« on: February 07, 2013, 03:12:16 pm » |
Hello, I have an Arduino Uno, and this bluetooth module http://www.lctech-inc.com/Hardware/Detail.aspx?id=25662aa3-0517-4d3d-960e-ff261d5ef28cI am trying to understand nature of PC->Arduino, Arduino->PC by bluetooth, in order to implement it in my program. My Arduino sends to my PC Serial monitor all commands correctly no problem by bluetooth. (Arduino IDE 1.0.3) However, the problem is that i am unable to send data from PC->Arduino via Bluetooth . I am able to do send data PC->Arduino via USB. I am using "toggle LED on/off" to test it. Tried using SoftwareSerial.h , no luck. Rabee
Seattle, WA USA
Seattle, WA USA
« Reply #1 on: February 07, 2013, 05:47:45 pm » |
Did you just tape the BT module to the Arduino?
« Reply #2 on: February 07, 2013, 06:05:47 pm » |
Do you mean if I changed factory settings modes ? (the slave/master) ?
Seattle, WA USA
Seattle, WA USA
« Reply #3 on: February 07, 2013, 06:08:32 pm » |
Do you mean if I changed factory settings modes ? (the slave/master) ? We've hired a psychic to help out when people do not describe the hardware that they have, how it is connected to the Arduino, or what code is running on the Arduino. His start data is the 12th of never. Can you wait that long, or do you maybe have an idea what you need to do?
« Reply #4 on: February 07, 2013, 06:32:14 pm » |
Do you mean if I changed factory settings modes ? (the slave/master) ? We've hired a psychic to help out when people do not describe the hardware that they have, how it is connected to the Arduino, or what code is running on the Arduino. His start data is the 12th of never. Can you wait that long, or do you maybe have an idea what you need to do? Arduino Uno R2. LED is on pin 13 My bluetooth module is on 3.3V/GND, and digital pins (0,1) rx,tx Arduino operating on 9V adapter, and using my Toshiba's laptop bluetooth stack, COM40 as for my code byte byteRead; void setup() { Serial.begin(9600); pinMode(13,OUTPUT); } void loop() { if (Serial.available()) { byteRead = Serial.read(); digitalWrite(13,HIGH); } }
« Reply #5 on: February 11, 2013, 01:00:36 pm » |
Refresh
Dee Why NSW
« Reply #6 on: February 11, 2013, 05:52:48 pm » |
I have the same module, I think. I have been sitting on this for a while. I think your problem may be in the first line. Try it. int incomingByte = 0; // for incoming serial data
void setup() { Serial.begin(9600); // opens serial port, sets data rate to 9600 bps }
// send data only when you receive data: if (Serial.available() > 0) { // read the incoming byte: incomingByte = Serial.read();
// say what you got: Serial.print("I received: "); Serial.println(incomingByte, DEC); } }
« Reply #7 on: February 12, 2013, 10:59:50 am » |
// say what you got: Serial.print("I received: "); Serial.println(incomingByte, DEC); } } Nope same problem, i don't get any response on Arduino's Serial moniter when i enter something Same code works over USB I believe it is a connectivity error , as even if i try the "AT" commands, i get no response from the module. As i mentioned before , i have it connected on Toshiba Bluetooth stack, COM40, and i can only recieve data programmed from arduino, obviously sending from PC-module-arduino is going wrong
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
« Reply #8 on: February 12, 2013, 11:10:37 am » |
Dont use the serial monitor to send things over bluetooth, it doesn't work. Use either Putty or hyperterminal. Setup your COM channel and see if they connect. Do a simple message to like "I have connected to the PC", ok. Then try to read something from the PC. NOTE you will not see what you enter unless you echo the input, back to the monitor.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
« Reply #9 on: February 12, 2013, 02:32:49 pm » |
Thanks for reply Tried it over COM4 (USB) on Putty and it gives me back a message Then I switch to COM40 (Bluetooth) , don't get any messages
Queens, New York
« Reply #10 on: February 12, 2013, 03:27:02 pm » |
Do you know if your computer pairs with the BT module? Do you know what the factory baud rate is?
Edit: did you cross connect the Rx and Tx pins? Also when you did pair it, (if you got it to pair correctly), did you get another COM number?
« Last Edit: February 12, 2013, 03:36:17 pm by HazardsMind »
« Reply #11 on: February 12, 2013, 03:39:51 pm » |
Baud rate is 9600, but also tried other common Bluetooth rates I do not get the device in the "devices and printers" , but i get it in the Toshiba Bluetooth stack as a connected and paired device Hence i can receive data from it, but can't send to it
« Reply #12 on: February 14, 2013, 10:38:55 am » |
Any ideas guys ?
