Topic: Arduino Mega 2560 UART with other device (Read 1 time) previous topic - next topic
JonathanLaw
Mar 05, 2013, 05:11 pm Last Edit: Mar 05, 2013, 05:15 pm by JonathanLaw Reason: 1
I'm new to arduino and having Arduino Mega 2560 with me,
I wish to connect Arduino with below device using UART.
http://www.cytron.com.my/viewProduct.php?pcode=SKPS&name=PS2%20Controller%20Starter%20Kit
User manual can be found in above website,
Seems complicated because there are three RX and TX pin available in Arduino Mega 2560,
Anyone here can help me in establish UART coding?
I found some useful code but not works for my project
Code: [Select]
  Serial.begin(9600);      //Set serial baud rate as 9600
  Serial.flush();          //Waits for the transmission of outgoing serial data to complete.
  //Set the mode for each digital pins whether input or output
  pinMode(rx, INPUT);
  pinMode(tx, OUTPUT);
unsigned char receive_data(void)  //Function to wait for a byte receive from UART
  unsigned char temp;
  while(!Serial.available());    //Wait until data received
  temp=Serial.read();
  return temp;                    //Return the received data
unsigned char skps(unsigned char data) //Function to send out a byte via UART
  Serial.write(data);             //Send new data
  return receive_data();          //Return received data
PeterH
The global object Serial represents the hardware UART that is connected to USB.
On Arduinos with additional UARTs, additional objects Serial1 etc are declared to access them. I will leave it to you to work out which object corresponds to which physical connector on your board.
