Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: Arduino, and Mechanical Movement of Objects - a Newbie Question  (Read 960 times)
Washington, PA
Offline Offline
Newbie
A job worth doing is worth doing right
View Profile
You folks are awesome-fantastic-brilliant-and-generous! Thanks for all these ideas. The one I think is most elegant is also probably the lease accessible to me, that being the rod with spiraling, machined grooves. In addition to finding someone to do the machining at a price I could afford, that one poses another thing to figure out. Splitting even one ball of yarn creates a couple of grams of lint. Lint, and grease don't play well together; they make a sticky mess.
I'm leaning toward some variation of the threaded rod. Parts are cheap, and ubiquitous, If I mess up, or make some revision, I'll still have more to have at it again. The threaded rod  presents the same grease/lint issue, and I haven't resolved that.
I don't know if you noticed, but in the video, there's a dangling gadget that looks like a toilet paper holder holding a ball of yarn, and it's rotating. It rotates to remove some varying amount of twist in the yarn, but I've been stopping to spin it manually every 15 or 20 seconds. There's now a little 12v. DC motor up there. One problem is that I need a 4" or larger pulley above the yarn ball holder, but I'm wondering if there's a way to edit the sketch so that I can adjust it as needed more easily than I can now. It seems to reach maximum RPMs well before the potentiometer reaches it's extreme. That sketch follows.
Code:
#include <EEPROM.h>
// Maurice Ribble
// 2-4-2010
// http://www.glacialwanderer.com/hobbyrobotics
// Open Source, licensed under a Creative Commons Attribution 3.0 License (http://creativecommons.org/licenses/by-sa/3.0/)
// Compiled with Arduino Software 0017 (http://arduino.cc)
// This program reads an input potentiometer and uses that value to set a motor controller's direction and speed.
// REVISIONS:
// Initial Version
// Frequency for updating motor
#define UPDATE_HZ   100
// Define digital/analog pins
#define BUTTON_PIN        2
#define MOTOR_ENABLE_PIN  3
#define MOTOR_IN1_PIN     4
#define MOTOR_IN2_PIN     5
#define DIAL_APIN         0
// Positions that different data is stored in eeprom
#define EEPROM_DIAL_LOW  0
#define EEPROM_DIAL_MID  1
#define EEPROM_DIAL_HIGH 2
enum { BUTTON_PRESSED=0, BUTTON_NOT_PRESSED=1 };
// Globals
unsigned long g_dialLow;
unsigned long g_dialMid;
unsigned long g_dialHigh;
  int button;
  //Serial.begin(9600); // open hw serial for debugging
  pinMode(BUTTON_PIN, INPUT);
  pinMode(MOTOR_ENABLE_PIN, OUTPUT);
  pinMode(MOTOR_IN1_PIN, OUTPUT);
  pinMode(MOTOR_IN2_PIN, OUTPUT);
  // Default values
  digitalWrite(MOTOR_ENABLE_PIN, LOW);
  digitalWrite(MOTOR_IN1_PIN, LOW);
  digitalWrite(MOTOR_IN2_PIN, LOW);
  button = digitalRead(BUTTON_PIN);
  // If the button is pressed during startup enter a special mode to set the min, max and mid dial readings
  // Should only need to do this once (unless you change the the potentiometer is changed)
  if (button == BUTTON_PRESSED)
    waitTillAllButtonsReleased();                   // debounce
    g_dialLow = analogRead(DIAL_APIN);              // save low speed position
    button = digitalRead(BUTTON_PIN);               // wait for button to be pressed again
    while(button == BUTTON_NOT_PRESSED)
    g_dialHigh = analogRead(DIAL_APIN);             // save high speed position
    g_dialMid = analogRead(DIAL_APIN);              // save middle speed position
    eepromWriteInt(EEPROM_DIAL_LOW, g_dialLow);    // save dial position references to eeprom
    eepromWriteInt(EEPROM_DIAL_MID, g_dialMid);
    eepromWriteInt(EEPROM_DIAL_HIGH, g_dialHigh);
    g_dialLow  = eepromReadInt(EEPROM_DIAL_LOW, 0, 1023);  // read dial position references from eeprom
    g_dialMid  = eepromReadInt(EEPROM_DIAL_MID, 0, 1023);
    g_dialHigh = eepromReadInt(EEPROM_DIAL_HIGH, 0, 1023);
  unsigned long dialVal = analogRead(DIAL_APIN);
  long percentOn;
  unsigned long usTotal = 0;
  unsigned long usOn = 0;
  unsigned long usOff = 0;
  int forward;
  if (g_dialHigh > g_dialLow)
    if (dialVal >= g_dialMid)
      forward = 0;
      percentOn = 100*(dialVal-g_dialMid)/(g_dialHigh-g_dialMid);
      forward = 1;
      percentOn = 100*(g_dialMid-dialVal)/(g_dialMid-g_dialLow);
  else // g_dialHigh < g_dialLow
    if (dialVal <= g_dialMid)
      forward = 0;
      percentOn = 100*(g_dialMid-dialVal)/(g_dialMid-g_dialHigh);
      forward = 1;
      percentOn = 100*(dialVal-g_dialMid)/(g_dialLow-g_dialMid);
  if (percentOn <= 5)  // Turn motors off when they are close to off
    percentOn = 0;
  else if (percentOn >= 95)  // Turn motors full on when they are close to full on
    percentOn = 100;
  usTotal = 1000000/UPDATE_HZ;
  usOn = usTotal*percentOn/100;
  usOff = usTotal - usOn;
  if (forward)
    digitalWrite(MOTOR_IN1_PIN, HIGH);
    digitalWrite(MOTOR_IN2_PIN, HIGH);
  if (usOn)
    unsigned int msOn = usOn/1000;
    usOn %= 1000;
    digitalWrite(MOTOR_ENABLE_PIN, HIGH);
    if (msOn)
      delay(msOn);
    if (usOn)
      delayMicroseconds(usOn);
  if (usOff)
    unsigned int msOff = usOff/1000;
    usOff %=1000;
    if (msOff)
      delay(msOff);
    if (usOff)
      delayMicroseconds(usOff);
// Helper functions
// Writes an integer to eeprom
void eepromWriteInt(int addr, int val)
  addr *= 2;  // int is 2 bytes
  EEPROM.write(addr+1, val&0xFF);
  val /= 256;
  EEPROM.write(addr+0, val&0xFF);
// Reads an integer from eeprom
int eepromReadInt(int addr, int minVal, int maxVal)
  int val;
  val = EEPROM.read(addr+0);
  val *= 256;
  val |= EEPROM.read(addr+1);
  val = constrain(val, minVal, maxVal);
  return val;
// Wait for all the current button presses to end (handles debouncing buttons)
void waitTillAllButtonsReleased()
  while(1)
    int i;
    int button;
    // Need to sample many times to makes sure the button isn't currently bouncing
    for(i=0; i<100; ++i)
      delayMicroseconds(10);
    if (button == BUTTON_NOT_PRESSED)
I've harvested a lot of plastic gears, several stepper motors, and other cool toys. There has been discussion about a lever toggling the direction of rotation of the shaft that will move the "hooks". Right now, I'm imagining something that will be better illustrated than described with words. I'll post that sometime this afternoon.
You all gave me so much food for thought. I am very grateful.
Logged
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
