Topic: timer printing and array of serial data issue (Read 913 times) previous topic - next topic
btricha2
I was wondering if you guys could help me solve an arduino Coding problem. I've simplified the code to highlight the issue that I'm having. I've created a program to read streaming serial data to an array. This array needs to be printed at a specific time interval, delays in this case are insufficient, and I have resorted to using timer.h which can be found here http://playground.arduino.cc/Code/Timer . My intention was to read to an array of size index, and increment index. When index becomes a value of 80, it is supposed to save the the array (inData) to another array("prntfd"). ("prntfd") is printed every 5 seconds. In this I hoped to decouple the serial timing, and the print timing of a serial data array.
Unfortunately the code only prints "c", and a print line. The code is below. Any insights would be much appreciated
//Sketch feeds serial data to array (inData) of size (index).
//A timer library is then used to print the data every 5 seconds
//debugs: a,b,c are inserted at various parts of the code.
//Serial data from inChar should print every 5 seconds just after C.
//Include timer libraries and serial library
#include <Event.h>
#include <Timer.h>
#include <NewSoftSerial.h>
//set serial pins, serial feed array "inData" and its index "index"
NewSoftSerial nss(3,4);
Timer t;
char inData[80];
static char prntfd[80];
int index = 0;
  nss.begin(9600);
  t.every(5000, takeReading);//set call time to function "take reading"
  t.update();
  char inChar = nss.read();
  if (index <(80))
    inData[index++] = inChar;
    inData[index] = '\0';
  else if (index == 80)
  inData == prntfd;
  index = 0;
void takeReading()
  Serial.println("c");
  Serial.println(prntfd);
PaulS
  if (index <(80))
Read and store a character, even if there is not one to read. Not the best idea I've seen this week.
Why is the 80 in parentheses?
takeReading() is an interrupt service routine. In interrupt service routines, interrupts are disabled. The Serial.print() function stores data in a buffer, and returns, immediately, if there is room in the buffer. If there is not, it blocks waiting for there to be room in the buffer. Since the buffer is not being emptied during an ISR, you should not be putting stuff into it in an ISR.
Bottom line: Do NOT call Serial.print(), Serial.println(), or Serial.write() in an ISR.
btricha2
Do you have any recommendations or direction for methods I might pursue to do what I am attempting?
btricha2
I ask b/c it would seem that it isn't possible to use interrupts to time outputs from the micro-controller. Here is an example from the library. Does it only work because any analog values are going to be lower than the 64 byte serial buffer?
    #include "Timer.h"
    Timer t;
    int pin = 13;
      pinMode(pin, OUTPUT);
      t.oscillate(pin, 100, LOW);
      t.every(1000, takeReading);
      t.update();
    void takeReading()
      Serial.println(analogRead(0));
Arrch
Using timer interrupts for printing a value every 5 seconds is overkill. The Blink without delay example demonstrates how to do something at an interval without blocking your code.
PaulS
Every 5 seconds, plus or minus how many milliseconds? Consider that it will take time to shift out all the data.
You could reduce that time by picking up the speed - 9600 is way too slow.
PeterH
In what way are they insufficient?
I only provide help via the forum - please do not contact me for private consultancy.
btricha2
Paul,
I am looking for something that doesn't rely on how long it takes to shift out the data. I realize that it does take time to shift out the data. i'm only looking to print every 10 seconds. That being said, it needs to be uncoupled from the the looping times, because (in my case) the looping times will vary
PeterH
So, code it so that the repeat interval is independent of the loop execution time.
