Topic: problem coding 2 ping sensors with an l2C LCD (Read 1 time) previous topic - next topic
Hamoud005
hello everyone
am doing a small project using 2 ping sensors & L2C LCD
so far i was able to make one sensor to work fine with LCD
here is the code for it
Code: [Select]
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR    0x27 // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN  3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
const int pingPin = 8;
int n = 1;
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
  lcd.begin(20, 4); //  <<----- My LCD was 20x4
  lcd.print(pingPin, OUTPUT);
  lcd.print(pingPin, INPUT);
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.home (); // go home
  int duration, distance, cm;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH); //Time pulse in
  distance = (duration/2) / 29.1; //Convert time to Cm
  if (distance >= 90 || distance <= 0){
    lcd.clear();
    lcd.setCursor(2,0);
    lcd.print("Out of Range");
  else {
    lcd.clear();
    lcd.setCursor(2,0); //Print to screen
    lcd.print(distance);
    lcd.setCursor(5,0);
    lcd.print(" Cm");
  delay(300);
i tried to use another code that can use 2 ping sensors
i can see the result in the Serial Monitor
but couldn't show it on the LCD screen
Code: [Select]
#include <Wire.h>
#include <LCD.h>
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
int ultraSoundSignalPins[] = {8,9}; // X, Y Ultrasound signal pins
char *pingString[] = {"X= ","Y= "}; // just something to print to indicate direction
int n = 1;
  unsigned long ultrasoundValue;
  for(int i=0; i < 2; i++)
    ultrasoundValue = ping(i);
    Serial.print(pingString[i]);
    Serial.print(ultrasoundValue);
    Serial.print("cm, ");
    delay(100);
  delay(300);
//Ping function
unsigned long ping(int i)
  unsigned long echo;
  pinMode(ultraSoundSignalPins[i], OUTPUT); // Switch signalpin to output
  digitalWrite(ultraSoundSignalPins[i], LOW); // Send low pulse
  delayMicroseconds(2); // Wait for 2 microseconds
  digitalWrite(ultraSoundSignalPins[i], HIGH); // Send high pulse
  delayMicroseconds(5); // Wait for 5 microseconds
  digitalWrite(ultraSoundSignalPins[i], LOW); // Holdoff
  pinMode(ultraSoundSignalPins[i], INPUT); // Switch signalpin to input
  digitalWrite(ultraSoundSignalPins[i], HIGH); // Turn on pullup resistor
  echo = pulseIn(ultraSoundSignalPins[i], HIGH); //Listen for echo
  return (echo / 2) / 29.1; //convert time to CM
  if (echo >= 90 || echo <= 0){
    lcd.clear();
    lcd.setCursor(2,0);
  else {
    lcd.clear();
    lcd.print(echo);
    lcd.setCursor(5,0);
    lcd.print(" Cm");
can you guys help me please :(
UKHeliBob
You are returning from your ping() function before it gets a chance to display the distance on the LCD.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Hamoud005
ok i mad the return code the last thing in the program
Code: [Select]
  echo = (echo / 2) / 29.1; //convert time to CM
    lcd.clear();
    lcd.setCursor(2,0);
  else {
    lcd.clear();
    lcd.print(echo);
    lcd.setCursor(5,0);
    lcd.print(" Cm");
  delay(300);
but now it shows the two distance in the same line
how can i separate them to make them shows on line 1 & line 2 ??
lar3ry
You could check the parameter you pass to ping(), and change the line number in the setCursor() call accordingly.
Hamoud005
am sorry am not that good with coding & technical words
can you explain it more or show me what you mean
UKHeliBob
In your ping() function change the second value in lcd.setCursor() to i
Hamoud005
ok thanks for the help
i was able to show them both in different line now
Code: [Select]
#include <Wire.h>
#include <LCD.h>
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
int n = 1;
    delay(100);
  delay(300);
//Ping function
  unsigned long echo;
  if (echo >= 200 || echo <= 0){
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("X=");
    lcd.setCursor(0,1);
    lcd.print("Y=");
    lcd.setCursor(3,0);
  else {
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("X=");
    lcd.setCursor(0,1);
    lcd.print("Y=");
    lcd.setCursor(3,i); //Print to screen
    lcd.print(echo);
    lcd.setCursor(6,i);
    lcd.print(" Cm");
    delay (300);
  //return (echo / 2) / 29.1; //convert time to CM
  delay(300);
but they still alternate between them instead of showing both at the same time
is it because the sensor was set as "i" instead of 2 different function ?
lar3ry
It's because you only ping one sensor within the ping() function, then you clear the lcd screen, and print the result to it. When you ping the second sensor, the lcd.clear erases the first reading.
You might want to try separating the ping from the display. So, the code would be something like:
ping first sensor. save distance
ping second sensor. save distance
display both sensors
The first two lines be done in a single function, called twice, one for each sensor. Basically, everything you do now in ping(), up to where you store the distance. Just move the declaration of echo out of the function, making it global. Again, make echo a two-element array.
display can be one function, called once, which will simply display both echo values.
