Loading...
Pages: 1 2 [3]   Go Down
Author Topic: mpu6050 problem  (Read 2362 times)
Indiana
Offline Offline
Jr. Member
View Profile
No problem, I am new to all this too, and just got my first Arduino and MPU6050 sensor a few weeks ago, so this is all very fresh in my mind on exactly how to get it all working. :-) Glad I could help.
Logged
Offline Offline
Sr. Member
View Profile
You're helping me a lot! ok, i changed my sketch in this:
Code:
#include "Wire.h"
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
//#include "MPU6050.h" // not necessary if using MotionApps include file
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for SparkFun breakout and InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 mpu;
   NOTE: In addition to connection 3.3v, GND, SDA, and SCL, this sketch
   depends on the MPU-6050's INT pin being connected to the Arduino's
   external interrupt #0 pin. On the Arduino Uno and Mega 2560, this is
   digital I/O pin 2.
   NOTE: Arduino v1.0.1 with the Leonardo board generates a compile error
   when using Serial.write(buf, len). The Teapot output uses this method.
   The solution requires a modification to the Arduino USBAPI.h file, which
   is fortunately simple, but annoying. This will be fixed in the next IDE
   release. For more info, see these links:
   http://arduino.cc/forum/index.php/topic,109987.0.html
   http://code.google.com/p/arduino/issues/detail?id=958
// uncomment "OUTPUT_READABLE_QUATERNION" if you want to see the actual
// quaternion components in a [w, x, y, z] format (not best for parsing
// on a remote host such as Processing or something though)
//#define OUTPUT_READABLE_QUATERNION
// uncomment "OUTPUT_READABLE_EULER" if you want to see Euler angles
// (in degrees) calculated from the quaternions coming from the FIFO.
// Note that Euler angles suffer from gimbal lock (for more info, see
// http://en.wikipedia.org/wiki/Gimbal_lock)
//#define OUTPUT_READABLE_EULER
// uncomment "OUTPUT_READABLE_YAWPITCHROLL" if you want to see the yaw/
// pitch/roll angles (in degrees) calculated from the quaternions coming
// from the FIFO. Note this also requires gravity vector calculations.
// Also note that yaw/pitch/roll angles suffer from gimbal lock (for
// more info, see: http://en.wikipedia.org/wiki/Gimbal_lock)
#define OUTPUT_READABLE_YAWPITCHROLL
// uncomment "OUTPUT_READABLE_REALACCEL" if you want to see acceleration
// components with gravity removed. This acceleration reference frame is
// not compensated for orientation, so +X is always +X according to the
// sensor, just without the effects of gravity. If you want acceleration
// compensated for orientation, us OUTPUT_READABLE_WORLDACCEL instead.
#define OUTPUT_READABLE_REALACCEL
// uncomment "OUTPUT_READABLE_WORLDACCEL" if you want to see acceleration
// components with gravity removed and adjusted for the world frame of
// reference (yaw is relative to initial orientation, since no magnetometer
// is present in this case). Could be quite handy in some cases.
//#define OUTPUT_READABLE_WORLDACCEL
// uncomment "OUTPUT_TEAPOT" if you want output that matches the
// format used for the InvenSense teapot demo
//#define OUTPUT_TEAPOT
and now I'm reciving this:
Code:
Initializing I2C devices...
Testing device connections...
MPU6050 connection successful
Send any character to begin DMP programming and demo:
Initializing DMP...
Enabling DMP...
Enabling interrupt detection (Arduino external interrupt 0)...
DMP ready! Waiting for first interrupt...
ypr 0.09 -2.43 8.77
areal -111 379 2561
ypr 0.07 -2.45 8.82
areal -144 464 3145
ypr 0.05 -2.46 8.86
areal -163 524 3579
ypr 0.03 -2.48 8.91
areal -174 562 3896
Is ypr about the gyroscope? Howerever the areal values are still strange...
Logged
Indiana
Offline Offline
Jr. Member
View Profile
Yaw/pitch/roll is presumably found by a fusion algorithm contained within the DMP, so it uses both the gyroscope and accelerometer to determine the yaw/pitch/roll.    Remember, the gyroscope does not actually determine angular position, but it measures angular velocity.  To determine angular position from angular velocity, one must integrate the values over time from the gyroscope to find position.  This introduces error, because of noise and imperfection in the sensor.  The accelerometer should always read 1G of force in the Z direction when the Z-axis is normal to the ground plane.  With this information you can also use an accelerometer to determine angular position, but accelerometers are very noisy so their data alone is not great either.  But the fused algorithm presumably is much better.
Logged
Offline Offline
God Member
View Profile
To get that fancy display to work,   you need to have the "Processing" working on your computer,   and then find some libraries for it.
I don't recall all the details now,  but it was quite a hassle to get it to work.
Logged
Indiana
Offline Offline
Jr. Member
View Profile
oh, also, the accelerometer values, I forget what units they are in, but they are not in G by default.  I don't recall what it was, but I had to convert it by dividing by 28xx(don't remember what "xx" values are).  My conversion and code are at home, I will look for it later.  If you don't need an EXACT value now, just let the sensor sit still and take an average value of the Z axis (make sure the sensor is as flat as possible).  This value should be about equal to 1G of accleration, so use that number to divide all of your accelerometer values before printing them to the serial port and they will be in G's.
Logged
Indiana
Offline Offline
Jr. Member
View Profile
You don't need processing to get the display in the video I posted.  That is C# code I wrote and OpenTK rendering the cube based on the yaw/pitch/roll values output from the sensor.  It did take a decent amount of work getting it working, only because I had never tried 3D rendering before so I had to learn about that and the different libraries out there and finally chose OpenTK (which is free).
Logged
Offline Offline
Sr. Member
View Profile
I found the toxi libraries for the processing sketch. But I'm still not understanding how to convert the raw values to the real position of my board on the space and if it's possible. Can you explain this to me?
Logged
Indiana
Offline Offline
Jr. Member
View Profile
What exactly are you looking for?  Accelerometers measure acceleration, and gyro's measure angular velocity.  With the code that you have, you can get yaw/pitch/roll, and acceleration.  If you are looking position as well as orientation, you will need another sketch, or to do your own math's on the data from the sensors.  Position can be found by integrating velocity, which can be found by integrating acceleration. Ideally you will want to use a fused data algorithm for this and not the direct data from just the accelerometer.  A complimentary or Kalman filter is probably your best best.
Logged
Offline Offline
Sr. Member
View Profile
Thank you. for the reply. Yes, I don't need the angular velocity. Have you some code about fused data algorithm? On Google I didn't find anything about arduino...
Logged
Indiana
Offline Offline
Jr. Member
View Profile
Here is a thread in this forum about it:
http://arduino.cc/forum/index.php/topic,58048.0.html
Search FreeIMU on google and download the library.  The fused algorithm there is completely open-source so you can try to decipher it yourself.  It does not include code to calculate position though, so you will need to look elsewhere for position sensing.
Logged
Offline Offline
Sr. Member
View Profile
jjspierx can you post the code of your cube? The processing sketch doesn't work... maybe with yours i'll be more lucky!
Logged
Indiana
Offline Offline
Jr. Member
View Profile
My code is not for Arduino.  It is a C# project written in Visual Studio 2012 with OpenTK library used for openGL rendering in 3D.  The C# program opens the COM port that arduino uses and reads the lines as they come in.  If you have Visual Studio 2012 and have a basic understanding of OpenGL and 3D rendering, you might be able to get my C# project to work on your computer, otherwise you are probably better off trying to get the processing code to work.
Logged
Offline Offline
Sr. Member
View Profile
mmmh... I think it's too difficult for me smiley-mr-green
Logged
Offline Offline
Sr. Member
View Profile
I'm still having problems whit the processing sketch. I see only three green lines whit a red point in the middle of these... smiley-roll Can anyone help me?
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
