Topic: String or Char Arrays Length Definition (Read 8464 times) previous topic - next topic
tavovalencia
Hi there,
I'm interfacing a LCD with a consumer, prompting to enter some text via serial.
I have some default text (easy enough), but I will like to limit input to 8 character strings. What should I do:
  • Define input as char text[8].
  • Define input as String.
In either case, how to limit Serial.read() to read only 8 chars? (If loop with string.lenght == 8 )? or is there a more efficient way?
PaulS
Quote
What should I do:
Neither. 8 characters need a 9 element array, so there is room for the terminating NULL.
Quote
That depends on what you intend to do if there is more than 8 characters sent. I would read and store the first 8, and read and discard the rest until the end-of-packet marker arrived.
tavovalencia
Quote
What should I do:
Ok, got it... Forgot about the NULL.
Are you suggesting me to go char text[9] instead of string?
Quote
I really want users to think through and only input 8 characters. If there is more than 8 chars, warn user and ask again. Only 'save' (change variable) if the input is 3<=text>=8, then LCD print some info with the user input!
PaulS
Quote
A string is a NULL terminated array of chars. A String, on the other hand, is a horrid beast that has no place on the Arduino.
Quote
How will you know when they are done with input? Where is the input coming from? You can count the characters received, and store the first 8 in the array. If the end-of-packet marker arrives before you get to 9, then use the data. Otherwise, reject it. It ain't rocket surgery.
tavovalencia
I was thinking in something like this:
tmpName = Serial.read()
if (strlen($tmpName) < 2 || strlen($tmpName) > 8 )
     Serial.println("The input is not valid!, please retry (min: 3 chars, max 8 chars)");
     char Name[9] = tmpName
But I don't know how to work around strlen()
PaulS
Quote
I don't understand why you think you need to. That example won't work, for several reasons.
First, Serial.read() returns ONE character, not a string.
Second, there is no variable defined called $tmpName, which is not a valid name in C++.
Third, you can't assign an array (if that is what the undefined tmpName is supposed to be) to another array that way.
tavovalencia
OK, I get It... I was trying to do the 3rd.
I wanted to add a string or an array of characters after user inputs the text and hits "send"
PaulS
Quote
strcat() does that.
tavovalencia
OK, but how can I limit strcat() to 8 chars?
pYro_65
You could overload the function to add in another parameter, or put a null in the source at the position you want it to stop copying at.
If needed, store the 8th character in a temp, replace with null, when done just put the temp char back.
Forum Mod anyone?
https://arduino.land/Moduino/
Erni
You could read and count the characters until you reach the terminator, while you store the characters in a character array.
The terminator could be Carriage return, or other special you choose
If the count is >8, warn the user, ans start over.
tavovalencia
This sounds great, though I'm not sure how to implement the If. I have this so far:
Code: [Select]
char Name[9]; // My Data array
char inChar; // Where to store the character read
byte index = 0; // Index into array; where to store the character
if(index < 8){
           inChar = Serial.read();
           Name[index] = inChar; // Store it
           index++; // Increment where to write next
           Name[index] = '\r'; // Carriage to terminate the string
else{
           Serial.println("Invalid Input, please enter 3 to 8 characters");
Will that work?
Erni
#12
Feb 06, 2013, 02:27 pm Last Edit: Feb 06, 2013, 02:29 pm by Erni Reason: 1
That was something like that I was thinking, although I think that the below test Sketch is more likely what you want.
You need to clear the Name array in case of wrong number of entrys, and end the Array with the null terminator.
There might be some errors in the sketch, but it explains better than words what I meant.
Code: [Select]
void setup(){
void loop(){
 if (Serial.available()>0){
          if (index>8){
  if (int(Name[index])==13){  //If Carriage return has been reached
           Serial.println(Name);
        index=0;
JosAH
The Stream class has a readBytesUntil( ... ) function; have a look at it.
kind regards,
Jos
tavovalencia
EUREKA!!! jajaja thanks!
