Loading...
Pages: [1]   Go Down
Author Topic: Making a USB charger of a Racing Pack  (Read 2259 times)
Offline Offline
Jr. Member
View Profile
I calculated that that my cellphone battery (3.7V, 1.23Ah) can store 16.4kJ of energy and a battery for an RC car (7.2V, 3Ah) can store 77.7kJ, which could recharge the cellphone a few times.
So I was wondering if I could make a mobile USB charger of a Racing Pack and a 5V voltage regulator.
My questions are:
Does this work at all?
Can I damage something (for example with a too high voltage)?
What happens if the racing pack is discharged? Can I damage the phone / usb device with a too low voltage?
How can I determine when racing pack is discharged?
Logged
Denmark
Offline Offline
Full Member
New on the Arduino platform...
View Profile
WWW
Hi. If you use a standard voltage regulator, you will waste a LOT of energy this way, and regulator will get hot and require heatsinking.
I would recommend a module like this http://goo.gl/nLeVz - they are very good at this job.
Please be sure not to over-discharge your battery pack, or you will hurt your batteries. You could make an auto-switch off circuit with some resistors and a transistor that turns off the load when the voltage gets too low.
Good luck with the project.
// Per.
Logged
Louisiana, USA
Offline Offline
Newbie
View Profile
WWW
I've been reading the datasheet for the LM7805 -
http://www.fairchildsemi.com/ds/LM/LM7805.pdf
Looks to me like a problem would be the dropout voltage of 2V.  I read this to mean the 7805 will stop outputting when the input voltage dips below 7 volts.  That discharging RC battery wouldn't last long like that, would it?
Would 7.2V really be a heat issue at that low of a power draw?
Logged
Offline Offline
Full Member
View Profile
P=U*I
Calculate the power you waste with the 7805.
Logged
Pages: [1]   Go Up
Print
Jump to:
