Topic: Compare Dates - Times (Read 4461 times) previous topic - next topic
marco_c
One other thing I forgot to mention is that you should be careful not to just check if they are equal but check if the current time is >= the set time, because being just one second out will void the equality condition.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
gnusso
Ok, then for do that how I can do ?
What I've understand is that I'm not comparing to datatime type but the fact 2 array char....
So in vb it's simple to do, but i c++ I've to find the way for do that ...
so if you have an example of compare date time i think could be more clear for understand what there is behind i think.
thanks gnux
marco_c
Strcmp() returns different values depending on whether the strings are equal, greater than or less than.
gnusso
yes but In my case i think that is correct if are equal ...
so, from you your point of view how do you'll implement it ?
Thanks
gnux
marco_c
If in your case equal is correct then implement it the way you think it should be.
gnusso
Ciao Marco,
Looking the documentation about the sprintf
http://linux.die.net/man/3/sprintf
I don't understand one thing: so into my array I've byte ...with the function below reported will build my string that after will be compared.
but if for example into hour there is "9" the function for example for the hour take 2 digits will take 9 or 09 ? because my string lentgh will be different if i not understood bad ... than i need to check also if the hour > 9 take hour if hour < 9 take 0+hour 09 ... is correct ?
char s[15];
sprintf(s, "%04d%02d%02d%02d%02d%02d", year, month, day, hour, minute, second);
thanks
gnux
marco_c
%02d puts the leading zero in for you.  What you need to do is make sure the time is in 24 hour format so that 1 am is 01 and 1 pm is 13. The string will always be the same length.
gnusso
yes for sure the time is 24 format ... I will try then I'll let you know ...
Thanks,
gnux
gnusso
Ciao Marco,
so I've did this simple sketch could be a good starting point:
#include <Time.h>
char s[15];
char s1[15];
byte y1,mon1,d1,h1,min1,sec1;
void setup(){
  setTime(9,25,00,6,2,13);
  y1 = 13;
  mon1 = 2;
  d1 = 6;
  h1 = 9;
  min1 = 25;
  sec1 = 01;
void loop(){
  time_t t = now();
  sprintf(s, "%04d%02d%02d%02d%02d%02d", year(t), month(t), day(t), hour(t), minute(t), second(t));
  sprintf(s1, "%04d%02d%02d%02d%02d%02d", (y1+2000), mon1, d1, h1, min1, sec1);
  // Debug
  Serial.println("Stampo S ");
  Serial.println(s);
  Serial.println("Stampo S1 ");
  Serial.println(s1);
  if (strcmp(s,s1) == 0)
      Serial.println("Condition Verified");
so now just to think about the structure how use it ?
do you think that could be fine ?
thanks
gnux
Jimmy60
As you are using seconds your comparison will only be true for one second. If your sketch is doing other things it could miss. However to change to one minute resolution just drop seconds from your strings. Then they will be equal within one minute. Drop the minutes for one hour resolution.
If you really need one second resolution then Unix time might be a better solution.
