Author Topic: 4 pin ultrasonic range finder, 3 pin ping sensor  (Read 491 times)
can a 4 pin ultrasonic range finder be operational using only 3 pins as on the parallax ping sensors?
Thank You
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
No, with the 4 pin, they have split the data lines to Echo and Trigger, instead of a single line. The 3 pin code will work, you just need to tweak it to work with trigger and echo. HINT: one is input and the other is output.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Central MN, USA
You want some code or just general advice whether to buy a 4-pin sensor but run the 3-pin code?
Here is code snippet:
    micros_now=micros();
    digitalWrite(sonic_ranger_init,LOW);
    delayMicroseconds(2);
    digitalWrite(sonic_ranger_init,HIGH);
    delayMicroseconds(15);
    delayMicroseconds(20);
    micros_delay=pulseIn(sonic_ranger_echo,HIGH,35000L);
    distance_mm=micros_delay*343/2000; // This is round trip time so 1/2/1000=1/2000
    Serial.println(distance_mm);
Go ahead and but the 4-pin sensor.
