Loading...
Pages: [1]   Go Down
Author Topic: Arduino Duemilanove trying to talk to an Arduino Mega....  (Read 141 times)
Offline Offline
Newbie
View Profile
This should be a simple one for anyone but me...
What I'm trying to do:
Send data from the Due to the Mega via Serial, and show that the data is moving by having the Due send a $ chr to turn an LED on the Mega on, then 2 seconds later, send a # chr to turn it off.  LED is on Pin 8 of the Mega.
The problem:
This setup works, for the most part. It seems it is missing communication because the LED does not always toggle on, or off after 2 seconds. Sometimes it does, sometimes it doesn't.
Hardware:
Arduino Due Pin 0 (RX) TO Mega pin 1 (TX)
Arduino Due Pin 1 (TX) TO Mega pin 0 (RX)
Arduino Due GND to Mega GND
Arduino Due code:
Code:
void setup(){
void loop(){
Serial.print("$");
delay(2000);
Serial.print('#');
delay(2000);
Arduino Mega code:
Code:
void setup(){
  pinMode(8, OUTPUT);
void loop(){
  delay(1);
  if(Serial.read() == '$'){
    delay(1);
digitalWrite(8, HIGH);
    delay(1);
  if(Serial.read() == '#'){
    delay(1);
digitalWrite(8, LOW);
delay(1);
    delay(1);
Any thoughts?
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
In your if statements
Code:
you read a character from the serial buffer (without checking if there is one available BTW) and consume it. If the sent '#' is read in the first if, the second if will not see it. Same the other way around. So read the character and then check it:
Code:
if (Serial.available()) {
  byte c = Serial.read();
  if (c == '$') {
    // do your stuff
  } else if (c == '#') {
    // do other stuff
Logged
Offline Offline
Newbie
View Profile
That did it! Thank you very much!!
Also I learned something new!
Logged
Pages: [1]   Go Up
Print
Jump to:
