Topic: Arduino Security [I know there are lots of them] (Read 940 times) previous topic - next topic
morganlowe
Feb 06, 2013, 04:24 pm Last Edit: Feb 06, 2013, 04:45 pm by morganlowe Reason: 1
I am using a mashup of parts though. Have a 4x4 keypad, LCD screen that runs on just 2 wires for signal, 4 relay board and an Uno.
Its works, once. I can't get it to reset for the next password. I was thinking of using a sensor that says the door has been opened to reset it or set off the alarm if the password was not used.
I am looking for just a little guidance. I need to finish out the build and the code. The LCD has an RGB LED in it and I want to use that to indicate some of the status. I only have 2 digital pins left and all the analog. With the door senor on those last two digital pins I'm not sure how to do the RGB LED but I am thinking the analog can run it.
Right now, can anyone help with the reset for the next password?
#include <Password.h>
#include <Keypad.h>
#include <Wire.h>
Password password = Password( "1234" );
unsigned char WrongAttempts = 0; //global variable to keep the number of wrong attempts done at the code.
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {6, 7, 8, 9}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {10, 11, 12, 13}; //connect to the column pinouts of the keypad
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
//PIN assignments
int r1 = 2; //alarm
int r2 = 3;  //green light
int r3 = 4;  //Red light
int r4 = 5;  //Nothing?
void setup(){
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
  lcd.init(); // initialize the lcd
  lcd.backlight();
  // Print a message to the LCD.
  //lcd.setCursor(0, 1);
  lcd.print("Security Status");
pinMode(r1, OUTPUT);
pinMode(r2, OUTPUT);
pinMode(r3, OUTPUT);
pinMode(r4, OUTPUT);
keypad.getKey();
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
lcd.print("Pressed: ");
lcd.println(eKey);
switch (eKey){
case '*': checkPassword(); break;
case '#': password.reset(); break;
default: password.append(eKey);
void checkPassword(){
if (password.evaluate()){
  lcd.clear();
lcd.println("Success!");
lcd.println("Disarmed!");
digitalWrite(r1, LOW); //DISCONNETC THE SIREN IF THE PASSWORD IS CORRECT
digitalWrite(r2, HIGH);
delay(2000);
digitalWrite(r3, HIGH);
delay(100);
}else{
    lcd.clear();
lcd.println("Wrong");
lcd.clear();
WrongAttempts++;
if (WrongAttempts >= 3) { //UPS....
digitalWrite(r1, HIGH); //START THE SIREN
digitalWrite(r3, HIGH); //START THE REDNESS
lcd.clear();
lcd.print("Alarm Activated");
delay(100);
delay(100);
UKHeliBob
It would help to understand your code if you gave the pins meaningful names.
Why do you need to know whether the door has opened ?  You already know that a correct password has been entered and if so, pins 'r2' and 'r3' are set high, presumably they are something to do with releasing the door (see what I mean about using meaningful names ?)
If the password is correct then release the door, give the user a few seconds to open the door, lock the door again and reset the password.  If the user did not open the door in the time allowed then, tough, they will need to enter the password again
morganlowe
I suppose Io could explain that.
r 1-4 are the relays. I didn't bother with meaningful names because I'm not used to working like that.
Relay 1 is alarm
Relay 2 is a big red bulb
Relay 3 is a big green bulb
Relay 4 is nothing but defined because it's there.
This isn't for anything serious, I was going to install it on the bathroom door.
The alarm is an old school bell.
UKHeliBob
It would be a good idea to get into the habit
Your comments indicate what the pins are used for but you cannot tell when reading the code.
How about
int alarm = 2; //alarm
int green_light = 3;  //green light
int red_light = 4;  //Red light
int nothing_yet = 5;  //Nothing?
I must admit to being amused by the fact that your explanation of what the pins are used for does not match your comments, which I think proves the point about using meaningful names.
Relay 1 is alarm
morganlowe
#4
Feb 06, 2013, 06:02 pm Last Edit: Feb 06, 2013, 06:21 pm by morganlowe Reason: 1
Alright, I'll change it, but that's not why I posted it here.
Thanks for the tip though!
How do we make it reset after a successful entry or after a set period of time when the alarm goes off.
One possibility is having a sensor for door open that resets it, but I don't think that would be the best overall solution. I am thinking something time based.
PeterH
I think either option would be viable. Making the system rearm itself after a delay (ten seconds would be enough?) would be easiest since it does not require any extra hardware.
morganlowe
My question is how to implement it. I tried setting it in the code and I broke the whole thing. I'm a N00b, any thoughts? Tips?
UKHeliBob
What do you do when the user enters '#' ?
Can't you do the same after a delay when they enter a correct password and you have flashed lights or whatever ?
PeterH
I would just add a fixed delay after the code that prints "Success!", and follow that by code to print out "Armed!" and reconnect the siren and do whatever you want to happen to the lamps. (Which, by the way, doesn't currently seem very sensible - the red and green lamps don't seem to be turned off in any coherent way. I suggest you decide what you want each lamp to represent, and then define when it needs to be turned on and off in terms of events within your sketch.)
morganlowe
Alright, I made some changes. I think it's much better but still incomplete. I picked a hellova project for my introduction to this.
#include <Keypad.h>
#include <Wire.h>
const byte COLS = 4; //four columns
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
/*-----( Declare Constants )-----*/
#define RELAY_ON 0
#define RELAY_OFF 1
/*-----( Declare objects )-----*/
/*-----( Declare Variables )-----*/
#define Relay_1  2  // Bell
#define Relay_2  3  // Green Lamp - ready
#define Relay_3  4  // Red Lamp - ALERT!
#define Relay_4  5  // Door actuator - not finished yet
void setup(){
  //-------( Initialize Pins so relays are inactive at reset)----
  digitalWrite(Relay_1, RELAY_OFF);
  digitalWrite(Relay_2, RELAY_OFF);
  digitalWrite(Relay_3, RELAY_OFF);
  digitalWrite(Relay_4, RELAY_OFF);
//---( THEN set pins as outputs )----
  pinMode(Relay_1, OUTPUT);
  pinMode(Relay_2, OUTPUT);
  pinMode(Relay_3, OUTPUT);
  pinMode(Relay_4, OUTPUT);
  delay(4000); //Check that all relays are inactive at Reset
  lcd.backlight();
  lcd.clear();
keypad.getKey();
case PRESSED:
lcd.println(eKey);
switch (eKey){
  lcd.clear();
digitalWrite(Relay_1, RELAY_OFF); //DISCONNETC THE SIREN IF THE PASSWORD IS CORRECT
digitalWrite(Relay_2, RELAY_ON);
digitalWrite(Relay_4, RELAY_ON);
delay(2000);
delay(100);
}else{
    lcd.clear();
lcd.clear();
WrongAttempts++;
digitalWrite(Relay_1, RELAY_ON); //START THE SIREN
digitalWrite(Relay_3, RELAY_ON); //START THE REDNESS
lcd.clear();
delay(100);
delay(100);
UKHeliBob
Why issue commands to set the relay pins low then define them as outputs ?
Much better with the meaningful names though.
morganlowe
Oops, forgot to take that out. Thanks for reminding me!
So umm... Any ideas on how to reset it?
PeterH
UKHeliBob
Leave the pinMode and digitalWrite commands in there but do them in the reverse order.
You have had my idea on how to reset the password when the user has been successful.  You do it when the user presses the '#' key
case '#': password.reset(); so why not when they get it right and the light show is triggered ?
morganlowe
#14
Feb 07, 2013, 07:54 am Last Edit: Feb 07, 2013, 07:58 am by morganlowe Reason: 1
OK, It's about done... I need to get rid of the funky weirdness on the display, maybe you guys could help with that?
I made a video of the pile of parts in action. I am still working on the door it's self, more to come later.
Here's the code again! I am using an RGB backlit display with a 2 wire I2C interface, a 4x4 Keypad and a 4 relay board. I have a fire alarm from a school that will be the siren and red and green 120v bulbs in cages for the indicator lights. Somewhere in my junk I have a magnetic door latch too.
Oh! Almost forgot.
Must come before
Or when it boots everything is turned on and that's a mess.
To do list:
1) Make the alarm only sound for 5 minutes. Just in case I put this to real use.
2) Make an enclosure and cable system so the board and relays can be inside the locked room with only the keypad and display outside. 8 wires for keypad, 6 for display with RGB LED. Thinking a couple of Cat5e cables.
3) Redundant Power Supply.
4) Weird things on display.
http://youtu.be/UNHlT6wiEhI
Here's the code right now, the green light shuts off when the red comes on!
#include <Keypad.h>
#include <Wire.h>
//  Credit goes to Arduino and it's wonderful community and morganlowe for the code and setup.
//  Digital Pins 2=relay 1; 3 = relay 2; 4 = relay 3; 5 = relay 4; 6-13 = keypad; SDA & SDL = corrosponding inputs for LCD
//  Analog Pins A2 and A3 Green and Blue for LCD
Password password = Password( "5466" );
 {'1','2','3','A'},
 {'4','5','6','B'},
 {'7','8','9','C'},
 {'*','0','#','D'}
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
#define RELAY_ON 0
#define RELAY_OFF 1
void setup(){
 pinMode(A2, OUTPUT);
 pinMode(A3, OUTPUT);
 lcd.backlight();
 lcd.clear();
lcd.println("Enter Password:");
 digitalWrite(A3, HIGH);
 digitalWrite(A2, LOW);
lcd.noBacklight(); // turn off red channel
keypad.getKey();
case PRESSED:
lcd.blink();
lcd.println(eKey);
switch (eKey){
 lcd.clear();
   digitalWrite(A3, LOW);
 digitalWrite(A2, HIGH);
 lcd.backlight();
lcd.blink();
lcd.blink();
password.reset();  //Reset Password
WrongAttempts = 0;  //Reset how many times it got screwed up
delay(5000);
lcd.clear();
lcd.backlight();
lcd.println("Armed!");
delay(3000);
lcd.clear();
lcd.blink();
delay(100);
}else{
   lcd.clear();
 lcd.backlight();
lcd.blink();
lcd.clear();
lcd.backlight();
 password.reset();
WrongAttempts++;
if (WrongAttempts >= 3) { //Trouble counter
lcd.clear();
lcd.backlight();
 password.reset();
 digitalWrite(Relay_2, RELAY_OFF); //turn off the good lamp
