Topic: Arduino Led e Velocità Motore GUI (Read 6114 times) previous topic - next topic
francescoprisco
dovrebbe essere una cosa del genere?
      while (arduino.available () > 0) {
inByte = arduino.readStringUntil('\n');
if ( inByte != null ) {
  a= arduino.readStringUntil('\n');
   synchronized(a){
      a = inByte;
  fill(125);
  synchronized(a){
        text(a,width/2, height/2);
lesto
togli a= arduino.readStringUntil('\n');
e
fill(125);
la text va messa nella funzione draw()
Unoffical Telegram group https://telegram.me/joinchat/ALRu8ACkdTdXyz-2P7v13A
francescoprisco
Così dunque:
import processing.serial.*;
int width = 800;
int height = 600;
String inByte;
String a;
int button1X;
int button1Y;
int button1Width = width/10;
int button1Height = height/20;
int button2X;
int button2Y;
int button3X;
int button3Y;
int button2Width = button1Width;
int button2Height = button1Height;
int button3Width = button1Width;
int button3Height = button1Height;
float buttonFont = button1Height/1.5;
float wordFont = button1Height;
Serial arduino;
color buttonColor, buttonHighlight, buttonPressed;
PFont font;
boolean button1Over = false;
boolean button2Over = false;
boolean button3Over = false;
  size(width,height);
  smooth();
  font = loadFont("CourierNew36.vlw");
  buttonColor = color(255);
  buttonHighlight = color(200);
  buttonPressed = color(50);
  button1X = width/10 - button1Width/2;
  button1Y = height/5 - button1Height/2;
  button2X = 2*width/10 - button1Width/2;
  button2Y = height/5 - button1Height/2;
    button3X = 3*width/10 - button1Width/2;
  button3Y = height/5 - button1Height/2;
  arduino = new Serial(this,"COM3", 9600);
    arduino.bufferUntil('\n'); // SerialEvent for new line
  arduino.clear();
void draw() {
  update(mouseX,mouseY);
  background(0);
  if(button1Over) {
    fill(buttonHighlight);
    fill(buttonColor);
  stroke(0);
  rect(button1X,button1Y, button1Width, button1Height);
  if(button2Over) {
    fill(buttonColor);
  stroke(0);
  rect(button2X,button2Y, button2Width, button2Height);
    if(button3Over) {
    fill(buttonColor);
  stroke(0);
  rect(button3X,button3Y, button3Width, button3Height);
  textFont(font, buttonFont);
  fill(0);
  text("On t",button1X + button1Width/3.9,button1Y + button1Height/1.3);
  text("On nt",button2X + button1Width/10.9,button1Y + button1Height/1.3);
    text("Off nt",button3X + button1Width/10.9,button1Y + button1Height/1.3);
   synchronized(a){
      a = inByte;
  synchronized(a){
  textFont(font, wordFont);
  fill(255);
  text("Accendi/Spegni Led ",button3X + button1Width + width/20,button1Y + button1Height/1.2);
void update(int x, int y) {
  if(overButton(button1X,button1Y,button1Width,button1Height)){
    button1Over = true;
  if(overButton(button2X,button2Y,button2Width,button2Height)){
    button2Over = true;
  if(overButton(button3X,button3Y,button3Width,button3Height)){
    button3Over = true;
void mousePressed() {
  if(button1Over) {
    println("Button1 pressed");
    arduino.write('S');
    fill(buttonPressed);
  if(button2Over) {
    println("Button2 pressed");
     arduino.write('N');
  if(button2Over) {
    println("Button3 pressed");
     arduino.write('Z');
boolean overButton(int x, int y, int width, int height) {
  if(mouseX >= x && mouseX <= x+width && mouseY >= y && mouseY <= y+height) {
    return true;
    return false;
void serialEvent (Serial arduino) {
  // get the byte:
  // print it:
// println(inByte);
  // at the edge of the screen, go back to the beginning:
lesto
no allora chiariamo le cose.
Tu hai 2 thread, ovvero 2 "programmi" in parallelo su processing.
Uno ha il loop che si chiama appunto loop() come su arduino, che non stai usando (infatti manca mi pare, ma va bene così. Quà vanno messe tutte le operazioni logiche.
Uno si chiama draw() e viene chiamato quando bisogna aggiornare la finestra. Qua vanno messe SOLO le operazioni di disegno. Niente letture seriali o boiate del fenere.
In oltre ci sono degli eventi, ovvero funzioni che sono chiamate quando succede qualcosa. In questo caso "void serialEvent (Serial arduino) {"
quindi nell'evento seriale leggi la seriale e metti il risultato in una stringa (nel tuo caso "a").
il draw semplicemente stampa "a", nient'altro. se poi in "a" c'è un valore messo da seriale o il numero seriale di windows la fuunzione draw se ne deve fregare.
PERCHE?
perchè se la seriale si impalla (prova a staccare arduino), se fai come dico io la grafica è INDIPENDENTE dalla seriale e puoi chiudere/continuare ad usare il tuo programma... col tuo sistema anche la grafica si impalla e devi uccidere il programma da taskmanager.
altro esempio è se "a" fosse un'elaborazione pesante, l'immagine della finestra rimarrebbe congelata e non responsiva... non ti è mai capitato? bene, sappi che quello è un errore di strutturazione, o di architettura del programma.
kiss
francescoprisco
Lesto ti chiederei troppo se ti chiedessi di fare i due pezzi di codice che mi servirebbero a prendere questi dati da arduino? Per piacere ne sto uscendo pazzo  :smiley-eek: :smiley-eek:
francescoprisco
#20
Feb 07, 2013, 08:01 pm Last Edit: Feb 07, 2013, 08:16 pm by francescoprisco Reason: 1
Ho provato a modificare il codice in questo modo
int width = 800;
int height = 600;
String inByte = null;
String a;
int lf = 10;
int button1X;
int button1Y;
int button2X;
int button2Y;
int button3X;
int button3Y;
Serial arduino;
PFont font;
 size(width,height);
 smooth();
 arduino.clear();
void draw() {
 background(0);
 if(button1Over) {
   fill(buttonColor);
 stroke(0);
 if(button2Over) {
   fill(buttonColor);
 stroke(0);
   if(button3Over) {
   fill(buttonColor);
 stroke(0);
 fill(0);
synchronized(a){
 fill(255);
   button1Over = true;
   button2Over = true;
   button3Over = true;
 if(button1Over) {
   arduino.write('S');
 if(button2Over) {
    arduino.write('N');
 if(button2Over) {
    arduino.write('Z');
   return true;
   return false;
inByte =  arduino.readStringUntil(lf);  // Receive one reading from Arduino
 if (inByte != null) {
      synchronized(a){
    a = inByte;
   println(a);
leggendo anche un pò il codice di http://scuola.arduino.cc/en/content/how-create-graphical-interface-tinkerkit-gyro-module
con risultato una schermata grigia senza nulla all'interno.
In processing mi da questi errori:
Exception in thread "Animation Thread" java.lang.NullPointerException
at sketch_130203abbbbbb.draw(sketch_130203abbbbbb.java:107)
at processing.core.PApplet.handleDraw(PApplet.java:2142)
at processing.core.PGraphicsJava2D.requestDraw(PGraphicsJava2D.java:193)
at processing.core.PApplet.run(PApplet.java:2020)
at java.lang.Thread.run(Thread.java:662)
error, disabling serialEvent() for //./COM3
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at processing.serial.Serial.serialEvent(Unknown Source)
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
Caused by: java.lang.NullPointerException
at sketch_130203abbbbbb.serialEvent(sketch_130203abbbbbb.java:173)
... 8 more
(Guarda allegato)
lesto
ad occhio
String a;
in
String a="nessun valore ricevuto per ora";
in processing le variabili GLOBALI non inizializzate sono "null"
non sai se a verrà prima inizializzata dalla seriale o prima usata dalla grafica, e la grafica se prova a stanapare una stringa "null" va in errore  (infatti hai un "null pointer exception")
francescoprisco
Ho messo il codice come dicevi tu
int width = 800;
int height = 600;
int lf = 10;
int button1X;
int button1Y;
int button2X;
int button2Y;
int button3X;
int button3Y;
Serial arduino;
PFont font;
  size(width,height);
  smooth();
  arduino.clear();
void draw() {
  background(0);
  if(button1Over) {
    fill(buttonColor);
  stroke(0);
  if(button2Over) {
    fill(buttonColor);
  stroke(0);
    if(button3Over) {
    fill(buttonColor);
  stroke(0);
  fill(0);
synchronized(a){
  fill(255);
    button1Over = true;
    button2Over = true;
    button3Over = true;
  if(button1Over) {
    arduino.write('S');
  if(button2Over) {
     arduino.write('N');
  if(button2Over) {
     arduino.write('Z');
    return true;
    return false;
       synchronized(a){
     a = inByte;
    println(a);
In  terminale seriale il valore viene visualizzato ma nella GUI no.Come devo fare? (Guarda immagine in allegato)
francescoprisco
Sono riuscito a risolvere il problema usando questo codice qui
// Example by Tom Igoe
Serial myPort;    // The serial port
PFont myFont;     // The display font
String inString;  // Input string from serial port
int lf = 10;      // ASCII linefeed
  size(400,200);
  // Make your own font. It's fun!
  myFont = loadFont("CourierNew36.vlw");
  textFont(myFont, 18);
  // List all the available serial ports:
  println(Serial.list());
  // Open the port you are using at the rate you want:
  myPort = new Serial(this, Serial.list()[0], 9600);
  myPort.bufferUntil(lf);
void draw() {
  background(0);
  text("received: " + inString, 10,50);
void serialEvent(Serial p) {
  inString = (myPort.readString());
preso dalle guide di Processing disponibile al link http://www.processing.org/reference/libraries/serial/Serial_bufferUntil_.html
Ora quello che io mi chiedo, Mettiamo caso io debba prelevare + dati da + sensori... come organizzo quel codice?Lesto intanto ti ringrazio per l'aiuto e la tua disponibilità, ho già provveduto ad assegnarti il karma.
francescoprisco
lesto
ora tu prendi una stringa di una riga a la stampi.
Ora, arduino potrebbe stampare tutti i valori su una riga e poi a fine loop andare a capo, così avetsri tutti i valori in una riga.
Poi volendo puoi dividere i valori con una virgola, o con una lettera, in modo che poi lato processing giocando con la stringa (un pò di  cerca e taglia, vedi substring e indexOf della classe String), puoi anche estrarre i valori dei vari sensori per poterli visualizzare in posti differenti od animare qualche grafico etc..
francescoprisco
francescoprisco
lesto
fai qualche prova da solo, e se non funziona posta il codice che hai usato, cosa ti apsettavi facesse, e cosa invece ha fatto.
francescoprisco
Ho provato a modificare il codice così ma non so se e corretto ora non sono in condizione di poter testare.
Arduino:
void displayvalue(){
pass = digitalRead(A1);
if(pass != 0)
   car++;
  Serial.println(mph);
  Serial.print(",");
  Serial.println(car);
processing:
int sensors[] = int(split(inString, ','));
println(sensors[0]);
println(sensors[1]);
Così dovrebbe funzionare?
