Topic: Attiny 85 (Read 928 times) previous topic - next topic
Vincent19
Dear friend,
recently I get myself some attiny85. So, by referring to the datasheet, it mention it has 6 programmable I/O. But I just only can see there are 5 programmable IO only. Is it that the RESET pins also can be the IO  ?
Thanks
strykeroz
Yes it is possible to reassign the reset pin as an IO pin, but you won't be able to reprogram your ATTiny85 in the usual way after that, as the reset pin is required for that.  If you're using the Arduino IDE you'll typically treat it as 5 + reset + the two power pins.
What are you hoping to use them for?  It's possible you can work around this limitation.
Geoff
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
Erni
#2
Feb 06, 2013, 02:39 pm Last Edit: Feb 06, 2013, 02:41 pm by Erni Reason: 1
Yes it can, but if you use it as IO, you cannot reprogram the chip unless you use a High Valtage programmer
Ups, sorry strykeroz, I was too slow
Vincent19
USBasp consider HVP ? Oh, so for normal usage, I onyl can use 5 pins ?
Thanks
fungus
Realistically? 5 pins is the limit, yes. 6 pins needs special hardware to program it.
PS: You can use the RESET pin as an analog input so long as you don't take the voltage low enough to cause a reset :)
