Topic: 50 NTC o DS18B20 con un arduino UNO [SOLUCIONADO casi] (Read 16563 times) previous topic - next topic
flico
#15
Mar 01, 2013, 11:42 pm Last Edit: Mar 01, 2013, 11:48 pm by flico Reason: 1
Como bien decis los dispositivos onewire tienen un dni o ROM de 8 bytes.
El primer byte de la ROM define el tipo de dispositivo 0x28 DS18B20 0x10 DS18S20
Te dejo este ejemplo de hacktronics, espero que te sirva
Code: [Select]
// This Arduino sketch reads DS18B20 "1-Wire" digital
// temperature sensors.
// Tutorial:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-tutorial.html
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress insideThermometer = { 0x28, 0x94, 0xE2, 0xDF, 0x02, 0x00, 0x00, 0xFE };
DeviceAddress outsideThermometer = { 0x28, 0x6B, 0xDF, 0xDF, 0x02, 0x00, 0x00, 0xC0 };
DeviceAddress dogHouseThermometer = { 0x28, 0x59, 0xBE, 0xDF, 0x02, 0x00, 0x00, 0x9F };
void setup(void)
  // start serial port
  // Start up the library
  sensors.begin();
  // set the resolution to 10 bit (good enough?)
  sensors.setResolution(insideThermometer, 10);
  sensors.setResolution(outsideThermometer, 10);
  sensors.setResolution(dogHouseThermometer, 10);
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  if (tempC == -127.00) {
    Serial.print("Error getting temperature");
    Serial.print("C: ");
    Serial.print(tempC);
    Serial.print(" F: ");
    Serial.print(DallasTemperature::toFahrenheit(tempC));
void loop(void)
  delay(2000);
  Serial.print("Getting temperatures...\n\r");
  sensors.requestTemperatures();
  Serial.print("Inside temperature is: ");
  printTemperature(insideThermometer);
  Serial.print("\n\r");
  Serial.print("Outside temperature is: ");
  printTemperature(outsideThermometer);
  Serial.print("Dog House temperature is: ");
  printTemperature(dogHouseThermometer);
  Serial.print("\n\r\n\r");
curro92
Gracias, Heke y flico
De acuerdo, no importa el orden en que yo coloque los sensores. Creo que me lié un poco al explicar antes: todavía quedo con la duda,  ¿el orden en que sensors.getAddress() me los presenta,  ¿siempre es el mismo, o es aleatorio? Si fuera aleatorio, tendría que recoger en el log mac+valor cada vez; si siempre salieran en el mismo orden, sabiendo el orden en que salen, solo anotaría el valor.
He visto que en la librería DallasTemperature (con la que también está hecho el ejemplo que menciona flico)  al hacer begin se buscan los devices
Code: [Select]
while (_wire->search(deviceAddress))
    if (validAddress(deviceAddress))
        devices++;
Está llamando iterativamente a un  _wire->search() que es una función de la librería OneWire , en cuyas fuentes casi me ahogo...
flico
Quote
No eres el unico que le ha pasado.
curro92
Hola,
sigo intentando establecer el orden de mis sensores: son 10 sensores que van colocados en fila entre los panales de una colmena, de izquierda a derecha. La librería produce una lista de los sensores que detecta.
En más de un lugar he hallado esto:
The order is deterministic. You will always get the same devices in the same order
Como no puedo establecer a partir de su ID el orden en que aparecerán en la lista, voy a hacer esto:
- conectar los 10 sensores al arduino, sacar la lista de los sensores
-  mientras estoy viendo las temperaturas en la consola, ir calentando uno a uno los sensores (apretando entre dos dedos), y ver cuál de ellos sube la temperatura, y marcarlo con el nº de orden que tiene en la lista.
- desconectarlos, y volver a conectarlos en el orden que se les ha asignado.
Así en el log sabré que el primer registro corresponde al primer sensor de la izquierda, y así sucesivamente.
El problema:  mi aplicación servirá solo para esos sensores colocados de esa manera. El día que uno se estropee y tenga que cambiarlo, tendría que rehacer todo el proceso de identificación.
La alternativa no me gusta: guardar en el log cada registro de temperatura asociado a su ID (16 caracteres), y luego reordenar los registros según el orden físico de los sensores.
Heke
#19
Mar 31, 2013, 10:29 am Last Edit: Mar 31, 2013, 10:40 am by Heke Reason: 1
Curro92
Me parece recordar que habia un sketch para identificar la MAC de cada dispositivo conectado...
Si es asi, solo tendrias que antes de sustituir un sensor cambiar en las variables o definiciones del programa su valor, pero la posicion seria la misma.
Me refiero a algo asi:
# define sensor 1 = mac... la que sea o numero de orden el que sea..
# define sensor 2 = mac... la que sea o numero de orden el que sea..
# define sensor 10 = mac... la que sea o numero de orden el que sea..
y en tu programa seguirias leyendo el sensor 1 o 2 o 3 solo que la mac o numero de orden habria cambiado.
Mira a ver si lo encuentras, yo hare lo mismo y si lo veo te lo posteo.
He encontrado de momento estos enlaces que te identifican el adress (yo lo llamo la mac)
http://arduino-info.wikispaces.com/Brick-Temperature-DS18B20#mult
http://tutorialpedia.org/tutorials/Working+with+Dallas+DS18S20+and+DS18B20+temperature+sensors+from+Arduino.html
Aqui el codigo que emplean para identificar el adress:
Code: [Select]
// This sketch looks for 1-wire devices and
// prints their addresses (serial number) to
// the UART, in a format that is useful in Arduino sketches
// Tutorial:
OneWire  ds(3);  // Connect your 1-wire device to pin 3
void setup(void) {
 discoverOneWireDevices();
void discoverOneWireDevices(void) {
 byte i;
 byte present = 0;
 byte data[12];
 byte addr[8];
 Serial.print("Looking for 1-Wire devices...\n\r");
 while(ds.search(addr)) {
   Serial.print("\n\rFound \'1-Wire\' device with address:\n\r");
   for( i = 0; i < 8; i++) {
     Serial.print("0x");
     if (addr[i] < 16) {
       Serial.print('0');
     Serial.print(addr[i], HEX);
     if (i < 7) {
       Serial.print(", ");
   if ( OneWire::crc8( addr, 7) != addr[7]) {
       Serial.print("CRC is not valid!\n");
       return;
 Serial.print("\n\r\n\rThat's it.\r\n");
 ds.reset_search();
 return;
void loop(void) {
 // nothing to see here
PD: Upsss..... creo que Flico ya te habia dirigido a hackatronics.... sorry... no lo habia visto.
leorrr
Hola a todos, yo estoy dandoles vueltas al mismo tema, y he hecho prueba con cuatro sensores ds18b20, y siempre salen en el mismo orden indiferentemente, de como estén conectados.
Code: [Select]
Found '1-Wire' device with address:
0x28, 0x68, 0x29, 0xEA, 0x03, 0x00, 0x00, 0xC1
0x28, 0x46, 0x40, 0x1A, 0x04, 0x00, 0x00, 0x8D
0x28, 0x5E, 0x78, 0x1A, 0x04, 0x00, 0x00, 0xCD
0x28, 0xF1, 0x33, 0xEA, 0x03, 0x00, 0x00, 0x27
That's it.
la verdad es que me tiene un poco despistado, pero su lógica tendrá....
curro92
Hola, @leorrr
Yo me hice un programilla que sacaba por serie el address y temperatura de cada sensor repetidamente. Tomando cada vez un sensor entre los dedos, miraba en cuál subía la temperatura y lo identifiqué externamente con el número de orden que le correspondía.
Luego tendrías que montar un array de los address en el orden en que salen, y leer temperturas en addresses[0], addresses[1] etc.
Code: [Select]
DeviceAddress addresses[] =
  { 0x28, 0x68, 0x29, 0xEA, 0x03, 0x00, 0x00, 0xC1 },  // nº 1
  { 0x28, 0x46, 0x40, 0x1A, 0x04, 0x00, 0x00, 0x8D },  // nº 2
  { 0x28, 0x5E, 0x78, 0x1A, 0x04, 0x00, 0x00, 0xCD },  // nº 3
  { 0x28, 0xF1, 0x33, 0xEA, 0x03, 0x00, 0x00, 0x27 }   // nº 4
leorrr
Mirando el foro encontré un link a una pagina de maxin, el creador del bus one-wire que usa el ds18b20, y que te explica el algoritmo de busqueda http://www.maximintegrated.com/app-notes/index.mvp/id/187 pero la verdad es que a mi me supera, y de todas maneras para mi proyecto no me sirve, el problema que yo veo es que si algún día se avería una sonda, y la cambias, la nueva no ocupara necesariamente la posición que tenia la antigua, y eso implica reasignar las sondas en el codigo, demasiado complicado, como solo tengo pensado usar 6,  emplearé las  ntc con el multiplexor 4051, así  puedo controlar el orden, si se avería alguna solo es cambiar y listo.
curro92
Hola, leorrr
tal vez me lié con mi insistencia en el orden, era una forma de identificar los sensores, pero ahora veo más claro que en realidad el orden que salen no tiene importancia, lo que necesitas es asociar cada sensor físico con su address. Luego según el orden que te interese que salgan las lecturas, ordenas los address en el array DeviceAddress addresses[].  Usando el array, el orden de lectura lo estableces tú, sabiendo el número de sensores (devicecount). Yo lo hago así
Code: [Select]
for(n=0;n< devicecount; n++)
     tempC[n] = sensors.getTempC(addresses[n]);
Cuando falle un sensor, conectas el nuevo al arduino, y averiguas su address (con el programilla que muestra en address por consola) y colocas esa dirección en el lugar que te convenga en el array.
Realmente el orden en que salen (según ese algoritmo tan complicado) solo interesaría si no usáramos ese array.
Te animo a que uses DS18B20, se conectan todos a 3 cables, y en la lectura no interviene la resistencia de los conductores.
leorrr
Si el funcionamiento de la ds18b20, lo tengo claro, de hecho dispongo de 5 de ellas, 2 waterprof, y 3 mas de los normales, y se que son mas fiables, mas versátiles, he leído que les puedes programar una temperatura de alerta y el chip te avisa cuando llega a esa "temp", etc, pero,pero... para mi es muy importante que en caso de fallo de un sensor, el orden de las sondas no se altere, y que al sustituirla se mantenga el orden físico original, ademas es mucho mas rápido de reparar, con un simple destornillador lo solucionas. con la ds18b20, aparte del destornillador, te hace falta un ordenador y alguien que sepa modificar el código.
Había pensado, incluso, en hacer una especie de menú de configuración para asignar las sondas, pero la memoria del arduino normal tiene sus limites, probablemente con el mega podría hacerlo, pero bueno lo mejor es ir poco a poco, me he propuesto, para el próximo agosto, tener un prototipo manejable..., que se pueda meter en una caja.
Saludos Leo...
noter
Así lo estoy haciendo yo, aunque de momento no uso tantos termómetros como tú, pero el sistema es perfectamente ampliable:
Guardo en eeprom las direcciones de los dallas.
Al leer la configuración miro uno a uno si los dallas existen. Si no, asigno 00000000.
Un menú específico me permite seleccionar un índice de termómetro e ir recorriendo todos los dallas (en caso de sustituir uno) y asignar uno nuevo a ese índice, guardando luego en la eeprom la nueva configuración.
Creo que la dirección de cada dallas eran 8 bytes; tampoco me parece una escabechina de memoria 80 bytes por 10 dallas conectados, por ejemplo; más teniendo en cuenta que para muchos de los comandos necesitas invocar esa dirección, con lo que te ahorras el tener que hacer un getAddress cada vez que quieras llamar a un termómetro determinado.
leorrr
Pues, esta muy bien pensado, con tu sistema, al fallar una sonda puede saber cual y actuar en consecuencia, por cierto, ¿alguien sabe,cuantas ds18b20, se pueden conectar a la vez en modo parásito al arduino?, lo pregunto mas que nada por el consumo de corriente....
