Loading...
Pages: [1]   Go Down
Author Topic: using wavecom gsm modem with Arduino  (Read 508 times)
Offline Offline
Newbie
View Profile
Hi everyone. I am a newbie to the forum as well as Arduino (electronics too).
I am trying to communicate with wavecom using arduino for basic gsm functionality. I am sure this is not the first post on this but none helped me. I tried connecting modem directly to the computer and it worked using PUTTY application.
1) rs232 / ttl converter
2) rs232 male to male connector
3)wavecom gsm modem(its fmade by fargo telecom and is wavecom compatible)
4)arduino
Connections
Arduino and rs232/ttl converter
- digital port 2 to tx of converter
- port 3 to rx of converter
- 5v n ground of converter left unconnected
Gsm modem led is blinking indicating connected to network.
Here's the arduino code
Code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3); // RX, TX
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("ATD9620243969;");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
Gsm modem works with 9600 by default  (or 115200 if set using AT command) .
Logged
NE PA
Offline Offline
Full Member
View Profile
WWW
What are you having trouble with? What output are you and aren't you getting?
Logged
Maine
Offline Offline
Sr. Member
Caution: Explosives in use.
View Profile
WWW
Are you sure that the modem can be powered by 5v? That big inline fuse looks like the sort of thing one would see on a 12v automotive supply.
Logged
"Anyone who isn't confused really doesn't understand the situation."
Arduino-based airsoft props -> www.nightscapetech.com
Denmark
Offline Offline
God Member
View Profile
WWW
Quote
You have to connect the grounds
Logged
Offline Offline
Newbie
View Profile
@Quick5pnt0
I am trying to call a mobile phone using AT command ATD9620243969; .
@wizdum
Gsm modem I am using operates between 5v to 35v. I tried connecting directly to pc using rs232 to usb converter but arduino as power source just like above and it works.LED blinks when sim is inserted indicating connected to home network.
@Erni
I tried connecting to ground but no luck.
Logged
Offline Offline
Newbie
View Profile
1) The Wavcomm will want a 12V supply - it SAYS it runs from 5V upwards but you want 12V believe me
2) The USB supply cannot possibly power the arduino and the Wavcomm together. You need seperate 12v supply for the Wavcomm and as others have said connect the grounds together.
You still haven't said what is/isnt working either
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Noo no no no. Go back to hoofie's or quick5ptn0's question. What do you expect and what have you seen instead?
I recommend going even further back: connect the modem directly to a pc and use terminal program to send AT command. You don't need arduino and its added complexity to bog you down. Connect to PC and send that command. It should reply something, righ? Like OK?
Logged
Offline Offline
Newbie
View Profile
Aim of the project is to do a webpage request using gsm module from arduino.To start with I am trying to call a mobile number using AT command.
I have tried connecting modem to pc directly usinf rs232 to usb converter and able to communicate with modem .I am able call and send sms to a phone number.
I tried connecting Wavecom to 12v. I am receiving continuous random characters on Serial monitor ( not sure whether incorrect baud rate or wire loose connection).I have ttl/rs232 converter between modem and arduino. Removing just the modem with converter connected still gives same output.
Logged
Spain
Offline Offline
God Member
Arduino rocks
View Profile
Hello
Your code does not have waits, does not have initializations, does not verify the condition of the network, does not verify the pin.
You need a protocol.
And, of course a null modem crossover cable.
A strong 12v. power supply (about 1A)
You need to take a look at wavecom manual and AT+ commands
http://www.sendsms.com.cn/download/Fastrack_M1306B_User_Guide_rev003.pdf
http://www.ozeki.hu/attachments/588/wavecom_command.pdf
An Example to begin:
Code:
/*  Example 26.2  GSM shield making and ending a telephone call
http://tronixstuff.com/tutorials > chapter 26 */
#include <NewSoftSerial.h>
//Include the NewSoftSerial library to send serial commands to the cellular module.
NewSoftSerial cell(2,3);  //Create a 'fake' serial port. Pin 2 is the Rx pin, pin 3 is the Tx pin.
{  //Initialize serial ports for communication.
cell.begin(9600);
delay(25000); // give the GSM module time to initialise, locate network etc.
// this delay time varies. Use example 26.1 sketch to measure the amount
// of time from board reset to SIND: 4, then add five seconds just in case
cell.println("ATDxxxxxxxxx"); // dial the phone number xxxxxxxxx
// change xxxxxxx to your desired phone number (with area code)
delay(20000); // wait 20 seconds.
cell.println("ATH"); // end call
do // remove this loop at your peril
{    delay(1);  }
while (1>0);
« Last Edit: February 08, 2013, 05:54:28 am by Heke » Logged
CUIDADO !! MIS POST NO SON APTOS PARA MENORES. SI ERES MENOR DE 14 AÑOS DEBES DE LEERLOS ACOMPAÑADO DE UN ADULTO
En diseño te tienen que gustar más las preguntas que las respuestas [.Jray.]
Si estas empezando:
1- Comienza a usar Arduino
2- Guías de iniciación a Arduino
3- Ejemplos
4- Referencia del Lenguaje
5- Conceptos básicos
6- Guia de usuario de arduino
UK
Offline Offline
Tesla Member
View Profile
It seems to me that you have taken reasonable steps to confirm that the modem works OK from a direct RS232 connection to a PC, and that it is powered adequately from the Arduino. The sketch looks reasonable. It should send a command to the modem at startup and also forward anything you type into the serial monitor to the modem, and forward any responses from the modem back to the serial monitor. That seems like a reasonable setup.
I suspect the problem is that the Arduino has not got successful serial comms with the modem. You need to have the correct serial settings (speed, start bits, stop bits, parity) and the correct cable. There are two types of serial cable and you will need the right one. A straight cable connects all the pins at one end to the same pins on the other end. A crossover cable connects pin 2 to pin 3 and vice versa. You can achieve the same effect by swapping the Rx and Tx connections between the Arduino and TTL/RS232 converter. If you don't know which one you need, try both ways.
You did not confirm that you saw "Goodnight moon!" on the serial monitor. Did that display as expected?
Logged
Offline Offline
Newbie
View Profile
@PeterH
Yes "Goodnight moon!" is printed on screen
Logged
Pages: [1]   Go Up
Print
Jump to:
