France
Offline
Sr. Member
« on: February 07, 2013, 11:05:50 pm » |
I'm new to Github (just created an account) as well as updating firmware, never done it so far so would like testing this new firmware. Could someone provide detailed steps so i can I update this firmware from my Macintosh and/or my spare arduino MEGA interfaced with arduino DUE ? Thank you in advance, Albert
« Last Edit: February 07, 2013, 11:32:00 pm by selfonlypath »
Logged
France
Offline
Sr. Member
« Reply #1 on: February 11, 2013, 03:33:01 am » |
I've been able to finally install Macports and DFU-programmer on my old iMac G5 running under Tiger following these instructions http://arduino.cc/en/Hacking/DFUProgramming8U2Now it seems that atmega16u2 does not appear on the list, can someone tell me what is exactly arduino DUE device port name so I can proceed on upgrading the USB firmware Here are extract of my Terminal shell showing where i'm stuck, Thanks new-host:~ selfonlypath$ sudo dfu-programmer at90usb82 erase dfu-programmer: no device present. new-host:~ selfonlypath$ sudo dfu-programmer atmega16u2 erase dfu-programmer 0.5.4 Usage: dfu-programmer target command [command-options] [global-options] [file|data] targets: at89c51snd1c at89c51snd2c at89c5130 at89c5131 at89c5132 at90usb1287 at90usb1286 at90usb1287-4k at90usb1286-4k at90usb647 at90usb646 at90usb162 at90usb82 atmega32u6 atmega32u4 atmega32u2 atmega16u4 atmega8u2 at32uc3a0128 at32uc3a1128 at32uc3a0256 at32uc3a1256 at32uc3a0512 at32uc3a1512 at32uc3a0512es at32uc3a1512es at32uc3a364 at32uc3a364s at32uc3a3128 at32uc3a3128s at32uc3a3256 at32uc3a3256s at32uc3b064 at32uc3b164 at32uc3b0128 at32uc3b1128 at32uc3b0256 at32uc3b1256 at32uc3b0256es at32uc3b1256es at32uc3b0512 at32uc3b1512 at32uc3c064 at32uc3c0128 at32uc3c0256 at32uc3c0512 at32uc3c164 at32uc3c1128 at32uc3c1256 at32uc3c1512 at32uc3c264 at32uc3c2128 at32uc3c2256 at32uc3c2512 global-options: --quiet, --debug level commands: configure {BSB|SBV|SSB|EB|HSB} [--suppress-validation] [global-options] data dump [global-options] dump-eeprom [global-options] dump-user [global-options] erase [--suppress-validation] [global-options] flash [--suppress-validation] [--suppress-bootloader-mem] [global-options] {file|STDIN} flash-eeprom [--suppress-validation] [global-options] {file|STDIN} flash-user [--suppress-validation] [global-options] {file|STDIN} get {bootloader-version|ID1|ID2|BSB|SBV|SSB|EB| manufacturer|family|product-name| product-revision|HSB} [global-options] getfuse {LOCK|EPFL|BOOTPROT|BODLEVEL|BODHYST| BODEN|ISP_BOD_EN|ISP_IO_COND_EN| ISP_FORCE} [global-options] setfuse {LOCK|EPFL|BOOTPROT|BODLEVEL|BODHYST| BODEN|ISP_BOD_EN|ISP_IO_COND_EN| ISP_FORCE} [global-options] data reset [global-options] start [global-options] version [global-options] new-host:~ selfonlypath$ sudo dfu-programmer atmega16u4 erase dfu-programmer: no device present. new-host:~ selfonlypath$ sudo dfu-programmer atmega16u4 flash Arduino-DUE-usbserial-prod-firmware-2013-02-05.hex dfu-programmer: no device present. Arduino-DUE-usbserial-prod-firmware-2013-02-05.hex MacPorts-2.1.3.pkg new-host:~/desktop selfonlypath$ sudo dfu-programmer atmega16u4 flash Arduino-DUE-usbserial-prod-firmware-2013-02-05.hex dfu-programmer: no device present. new-host:~/desktop selfonlypath$ sudo dfu-programmer atmega16u2 erasedfu-programmer 0.5.4 Usage: dfu-programmer target command [command-options] [global-options] [file|data] targets: at89c51snd1c at89c51snd2c at89c5130 at89c5131 at89c5132 at90usb1287 at90usb1286 at90usb1287-4k at90usb1286-4k at90usb647 at90usb646 at90usb162 at90usb82 atmega32u6 atmega32u4 atmega32u2 atmega16u4 atmega8u2 at32uc3a0128 at32uc3a1128 at32uc3a0256 at32uc3a1256 at32uc3a0512 at32uc3a1512 at32uc3a0512es at32uc3a1512es at32uc3a364 at32uc3a364s at32uc3a3128 at32uc3a3128s at32uc3a3256 at32uc3a3256s at32uc3b064 at32uc3b164 at32uc3b0128 at32uc3b1128 at32uc3b0256 at32uc3b1256 at32uc3b0256es at32uc3b1256es at32uc3b0512 at32uc3b1512 at32uc3c064 at32uc3c0128 at32uc3c0256 at32uc3c0512 at32uc3c164 at32uc3c1128 at32uc3c1256 at32uc3c1512 at32uc3c264 at32uc3c2128 at32uc3c2256 at32uc3c2512 global-options: --quiet, --debug level commands: configure {BSB|SBV|SSB|EB|HSB} [--suppress-validation] [global-options] data dump [global-options] dump-eeprom [global-options] dump-user [global-options] erase [--suppress-validation] [global-options] flash [--suppress-validation] [--suppress-bootloader-mem] [global-options] {file|STDIN} flash-eeprom [--suppress-validation] [global-options] {file|STDIN} flash-user [--suppress-validation] [global-options] {file|STDIN} get {bootloader-version|ID1|ID2|BSB|SBV|SSB|EB| manufacturer|family|product-name| product-revision|HSB} [global-options] getfuse {LOCK|EPFL|BOOTPROT|BODLEVEL|BODHYST| BODEN|ISP_BOD_EN|ISP_IO_COND_EN| ISP_FORCE} [global-options] setfuse {LOCK|EPFL|BOOTPROT|BODLEVEL|BODHYST| BODEN|ISP_BOD_EN|ISP_IO_COND_EN| ISP_FORCE} [global-options] data reset [global-options] start [global-options] version [global-options] new-host:~/desktop selfonlypath$
Logged
France
Offline
Sr. Member
« Reply #2 on: February 12, 2013, 03:41:26 am » |
Well i've just installed the latest Xcode 4.6 running on Mac OS Lion so have now the latest DFU-programmer from macports http://www.macports.org/install.php#pkg but see below my terminal Shell results, it does NOT know atmega16u8 Maybe it is available on PC but right now, if really the DUE has the atmega16u2, can't erase it neither flash new firmware on the USB chip from a Macintosh. It would nice someone provides the port device name handling the USB on arduino DUE, confirm it is atmega16u2 ! Thank, Albert new-host:~ selfonlypath$ sudo dfu-programmer atmega16u2 erase dfu-programmer 0.5.4 Usage: dfu-programmer target command [command-options] [global-options] [file|data] targets: at89c51snd1c at89c51snd2c at89c5130 at89c5131 at89c5132 at90usb1287 at90usb1286 at90usb1287-4k at90usb1286-4k at90usb647 at90usb646 at90usb162 at90usb82 atmega32u6 atmega32u4 atmega32u2 atmega16u4 atmega8u2 at32uc3a0128 at32uc3a1128 at32uc3a0256 at32uc3a1256 at32uc3a0512 at32uc3a1512 at32uc3a0512es at32uc3a1512es at32uc3a364 at32uc3a364s at32uc3a3128 at32uc3a3128s at32uc3a3256 at32uc3a3256s at32uc3b064 at32uc3b164 at32uc3b0128 at32uc3b1128 at32uc3b0256 at32uc3b1256 at32uc3b0256es at32uc3b1256es at32uc3b0512 at32uc3b1512 at32uc3c064 at32uc3c0128 at32uc3c0256 at32uc3c0512 at32uc3c164 at32uc3c1128 at32uc3c1256 at32uc3c1512 at32uc3c264 at32uc3c2128 at32uc3c2256 at32uc3c2512 global-options: --quiet, --debug level commands: configure {BSB|SBV|SSB|EB|HSB} [--suppress-validation] [global-options] data dump [global-options] dump-eeprom [global-options] dump-user [global-options] erase [--suppress-validation] [global-options] flash [--suppress-validation] [--suppress-bootloader-mem] [global-options] {file|STDIN} flash-eeprom [--suppress-validation] [global-options] {file|STDIN} flash-user [--suppress-validation] [global-options] {file|STDIN} get {bootloader-version|ID1|ID2|BSB|SBV|SSB|EB| manufacturer|family|product-name| product-revision|HSB} [global-options] getfuse {LOCK|EPFL|BOOTPROT|BODLEVEL|BODHYST| BODEN|ISP_BOD_EN|ISP_IO_COND_EN| ISP_FORCE} [global-options] setfuse {LOCK|EPFL|BOOTPROT|BODLEVEL|BODHYST| BODEN|ISP_BOD_EN|ISP_IO_COND_EN| ISP_FORCE} [global-options] data reset [global-options] start [global-options] version [global-options] new-host:~ selfonlypath$
Logged
Wahiawa, Hawaii
Online
Sr. Member
« Reply #3 on: February 12, 2013, 05:15:15 am » |
If I recall you could select an equivalent at90usb162.
Logged
France
Offline
Sr. Member
« Reply #4 on: February 12, 2013, 05:23:32 am » |
Unfortunately, just tried per your suggestion but DFU-programmer says no device present
Logged
Forum Administrator
Milano, Italy
Offline
Full Member
« Reply #5 on: February 12, 2013, 10:11:50 am » |
You can upgrade only using an ISP programmer.
Logged
C.
Offline
Full Member
« Reply #6 on: February 12, 2013, 04:44:20 pm » |
I used ArduinoISP on my leonardo. If your not familiar with this stuff, practice a bit with another (cheaper) board. Then try downloading the current firmware from the due's atmega16u2, for future reference and to check whether your setup is reliable. On the Due, pick the ISP header next to the atmega16u2!!! (One time I almost picked the other one, just by habbit, which is not 5V tolerant) I used this cmd line on linux: /opt/arduino-1.5.2/hardware/tools/avrdude -C /opt/arduino-1.5.2/hardware/tools/avrdude.conf -p m16u2 -b 9600 -c avrisp -P /dev/ttyACM1 -U flash:r:due-fw-ori.hex:i
I had to use avrdude from arduino, because the one on my system had no support for the m16u2. On windows it goes like this (note the -C arduino is needed when using leonardo as isp): C:\Users\peter\arduino-1.5.2/hardware/tools/avr/bin/avrdude -C C:\Users\peter\arduino-1.5.2/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -p m16u2 -c arduino -P COM6 -b 9600 -Uflash:r:due-fw-ori.hex:i
Then burn the new firmware: On linux: /opt/arduino-1.5.2/hardware/tools/avrdude -C /opt/arduino-1.5.2/hardware/tools/avrdude.conf -pm16u2 -b 9600 -c avrisp -P /dev/ttyACM1 -U flash:w:Arduino-DUE-usbserial-prod-firmware-2013-02-05.hex:i
On windows: C:\Users\peter\arduino-1.5.2/hardware/tools/avr/bin/avrdude -C C:\Users\peter\arduino-1.5.2/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -p m16u2 -c arduino -P COM6 -b 9600 -Uflash:w:Arduino-DUE-usbserial-prod-firmware-2013-02-05.hex:i
Logged
France
Offline
Sr. Member
« Reply #7 on: February 12, 2013, 10:48:24 pm » |
I just want make sure no blue smoking or destruction of my DUE... with the issue of 5V versus 3.3V ! Please confirm that I just build a 6 wires ribbon to connect directly my MEGA's 6 pins ICSP connector to my DUE's 6 pins ICSP connector. Via that ribbon, only +5V, GND, SCK, Slave, MOSI and MISO related to SPI protocol. Of course, I'll power my MEGA via USB connection of my Macintosh but how about my DUE, should it be powered or just receiving energy via its ICSP ? P.S. I've been able to download Crosspack http://www.obdev.at/products/crosspack/index.html running OK on my Macintosh, still not clear on my side how to properly sequence different actions of MEGA ICSP sketch, learning curve here since i'm more software guy than hardware. For example, i don't understand how via ICSP sketch one can download the HEX file firmware provided by cmaglie !
Logged
Forum Administrator
Milano, Italy
Offline
Full Member
« Reply #8 on: February 13, 2013, 01:58:47 pm » |
selfonlypath,
due to the high request, I've asked one of my collaborator to write a step-by-step tutorial, more info coming soon. Thanks for your patience.
Logged
C.
France
Offline
Sr. Member
« Reply #10 on: February 24, 2013, 06:46:09 am » |
« Last Edit: February 25, 2013, 11:31:53 pm by selfonlypath »
Logged
Germany
Offline
Full Member
« Reply #11 on: March 01, 2013, 11:58:39 am » |
Yes much better voll agree, the page for upgrading the Atmel16u2 is really nice but I think I would better and nicer for beginner that there would an Name for the Programming Port Atmel in the Boardslist so that anyone can change the firmware easily from the IDE
Logged
Offline
Newbie
« Reply #12 on: May 13, 2013, 01:08:22 am » |
Hello all. I am trying to do this as well and have a number of questions in regard to the tutorial posted above: http://arduino.cc/en/Hacking/Upgrading16U2DueHere are the issues I encountered so far, I am using Windows to attempt this: 1. It does not appear that AVRdude exists in the "tools" directory of any of the arduino releases so far. I was able to install WinAVR into a different directory. 2. I do not know where to find the "avrdude.conf" configuration file for avrdude mentioned here. I've done a lot of searching on the forums here and the arduino site and cannot find it. Can someone please point me to where that file is located? Also, it would be helpful if there was a link to this in the tutorial. That is as far as I made it using the tutorial. It appears that I need the avrdude.conf file to move forward. Any assistance you can offer is most appreciated. Thanks!
Logged
Offline
Newbie
« Reply #13 on: May 13, 2013, 01:34:40 am » |
Ok, I was able to find the correct path for the avrdude inside the arduino folders. I was also able to find the avrdude.conf file. And after a bit of work, I was able to create a command that avrdude would accept and seems to do something. My command looks like this:
avrdude -C avrdude.conf -c arduino -P com5 -b 19200 -p m16u2 -vvv -U flash:w:/16u2/16u2.hex:i
That works! I was able to flash the firmware to the 16u2. But, my Due still shows up as "USB device not recognized" in Windows. I guess it must be a further problem. Thanks all.
Logged
United States
Offline
Newbie
Yes. Thats my donkey
« Reply #14 on: May 23, 2013, 02:44:01 am » |
How does one determine if the OE firmware needs updating?
I ask this because my IDE ver1.5.2 "Arduino-DUE-usbserial.hex" file shows the "last modified" date as being 2/6/2013. That's one day newer than the proposed Arduino-DUE-usbserial-prod-firmware-2013-02-05.hex file. (I'm reading as Feb,6,2013 vs. Feb,5,2013)
I also know, that it is possible for neither of these versions to be actually installed (flashed) into the device from the factory. How do I tell?
Is there a trivial way to check if the 'update' is indeed required for the device in question?
User's Interface: OS == Win7x64 Have dedicated ICSP tool == False Have spare UNO == True (Should also be flashed?) Have spare Mega2560 == True (Should also be flashed?)
Logged
