Author Topic: Byte array - 2D  (Read 167 times)
Good Morning,
I've:
byte array [30] [12] = {
   //as many vals as dim1
  {0,0,0},
  {0,0,0}//as many rows as dim0
and I would like feel up it reading my eeprom address ...
where the record0 is from 0-12 the record1 is from 13-26, the record2 is from 27-39 until the record 31 ...
so now for fill up a record for 1 dimensional array should be like this:
byte memoria[416];
void LeggiEeprom()
  int ind;
   for (ind =0; ind <= 416 ; ind++)
        // memoria[ind] = EEPROM.read(ind);
        memoria[ind] = readEEPROM(disk1, ind);
how could I fill the bi dimensional array ?
Could you help kindly ?
thanks,
gnux
East Anglia (UK)
May all of your blinks be without delay
To fill a 2 dimensional array you need 2 nested loops
for (int row = 0;row <= 29;row++)
  for (int column = 0;column <= 11;column++)
    array[column][row] = whatever you want in this position
Where is the data coming from for the array ?
HI Bob,
thanks for the idea ... I've did something like that :
#define disk1 0x50    //Address of 24LC256 eeprom chip
#include <Wire.h>
  {0,0,0},
byte readEEPROM(int deviceaddress, unsigned int eeaddress )
  byte rdata = 0xFF;
  Wire.beginTransmission(deviceaddress);
  Wire.write((int)(eeaddress >> 8));   // MSB
  Wire.write((int)(eeaddress & 0xFF)); // LSB
  Wire.endTransmission();
  Wire.requestFrom(deviceaddress,1);
  if (Wire.available()) rdata = Wire.read();
  return rdata;
void writeEEPROM(int deviceaddress, unsigned int eeaddress, byte data )
  Wire.write(data);
  delay(5);
  int n,m,z,k,l,i,c;
  n = 416;
  k = 0;
  z = 0;
  for (i =0; i >= n ; i = i +13)
        m = k * 13;
        c = 0;
        for ( l = m ; l > (m + 13); l++)
               array[k][c] = readEEPROM(disk1, l);
               c = c + 1;
       k = k + 1;
void  loop()
delay(4000);
I think could be fine, what do you think ?
thanks gnux
UK
Online Online
n = 416;
That's going to be a short loop.
East Anglia (UK)
I think it look very complicated just to fill up a 2 dim array.
How many rows of data are there ?
How many columns are there in each row ?
Your array dimensions allow for 30 rows of 12 values.  Is that right ?
Do you want to fill up each row then move on to the next row or fill up each column then move on to the next column ?
