Topic: Simple counting problems (Read 839 times) previous topic - next topic
mrfunk
Feb 07, 2013, 12:41 pm Last Edit: Feb 07, 2013, 12:50 pm by Hackdub Reason: 1
I'm constructing a device which measures an analogue input.
when the analogue input is below a threshold, an output goes high once, until the analogue input goes above a threshold.
int sensorPin = A0; // select the input pin for the detector
unsigned int count = 0;
byte latch = 0;  //initial variable
unsigned int sensorValue = 0;  // variable to store the value coming from the detector
 pinMode(13, OUTPUT);
 //Start Serial port
count=0;
 // read the value from the soil detector:
 sensorValue = analogRead(sensorPin);
 if(count==0&&sensorValue<500)
 digitalWrite(13, HIGH);
 delay(1000); // 1 second delay
 ++count;// this increments the count by 1
 Serial.println(sensorValue);
 Serial.println(count);
 digitalWrite(13, LOW);
if(sensorValue>600)
count=0;
The problems I have..
the count variable displays a "1" when held high.... and when running, why isn't it 0 as per initialisation.
When taking A0 low the count keeps incrementing, ignoring the "count==0", why not just +1,
When taking A0 HIGH the count displays a "1" not 0 ?
thanks for any help
David
AWOL
That's the extent of your conditional code, everything else is executed unconditionally.
I'm not sure if that's what you intended.
mrfunk
No thats not what I want..
If the condition is met.
I want the pin to go high , ++count,then go low after a time..
Is this a bracket issue?
or lack of else?
is it only the line directly below the condition that is linked, and how do i add more...
Sorry for the dumb questions, but this is driving me mad, that i'm missing the obvious.
David
johncc
#3
Feb 07, 2013, 01:10 pm Last Edit: Feb 07, 2013, 01:12 pm by johncc Reason: 1
Yes
if (condition)
  statement;
where statement is either one line like
  digitalWrite( 13, HIGH);
or multiple like
      count++;
      ... etc
http://arduino.cc/en/Reference/If
Cheers,
John
mrfunk
Thanks John.. Ive tried that.
now its not incrementing... :-(
int count = 0;
//byte latch = 0;  //initial variable
  //Start Serial port
  if(count=0&&sensorValue<500)
    {digitalWrite(13, HIGH);
      delay(5000); // 5 second delay
      count++;// this increments the count by 1
    digitalWrite(13, LOW);}
if(sensorValue>600)
{count=0;
delay(2000);}
AWOL
Maybe it is, but you're just not waiting long enough to see the result.
On second thoughts, you're right, it will never increment
if(count=0
mrfunk
Nearly done..
its counting correctly, but no LED output .!
int count = 0;
const int LED = 4;
  pinMode(LED, OUTPUT);
  //Start Serial port
  // read the value from thedetector:
    {digitalWrite(LED, HIGH);
    digitalWrite(LED, LOW);}
  count++;
if(sensorValue>600)
{count=0;
delay(2000);
//digitalWrite(LED, LOW);
AWOL
if(count=0
unconditionally
mrfunk
BINGO! tx..
for some--- we need to learn the hard way ;-)
PaulS
Istheresomethingwrongwithyourspacekey?
would be heck of a lot easier to parse as
  if(count = 0 && sensorValue < 500)
Therefore, it would be a lot simpler to spot the mistake.
