Topic: Question about the analog input of "Arduino mega 2560 " (Read 2049 times) previous topic - next topic
class
Hi guys
i want to use "Arduino mega 2560 " as data acquisition,
but the analog signal is bipolar(ECG signal)
so can i direct measure this signal or i need signal conditioning circuit?
retrolefty
Hi guys
You will need some form of external signal conditioning as the arduino analog inputs cannot safety handle negative voltages (below -0.5vdc) or positive voltages about Vcc + 0.5vdc. This same voltage limit applies to the digital input pins also.
Lefty
class
#2
Feb 05, 2013, 05:53 pm Last Edit: Feb 05, 2013, 05:56 pm by class Reason: 1
thank you(retrolefty)
are there datasheet for analog input?
retrolefty
Well there is a Atmel datasheet avalible that covers the complete mega2560 chip that has sections covering the build in ADC.
http://www.atmel.com/images/doc2549.pdf
Lefty
