInterrupts();
  Serial.println();
  interrupts();
    case 0: //no object
      break;
      TurnRight(2,30);
      break;
      TurnLeft(2,30);
      break;
      break;
      break;
Long Island, NY
So I guess I was scratching my head for 15 hours because I need a second power source for the servos...
6 servos, 2 RGB lights an Arduino Micro and a Ping Sensor cant run on one 9v 170mAh battery, plus I learned the ins and outs of ChibiOS
 smiley-roll-sweat
 smiley
Thanks for the help
Long Island, NY
My serial output with the battery and USB hooked up looks like this:
24cm center
22cm left
0cm right
4 Case
28cm center
29cm left
0cm right
4 Case
43cm center
62cm left
39cm right
6cm center
4 Case
0cm left
39cm right
4 Case
38cm center
16cm left
0cm right
4 Case
40cm center
0cm left
41cm right
80cm center over 20
59cm center over 20
42cm center over 20
40cm center over 20
0 Case
0 Case
0cm center
4cm left
69cm right
4 Case
0cm center
244cm left
70cm right
4 Case
220cm center
245cm left
69cm right
79cm center
246cm left
69cm right
210cm center over 20
0 Case
22cm center
246cm left
63cm right
0 Case
0 Case
It's still missing some sensor readings, although not all the time. Maybe i need to use a semaphore to get the two processes synchronized? I was moving the bot around during that to get different readings and the reported distances are accurate.
Rapa Nui
Pukao hats cleaning services
Or it could also be that while my 9v 170mAh rechargeable is providing enough current to drive 1 servo and the ping, 5 servos or 6 servos (and 2 RGB LEDs... It is not providing enough current to run 6 servos, the ping and 2RGB LEDs concurrently
You can hardly use that battery for running that stuff.. The above battery is intended for powering systems with 20mA current consumption. A single servo can take 500mA or more when acting.
Better you use for example a 7.4V li-poly rechargeable battery pack..  smiley
« Last Edit: February 05, 2013, 09:05:03 am by pito » Logged
Long Island, NY
What about a 9v li-po rechargable at 500mAh?
Rapa Nui
500mAh - that is the capacity (C). The Q is how much current it can deliver (in a much shorter time of course).
Li-po batteries can do 1C up to 60C current (C=capacity) afaik, based on type etc. If the li-po pack is 500mAh and for example its C=10, it can deliver ~5A for ~6minutes..
« Last Edit: February 06, 2013, 06:12:20 pm by pito » Logged
Long Island, NY
I am using 9 gram HTX900 servos which at peak have 1.6kg of torque but at no time are they lifting more then 350 grams so I doubt they are using the 500 mA each, I know that wiring lithium batteries in parallel is supposed to be a no-no smiley
I know we are off topic for software now!
This thing was previously running on a single nickel rechargeable 170mAh and I think that is why with 5 servos and the sensor reading were fine but with servo six things got inconsistent because it could not supply the current even at full charge.
Pages: 1 [2]   Go Up
