Topic: Monitoring Serial Port in Perl without using 100% CPU (Read 997 times) previous topic - next topic
redcliffe
I've implemented a Perl script using this page as a template: http://playground.arduino.cc/interfacing/PERL
The while(1) loop uses 100% of the CPU power available. Is there a way to do this without using so much processor load? In my case the Arduino spits out a line of telemetry once per second. The perl script reads this and inserts it into a db. Any suggestions about better ways to do this? Thanks,
David
robtillaart
put in a sleep of a few (10) milliseconds as the hardware will buffer several characters anyway ?
#include "all disclaimers"
Rob Tillaart
PaulS
What operating system allows spaces in file names?
zoomkat
Consider the daffodil. And while you're doing that, I'll be over here, looking through your stuff.   8)
afremont
Try using "select" to wait for data with a timeout.  I think it's in IO::select.pm or something like that.
Experience, it's what you get when you were expecting something else.
redcliffe
Thanks, sleeping fixed it up. Seemed silly that such simple code would chew so much. Thanks,
David
robtillaart
almost all?
and yes spaces are mainly for us mere mortals to help our associative brain ;)
and yes they cause a lot of trouble (almost daily! )
Rob Tillaart
