Topic: Devide 12v square wave signal and output 5v squarewave (Read 9953 times) previous topic - next topic
Retroplayer
I've just googled optocoupler and it looks that it could be a good idea, I assume these a fast enough?
That depends on the one you select. Most I have looked at would be fast enough. Just translate your PPS to BPS in the datasheets.
Jimster
Pylon, thanks for all your input.
The following formula moves your floats to integers (better uint32_t, precision: 3 digits behind the point):
square_out = square_in * 201UL / 1138UL ; // case ratio1
square_out = square_in * 420 / 1777; // case ratio2
Where would I add this code, in the main void loop?
so by adding that code, I could set all my variables to integers? What role does the "UL" have?
Is this the correct implimentation?
Read square wave speed signal in on pin2 and output squarewave speed on pin4
volatile uint32_t lastPulseTime = 0;
volatile uint32_t lastPulseWidth = 0;
const int speed_pin = 2; //sqaure wave input from speed source
const int gear_pin = 3;     //gear select input
const int speed_out = 4; //sqaure wave output
// variables for calculation
const int ratio1 = 1/ 2.315;
const int ratio2 = 1/ 1.731;
const int FD = 1 / 4.7;
const int idler = 1.04;
const int pulses = 4; //pulses per simultated revolution
int square_in; //speed received
int square_out; //speed to send
int gear; // current gear selected
// the setup routine runs once when you press reset:
uint32_t lastEdge = 0;
byte state = 0;
 // initialize the digital pin as an output.
 pinMode(speed_pin, INPUT);
 pinMode(speed_out, OUTPUT);
 pinMode(gear_pin, INPUT);
 attachInterrupt(0, registerPulse, RISING);
// the loop routine runs over and over again forever:
 //Sample data to test
 square_in = 1000000UL / lastPulseWidth;
read the square wave speed input from "speed_in" into variable "sqaure_in"
 gear = digitalRead(gear_pin);
 if (gear == HIGH) {        //ratio1 is selected
   square_out = square_in / 2 * ratio1 / idler * FD * pulses;
 }//end of ratio1
 else{        //ratio2 is selected
   square_out = square_in / 2 * ratio2 / idler * FD * pulses;
 }//end of ratio2
 //output the variable "square_out" as square wave to "Speed_out"
    uint32_t outPulse = 500000UL / square_out; // get pulse length (not wave length)
 uint32_t m = micros();
 if (m - lastEdge >= outPulse) {
   state = ! state;
   digitalWrite(speed_out, state);
   lastEdge = m;
void registerPulse() {
 uint32_t cur = micros();
 lastPulseWidth = cur - lastPulseTime;
 lastPulseTime = cur;
Jimster
I have just found out some more info on the sqaurewave speed output from the ECU. The signal is 50% duty so the pulse length is determined by the frequency.The ECU updates the tachometer output every 50mS.
I'm hoping to read the signal in quicker than every 50ms to make sure that I'm not losing data.
I understand that the UNO is 16MHz, but how fast does that mean it could read and ouput data using my code?
pylon
That code has to go into your ratio selector if statement like this:
    square_out = square_in * 201UL / 1138UL;
  }//end of ratio1
    square_out = square_in * 420UL / 1777UL;
  }//end of ratio2
Yes, you now have to define your variables this way:
uint32_t square_in = 0;
uint32_t square_out = 0;
The UL hints the compiler that it should recognize the given integer constants as "unsigned long", meaning 32bit positive integers.
Jimster
Ahh right,
So in this line of code
where did the numbers 201 abd 1138 come from?
pylon
Your calculation
is the same as (constants replaced)
square_out = square_in / 2 / 2.315 / 1.04 / 4.7 * 4;
which is the same as (constants pre-calculated)
square_out = square_in * 0.176745271;
and 201 / 1138 = 0.176625659, which is the same factor with a precision of 3 digits after the point.
Jimster
Very clever, mathimatically, how did you get to those numbers?
It's not just electronics and c I need to learn
pylon
Take an estimate and approximate till you have the desired precision.
Jimster
I've updated the code:
uint32_t square_in = 0; //speed received
uint32_t square_out = 0; //speed to send
byte state = 0;
  }//end of ratio1
  }//end of ratio2
    state = ! state;
    lastEdge = m;
Does this look right? is there anything which could be done more affectively?
pylon
You can eliminate the change from wave length to frequencies and back:
  uint32_t outPulse;
    outPulse = lastPulseWidth * 1138UL / 201UL;
  } else {        //ratio2 is selected
    outPulse = lastPulseWidth * 1777UL / 420UL;
    state = ! state;
    lastEdge = m;
The next step is to do the calculation only if one of the input values have changed:
uint32_t savedPulseWidth = 0;
byte savedGear = LOW;
  uint32_t outPulse;
  if (gear != savedGear || lastPulseWidth != savedPulseWidth) {
    savedGear = gear;
    savedPulseWidth = lastPulseWidth;
    state = ! state;
    lastEdge = m;
Jimster
Thanks for that, I plan to have my test rig compleated this week to test this on, thanks again for your massive help  :D XD
