Author Topic: "Send" PC -> Arduino via Bluetooth  (Read 318 times)
Hello,
I have an Arduino Uno, and this bluetooth module
http://www.lctech-inc.com/Hardware/Detail.aspx?id=25662aa3-0517-4d3d-960e-ff261d5ef28c
I am trying to understand nature of PC->Arduino, Arduino->PC by bluetooth, in order to implement it in my program.
My Arduino sends to my PC Serial monitor all commands correctly no problem by bluetooth. (Arduino IDE 1.0.3)
However, the problem is that i am unable to send data from PC->Arduino via Bluetooth .
I am able to do send data PC->Arduino via USB.
I am using "toggle LED on/off" to test it.
Tried using SoftwareSerial.h , no luck.
Rabee
Seattle, WA USA
Seattle, WA USA
Did you just tape the BT module to the Arduino?
Do you mean if I changed factory settings modes ? (the slave/master) ?
Seattle, WA USA
Seattle, WA USA
We've hired a psychic to help out when people do not describe the hardware that they have, how it is connected to the Arduino, or what code is running on the Arduino.
His start data is the 12th of never. Can you wait that long, or do you maybe have an idea what you need to do?
Arduino Uno R2.
LED is on pin 13
My bluetooth module is on 3.3V/GND, and digital pins (0,1) rx,tx
Arduino operating on 9V adapter, and using my Toshiba's laptop bluetooth stack, COM40
as for my code
byte byteRead;
  pinMode(13,OUTPUT);
  if (Serial.available()) {
    byteRead = Serial.read();
    digitalWrite(13,HIGH);
Refresh
Dee Why NSW
I have the same module, I think. I have been sitting on this for a while. I think your problem may be in the first line. Try it.
int incomingByte = 0;   // for incoming serial data
        Serial.begin(9600);     // opens serial port, sets data rate to 9600 bps
        // send data only when you receive data:
        if (Serial.available() > 0) {
                // read the incoming byte:
                incomingByte = Serial.read();
                // say what you got:
                Serial.print("I received: ");
                Serial.println(incomingByte, DEC);
Nope same problem, i don't get any response on Arduino's Serial moniter when i enter something
Same code works over USB
I believe it is a connectivity error , as even if i try the "AT" commands, i get no response from the module.
As i mentioned before , i have it connected on Toshiba Bluetooth stack, COM40, and i can only recieve data programmed from arduino, obviously sending from PC-module-arduino is going wrong
Queens, New York
Online Online
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
Dont use the serial monitor to send things over bluetooth, it doesn't work. Use either Putty or hyperterminal. Setup your COM channel and see if they connect. Do a simple message to like "I have connected to the PC", ok. Then try to read something from the PC. NOTE you will not see what you enter unless you echo the input, back to the monitor.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Thanks for reply
Tried it over COM4 (USB) on Putty and it gives me back a message
Then I switch to COM40 (Bluetooth) , don't get any messages
Queens, New York
Online Online
Do you know if your computer pairs with the BT module? Do you know what the factory baud rate is?
Edit: did you cross connect the Rx and Tx pins? Also when you did pair it, (if you got it to pair correctly), did you get another COM number?
« Last Edit: February 12, 2013, 03:36:17 pm by HazardsMind » Logged
Baud rate is 9600, but also tried other common Bluetooth rates
I do not get the device in the "devices and printers" , but i get it in the Toshiba Bluetooth stack as a connected and paired device
Hence i can receive data from it, but can't send to it
Any ideas guys ?
