Topic: [FIXED][CapacitiveSensor] Can't compile with Due (port manipulation) (Read 3010 times) previous topic - next topic
Liarco
I'm using the CapacitiveSensor library from here: http://playground.arduino.cc//Main/CapacitiveSensor
It works great with my Leonardo (AVR), but it can't compile with Due and here are the errors explained:
  • portOutputRegister(PIN) and portInputRegister(PIN) were returning a uint8_t and now they return RwReg.
  • portModeRegister(PIN) isn't available on the Due. (Arduino.h code is commented out)
Now my question is:
I changed the uint8_t registers to RwReg (compiler doesn't complain) and I replaced the use of portModeRegister(PIN) with simple pinMode(PIN, MODE) calls (it's slower but it works).
  • Do the RwReg need to be handled in a different way? (the code works but I'm not an expert)
  • Is there a faster way than using pinMode(PIN, MODE) on Due?
  • Should I care about clock cycles since the old arduino was 16MHz and Due is 84MHz? :P
I'm waiting some feedback, then I'm going to rewrite the whole code to be Due-compatible and release a patch.
Liarco
I finally released my own version of this library and it works on Arduino Due. XD
I made a pull request to the only repository that I found about this library: https://github.com/arduino-libraries/CapacitiveSensor/pull/1
I hope that someone can optimize it because I'm just a beginner with Arduino. :smiley-red:
