Topic: Display 2 Different Images On 2 Different OLEDs Using 1 Board (Read 792 times) previous topic - next topic
Artie
I am wondering if anyone knows how to put two different images on two separate OLEDs (both the same models) through an I2C bus using a single Arduino MEGA ADK board. Thank you.
tack
You need the OLEDs on separate I2C addresses and then just create two instances, with correct constructors/address declaration, for the displays and write to them accordingly.
Artie
Thank you for your advice. But is there a way to change the address on one of the OLEDs. The two OLEDs are the same model and attached to one board. Again, thank you for your help.
