Loading...
Pages: 1 [2] 3   Go Down
Author Topic: String or Char Arrays Length Definition  (Read 698 times)
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Will that work?
No. A string is terminated by a NULL ('\0'), not a line feed ('\r').
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
EUREKA!!!
Keep in mind that you need to provide a large enough array to hold what the user typed, and that that may be more than 8 bytes.
Logged
Offline Offline
Newbie
View Profile
Quote
EUREKA!!!
jajaja I found out about this already  the hard way, with this code if I enter 123456789 I receive back two lines, 1st: 12345678 and 2nd: 92345678 so it overwrites the array.
Code:
char Name[9]; // My Data array
 while (!Serial) {
   ; // wait for serial port to connect. Needed for Leonardo only
 Serial.println("Please Enter your Name: ");
 while (!Serial.available()); // Wait for characters
 Serial.readBytes(Name, 8);
 Serial.println(Name);
Is there a way to avoid overwriting? ... not sure if I should go back to the other suggestions.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Yes, and no.
The signature for the readBytes() method is:
Code:
  size_t readBytes( char *buffer, size_t length); // read chars from stream into buffer
  // terminates if length characters have been read or timeout (see setTimeout)
  // returns the number of characters placed in the buffer (0 means no valid data found)
So, you know how many bytes were received. You can NULL terminate the array after that number of characters. That would make the output you saw "12345678" and "9".
I think a better approach is to use readBytesUntil() and send an EXPLICIT end of packet marker (the Serial Monitor can do that automatically). Then, simply check the number of bytes received.
Logged
UK
Offline Offline
Tesla Member
View Profile
Some code posted earlier showed how to read characters one by one and append them to the array, incrementing an index variable that held the length of the string received so far.
All you need to do is add a check that the array is not already full, before you append another character to the string.
Code:
    if (Serial.available()>0)
        inChar = Serial.read();
        if(index < 7)
            Name[index++] = inChar; // Store it
            Name[index] = 0; // append null-terminator
            // ... etc
            // buffer is already full - discard the character
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
Code:
Should it not be:  ?
Code:
Name[index]='\0';
Logged
North Queensland, Australia
Offline Offline
Edison Member
View Profile
WWW
They are equivalent. ASCII for null is 0
Logged
East Anglia (UK)
Online Online
Edison Member
May all of your blinks be without delay
View Profile
To prove it, try this
Code:
char myChars[] =  "1234567890";
  output();
  myChars[7] = '\0';
  output();
  myChars[5] = 0;
  output();
void output()
  Serial.println(myChars);
  for (int i = 0;i <= 10;i++)
    Serial.println(myChars[i],HEX);
Logged
Offline Offline
Newbie
View Profile
Back to the original problem... I almost got it. I still have a couple of questions (below!);
Here's the code:
Code:
char Name[9] = ""; // My Data array
char inChar; // Where to store the character read
byte index = 0; // Index into array; where to store the character
void setup(){
void loop(){
  if (Serial.available()>0){
     Name[index] = inChar; // Store it
     if (index>8){
         Serial.println("Invalid Input, please enter 3 to 8 characters");
         index=-1;
         memset(Name, 0, sizeof(Name));
   else if (int(Name[index])==13){  //If Carriage return has been reached
         index=-1;
         Name[9] = '\0';
   index++; // Increment where to write next
If I insert any string from 1 to 8 chars it works perfectly, else:
  • 9 chars - println the error message - GREAT!
  • >9 chars - sometimes prints error message twice (more than 20 chars) or error message + modulos 10 (that is the 11th, 12th, 13th... chars) - I don't get why? or how to avoid?
Thanks for your help so far!!
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Code:
         Name[9] = '\0';
For an array of 9 elements, what are the valid index values? Hint: 9 is not one of them.
Logged
Offline Offline
Newbie
View Profile
Code:
         Name[9] = '\0';
array of 9 elements = 8 valid values. right? I don't really get what you're suggesting?
Logged
UK
Offline Offline
Tesla Member
View Profile
No. The first element is array[0]. Count up to nine elements and see which index values you used.
Logged
Offline Offline
Newbie
View Profile
According to your explanation, there would be 10. But according to http://arduino.cc/en/Reference/Array
Quote
int mySensVals[6] = {2, 4, -8, 3, 2};
char message[6] = "hello";
so there are 5 values in the first and 5 letters in the second. I still don't get your point?... with my code loaded... press a key and hold until 20 or more chars have appeared in the dialog and then press enter... the error message appears several times and sometimes other chars bellow...
Logged
Offline Offline
Sr. Member
View Profile
lets look at index vs character position:
Index    Char position
0               1 (first character)
1               2
2               3
3               4
4               5
6               7
7               8 (last character)
8               9 (nul goes here at arry[8]
Logged
Offline Offline
Newbie
View Profile
  • INPUT: "1" ; OUTPUT: "1"
  • INPUT: "12345" ; OUTPUT: "12345"
  • INPUT: "12345678" ; OUTPUT: "12345678"
  • INPUT: "123456789" ; OUTPUT: "Invalid Input, please enter 3 to 8 characters"
  • INPUT: "12345678901" ; OUTPUT: Blank line, "Invalid Input, please enter 3 to 8 characters" & line with "1"
  • INPUT: "123456789012" ; OUTPUT: Blank line, "Invalid Input, please enter 3 to 8 characters" & line with "12"
  • INPUT: "012345678901234567890123" ; OUTPUT: "Invalid Input, please enter 3 to 8 characters" twice& line with "0123"
I would love to have just the ERROR ONCE. Any ideas, please!!!!
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
