Topic: M2TKLIB Hello World with LiquidCrystal_I2C (Read 13428 times) previous topic - next topic
digimate
I am trying to use M2TKLIB with my I2C 20x4 LCD panel.   I tried modifying the hello world program to use the different library...
Code: [Select]
#include <Wire.h>
#include "M2tk.h"
#include "utility/m2ghlc.h"
LiquidCrystal_I2C lcd(0x3F,20,4);
M2_LABEL(hello_world_label, NULL, "Hello World!");
M2tk m2(&hello_world_label, NULL, NULL, m2_gh_lc);
 m2_SetLiquidCrystal(&lcd, 16, 2);
 m2.draw();
But I get the following errors
Quote
In file included from HelloWorld.cpp:29:0:
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghlc.h:27:27: fatal error: LiquidCrystal.h: No such file or directory
compilation terminated.
So I tried a simple change to m2ghlc.h
Code: [Select]
//#include <LiquidCrystal.h>
#include <Wire.h>
But more errors appear...
Quote
In file included from HelloWorld_for_m2tklib.cpp:29:0:
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghlc.h:31:26: error: variable or field 'm2_SetLiquidCrystal' declared void
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghlc.h:31:26: error: 'LiquidCrystal' was not declared in this scope
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghlc.h:31:41: error: 'lc_ptr' was not declared in this scope
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghlc.h:31:57: error: expected primary-expression before 'cols'
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghlc.h:31:71: error: expected primary-expression before 'rows'
HelloWorld_for_m2tklib.cpp: In function 'void setup()':
HelloWorld_for_m2tklib.cpp:40:34: error: 'm2_SetLiquidCrystal' was not declared in this scope
So I thought I had better ask before making matters worse :)
olikraus
The simple answer is, M2tklib does not support LiquidCrystal_I2C.
If you want to support LiquidCrystal_I2C, you need to locate "m2ghlc.cpp"
Replace LiquidCrystal with LiquidCrystal_I2C, but also replace all member function calls with the equivalent one from LiquidCrystal_I2C.
For example you will find:
Code: [Select]
    case M2_GFX_MSG_START:
      m2_gh_lc_cursor_y = 255;
      m2_lc_ptr->noCursor();
      m2_lc_ptr->noBlink();
      m2_lc_ptr->clear();
So, for noCursor() you need to find the corresponding function name to switch the cursor off.
Once this is done all your errors should go away.
Oliver
digimate
I was starting to come to that conclusion myself.   It seems that nearly all LCD libraries seem to target the non-I2C devices, so although I really like how the I2C display interfaces with only a couple of pins, it makes more work whenever I want to use a library like M2TKLIB.
Thanks for the help.
olikraus
Can you provide a link to the I2C lib? I will check if i can do the porting.
Oliver
digimate
olikraus
digimate
ok, thanks.
I have created issue 98 for this: http://code.google.com/p/m2tklib/issues/detail?id=98
Oliver
Much appreciated.  As a beginner, I wasn't sure of the situation with all the various libraries and hardware surrounding the Arduino.   It can all be a bit confusing, but all the support that is available is great.
olikraus
I added the New LiquidCrystal Library (https://bitbucket.org/fmalpartida/new-liquidcrystal/) as output engine to M2tklib.
A first beta release for the New LiquidCrystal Library is available for download: http://code.google.com/p/m2tklib/downloads/list
Oliver
digimate
Oliver
Thanks.  I just downloaded it and am trying to understand how to make the Hello World example work with my I2C display.  Firstly I had to include Wire.h to get it to compile.
Then I tried to convert it to I2C by including the different library and changing how the lcd object was created (and changing the setup to 20x4 from 16x2)
Code: [Select]
#include <Wire.h>
#include "M2tk.h"
#include "utility/m2ghnlc.h"
LiquidCrystal_I2C lcd(0x3F);
M2tk m2(&hello_world_label, NULL, NULL, m2_gh_nlc);
  m2_SetNewLiquidCrystal(&lcd, 20, 4);
  m2.draw();
This is producing these errors
Quote
In file included from HelloWorld.pde:42:
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghnlc.h:32: error: variable or field 'm2_SetNewLiquidCrystal' declared void
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghnlc.h:32: error: 'LCD' was not declared in this scope
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghnlc.h:32: error: 'lc_ptr' was not declared in this scope
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghnlc.h:32: error: expected primary-expression before 'cols'
/home/myhome/sketchbook/libraries/M2tklib/utility/m2ghnlc.h:32: error: expected primary-expression before 'rows'
HelloWorld:45: error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int)'
/home/myhome/sketchbook/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.h:57: note: candidates are: LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, uint8_t)
/home/myhome/sketchbook/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.h:55: note:                 LiquidCrystal_I2C::LiquidCrystal_I2C(const LiquidCrystal_I2C&)
HelloWorld.pde: In function 'void setup()':
HelloWorld:51: error: 'm2_SetNewLiquidCrystal' was not declared in this scope
So assuming I just don't understand :)  I thought it was time to ask advice.
olikraus
Hi
Well, as far as possible, i tested this release in my environment. So, this is what i did:
1. Install a fresh Arduino IDE (I have used 1.0.3)
2. Download LiquidCrystal_V1.2.1.zip from https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
  It is really important to use LiquidCrystal_V1.2.1.zip, which contains the base class LCD ( this was missing in on your PC).
3. In your installation directory, located the libraries folder. Extract LiquidCrystal_V1.2.1.zip in that folder. Among others
  this will overwrite the original LiquidCrystal Library.
4. Install m2tklib and update the example as you already did. Now it should compile.
Oliver
digimate
I got it to compile thanks.
Unfortunately, that library just doesn't work with my display.  Even their own HelloWorld_i2c example that comes with the Liquidcrystal library just produces a  flashing backlight.  The DFRobot library (and other libraries that I mentioned)  does work with my display, so they've done something different. However they  won't work with M2TKLIB because they lack things like LCD.h (I think). So I am stuck.
olikraus
Quote
I have added support for one of the libraries you mentioned in reply #4.
Oliver
digimate
My fault.  I was sure they all worked when I first tried them, maybe I had an earlier version, or a modified one. When I googled for examples for my previous post, that one came up and I assumed it was the same. I am currently using the DFRobot one at the moment and it definitely works.  I don't really understand how some can work, and others fail.  Must be varying hardware out there too.   Hopefully they will all eventually work as they iron out the bugs and add support for all the variations.
bperrybap
There is varying i2c to hd44780 hardware out there.
Some librarys are hard coded for a particular wiring/pin mapping and
some libraries like fm's allow the pin mapping to be configured.
So, In the case of fm's library the library is not the actual problem
but rather the problem comes down to the user properly filling in the constructor which configures the pin mappings
for the library.
fm's library has a default output pin mapping for how the wires/traces are connected
between the pcf8574 chip and the hd44780 interface.
It is unwise not to fill in the full constructor and use the default mappings since
different PCF8574 based boards wire up the connections differently.
The default pin mapping in the library is for fm's lcd i/o expander board
and many of the i2c based boards are not wired up the same way.
When the pin mapping is wrong/incorrect, the library will compile just fine,
but since it has been told the incorrect pin mappings, it will not be able to properly
initialize and drive the lcd.
Unfortunately, There is no way to have the library automatically detect the wiring
and automatically set up the pin mappings.
To ensure that i2c interface works with fm's library, it is best
to always properly fill in the full constructor which includes all the pin mappings rather than only fill
in the i2c address, which will cause the library use the pin mappings of fm's lcdio board, which is
different from many of the other i2c to hd44780 boards out there.
Plus, the default pin mappings do not include backlight control over the i2c interface since
fm's lcd i/o board does not support this.
If you fill in the full constructor, you can not only ensure that the pin mappings are correct,but
also configure the library for how to control the backlight over the i2c interface.
Oliver,
for m2tk how do you detect the different libraries to handle initialization?
i.e. different libraries use different initialization functions. Most call begin() and but some call init()
--- bill
digimate
for the library.
Well, thanks for filling me in on all that.  I know nothing about constructors, and I really feel I have jumped in the deep end here.   Still, it looks like there's hope of making it work, and I'm game to try.
I need to find out where and how to set up the pin mappings, and what they really should be.  I'll try looking the code and google, but if anyone can lead me in the right direction, that would help :) .
