Topic: I can't #include<EDB.h> library (Read 2222 times) previous topic - next topic
chairedevil
Feb 08, 2013, 09:53 am Last Edit: Feb 08, 2013, 10:12 am by chairedevil Reason: 1
I downloaded EDB library from http://code.google.com/p/arduino-edb/
and I use ARDUINO IDE 1.0.3
have error compile :
Quote
In file included from RFID_EEPROM.ino:5:
C:\Users\Admin\Desktop\arduino-1.0.3\libraries\EDB/EDB.h:43: error: expected initializer before '*' token
C:\Users\Admin\Desktop\arduino-1.0.3\libraries\EDB/EDB.h:54: error: 'EDB_Rec' has not been declared
C:\Users\Admin\Desktop\arduino-1.0.3\libraries\EDB/EDB.h:56: error: ISO C++ forbids declaration of 'EDB_Rec' with no type
C:\Users\Admin\Desktop\arduino-1.0.3\libraries\EDB/EDB.h:57: error: ISO C++ forbids declaration of 'EDB_Rec' with no type
C:\Users\Admin\Desktop\arduino-1.0.3\libraries\EDB/EDB.h:58: error: 'EDB_Rec' has not been declared
C:\Users\Admin\Desktop\arduino-1.0.3\libraries\EDB/EDB.h:68: error: expected ',' or '...' before '*' token
C:\Users\Admin\Desktop\arduino-1.0.3\libraries\EDB/EDB.h:68: error: ISO C++ forbids declaration of 'byte' with no type
C:\Users\Admin\Desktop\arduino-1.0.3\libraries\EDB/EDB.h:69: error: 'byte' has not been declared
C:\Users\Admin\Desktop\arduino-1.0.3\libraries\EDB/EDB.h:72: error: ISO C++ forbids declaration of 'EDB_Rec' with no type
sorry ,this's my code, I want to create table for make database in eeprom .So I import EDB library into my code and compile it for test.
Code: [Select]
#include <SoftwareSerial.h>
#include <EEPROM.h>
#include <EDB.h>
#define rxPin 2
#define txPin 3
char rfid_data[12];
char rfid_in[12];
int i, a, b, tmp, num;
SoftwareSerial RFID = SoftwareSerial(rxPin, txPin);
struct LogEvent {
  int id;
  int temperature;
logEvent;
  RFID.begin(9600);
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  Serial.println("1 = Register RFID Card");
  Serial.println("2 = Remove RFID Card");
  Serial.println("3 = Delete EEPROM Database");
  Serial.println("4 = List EEPROM Database");
  Serial.println("5 = Active Mode");
  do
    delay(200);
  } while (Serial.available() <= 0);
  num = Serial.read();
  Serial.print("Serial port Value : ");
  Serial.println(num);
  switch (num)
    case '1':
      RegisterCard();
    case '2':
      RemoveCard();
    case '3':
      EEPROM.write(0,0);
      Serial.println("Database Erased");
    case '4':
      ListDatabase();
    case '5':
      ActiveMode();
    case '0':
    default:
      Serial.println("Unknown Input");
void RegisterCard()
  // Read a card
  for (int rs = 0; rs < 13; rs++)
    rfid_data[rs] = '0';
  rfid_data[12] = '\0';
  digitalWrite(11, LOW);
  delay(200);
  do
    delay(200);
  } while (RFID.available() <= 0);
  digitalWrite(11, HIGH);
  delay(200);
  Serial.println("Reading Card");
  rfid_data[0] = RFID.read();
  if (int(rfid_data[12]) <= 12)
    for (i = 0; i < 12; i++)
      rfid_data[i] = RFID.read();
  RFID.flush();
  Serial.print("Registering Card: ");
  Serial.println(rfid_data);
  // Check if it's in the database
  a = EEPROM.read(0);
  if (a == 0)
    EEPROM.write(0,1);
    for (i = 1; i < 13; i++)
      EEPROM.write(i,rfid_data[i-1]);
    Serial.println("Card Registered in Database Successfully");
    // REMOVE START
    for (i = 0; i < 13; i++)
      rfid_data[i] = '0';
    // REMOVE END
    return;
  if (a == 100)
    Serial.println("100 Cards Reached, Register Failed");
    return;
  for (i = 0; i < a; i++)
    for (b = 1; b < 13; b++)
      rfid_in[b-1] = EEPROM.read((i*12)+b);
    b = 1;
    for (int c = 0; c < 12; c++)
      if (rfid_data[c] == rfid_in[c])
        b++;
    if (b == 12)
      Serial.println("Card Already Exists in Database");
      return;
  // Add to database
  tmp = 0;
  for (int d = (a*12)+1; d < (a*12)+13; d++)
    EEPROM.write(d,rfid_data[tmp]);
    tmp++;
  EEPROM.write(0,a+1);
  Serial.println("Complete");
  return;
void ListDatabase()
  a = EEPROM.read(0);
  Serial.print("Cards in database: ");
  Serial.println(a);
  if (a == 0)
    Serial.println("Database Empty");
    return;
    Serial.print("Card ");
    Serial.print(i);
    Serial.print(": ");
      Serial.write(EEPROM.read((i*12)+b));
  return;
void ActiveMode()
  // Read a card
  do
    delay(200);
  Serial.print("Checking Card: ");
  a = EEPROM.read(0);
  if (a == 0)
    Serial.println("Access Denied!");
    RFID.flush();
    return;
    b = 1;
        b++;
    if (b == 12)
      Serial.println("Access Granted!");
      RFID.flush();
      return;
  RFID.flush();
  return;
void RemoveCard()
  // Read a card
  do
    delay(200);
  RFID.flush();
  delay(800);
  Serial.print("Removing Card: ");
  a = EEPROM.read(0);
  if (a == 0)
    Serial.println("Not in Database");
    return;
    b = 1;
        b++;
    if (b == 12)
      int rmstrt = ((i*12)+b)-11;
      // Last in database?
      if ((a*12) == (rmstrt+11))
        EEPROM.write(0,a-1);
        Serial.println("Card Removed Successfully!");
        return;
      for (tmp = rmstrt+12; tmp < (a*12)+1; tmp++)
        char dta = EEPROM.read(tmp);
        delay(100);
        EEPROM.write(rmstrt,dta);
        rmstrt++;
      delay(100);
      return;
  Serial.println("Card Not in Database");
  return;
help me, please
thank you so much .
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
PaulS
The library at that link has not been undated for 1.0+ use. What changes did YOU make to it to make it work with 1.0.3?
nickgammon
It looks to me like you installed the library in the wrong place. You don't put stuff into the Arduino distribution folder. Read this:
http://arduino.cc/en/Guide/Libraries
