Topic: Trying to Merge these programs together. Please Help. (Read 944 times) previous topic - next topic
ArduinoPalmer
Hi Arduino People,
So im pretty new with this stuff and Im having trouble merging two ideas into one program.
I basically want the functions of example 05 but I want to use the touch sensor (project 13) as my pushbutton switch. below are the two separate arduino codes.
//  Example 05: Turn on LED when the button is pressed
//  and keep it on after it is released
//  including simple de-bouncing.
//  If the button is held, brightness changes.
// Copy and paste this example into an empty Arduino sketch
#define LED 9     // the pin for the LED
#define BUTTON 7  // input pin of the pushbutton
int val = 0;      // stores the state of the input pin
int old_val = 0;  // stores the previous value of "val"
int state = 0;    // 0 = LED off while 1 = LED on
int brightness = 128;        // Stores the brightness value
unsigned long startTime = 0; // when did we begin pressing?
  pinMode(LED, OUTPUT);   // tell Arduino LED is an output
  pinMode(BUTTON, INPUT); // and BUTTON is an input
  val = digitalRead(BUTTON); // read input value and store it
                             // yum, fresh
  // check if there was a transition
  if ((val == HIGH) && (old_val == LOW)) {
    state = 1 - state; // change the state from off to on
                       // or vice-versa
    startTime = millis(); // millis() is the Arduino clock
                          // it returns how many milliseconds
                          // have passed since the board has
                          // been reset.
    // (this line remembers when the button
    // was last pressed)
    delay(10);
// check whether the button is being held down
  if ((val == HIGH) && (old_val == HIGH)) {
    // If the button is held for more than 500ms.
    if (state == 1 && (millis() - startTime) > 500) {
      brightness++; // increment brightness by 1
      delay(10);    // delay to avoid brightness going
                    // up too fast
      if (brightness > 255) { // 255 is the max brightness
        brightness = 0; // if we go over 255
                        // let's go back to 0
  old_val = val; // val is now old, let's store it
  if (state == 1) {
    analogWrite(LED, brightness); // turn LED ON at the                                               // current brightness level
    analogWrite(LED, 0); // turn LED OFF
  Arduino Starter Kit example
Project 13  - Touch Sensor Lamp
This sketch is written to accompany Project 13 in the
Arduino Starter Kit
Parts required:
1 Megohm resistor
metal foil or copper mesh
220 ohm resistor
LED
Software required :
CapacitiveSensor library by Paul Badger
http://arduino.cc/playground/Main/CapacitiveSensor
Created 18 September 2012
by Scott Fitzgerald
http://arduino.cc/starterKit
This example code is part of the public domain
// import the library (must be located in the
// Arduino/libraries directory)
#include <CapacitiveSensor.h>
// create an instance of the library
// pin 4 sends electrical energy
// pin 2 senses senses a change
CapacitiveSensor capSensor = CapacitiveSensor(4,2);
// threshold for turning the lamp on
int threshold = 1000;
// pin the LED is connected to
const int ledPin = 12;
  // open a serial connection
  // set the LED pin as an output
  pinMode(ledPin, OUTPUT);
  // store the value reported by the sensor in a variable
  long sensorValue = capSensor.capacitiveSensor(30);
  // print out the sensor value
  Serial.println(sensorValue);
  // if the value is greater than the threshold
  if(sensorValue > threshold) {
    // turn the LED on
    digitalWrite(ledPin, HIGH);
  // if it's lower than the threshold
  else {
    // turn the LED off
    digitalWrite(ledPin, LOW);
  delay(10);
Please Help!!!!
johnwasser
  // if the value is greater than the threshold, 'button' is down
  val = (sensorValue > threshold);
    // or vice-versa
    // been reset.
    delay(10);
      // up too fast
  if (state == 1) {
  else {
ArduinoPalmer
thanks for the Post.  It works perfect.  If I want to change the increment brightness what do I change in the code?  i seems to take a long time to brighten.
Thanks a bunch
johnwasser
I would change the line that says:
That line is a shortcut for:
brightness += 1; // increment brightness by 1
Which is a shortcut for:
brightness = brightness + 1; // increment brightness by 1
Skorn
brightness++;
delay(10);
 // you could reduce the delay
