Topic: Manipulate a Number (Read 1 time) previous topic - next topic
ilovetoflyfpv
Hi Gang
I was wondering how to manipulate a number?
Example
long serialNumber = 123456789
I am only interested in the last six digits. How can I extract these so that;
long serialNumber = 456789
Any help would be greatly appreciated.
Cheers
Jase
Delta_G
Use the % operator.  It gives you the remainder of a division.  If you % by 1000000 then the result will be the last six digits.
Ad hoc, ad loc, and quid pro quo.  So little time - so much to know!  ~Jeremy Hillary Boob Ph.D
JimboZA
Use the % operator.
Good thinking, Batman... I was starting to thing strings and right parts and stuff  :smiley-yell:
ZS6JMB
ilovetoflyfpv
Hi Guys
Thanks for the quick response. Can you give me an example?
Cheers
Jase  :)
PaulS
Where are you getting this number? Why are you only interested in the last 6 digits? What if the number is only a 3 digit number?
WizenedEE
long bignum = 2844493234;
int smallernum = bignum % 1000000;
JimboZA
Well the fact that the OP used the variable name serialNumber made me think it was exactly that, a serial number, and that they are of a specific length in his world. Often, the sections of serial numbers mean something: perhaps in his case the last 6 digits are the actual sequence number and that's what he needs to know for his purpose. Maybe the part before that is the factory and line number or something.
ZS6JMB
ilovetoflyfpv
Hi Guys
Thanks for the replies. As mentioned earlier I'm interested in only the last six digits of the number which form a serial number. I think I understand now your suggestions. So by using % (modulo) it divides the number until it can't be divided any more then returns the remainder.
Example
x = 2844493234 % 1000000
x = 493234
Cheers
Jase
JimboZA
Well no, it just divides it, not until it can't be divided any more, then returns the remainder.
Dividing by a power of ten is a kind of "special case" I guess one could call it, since it has the efect of moving the decimal place.
7%4 is 3, because 7/4 is 1.75, which is 1 remainder 3 (0.75 x 4=3)
123%10 is 3, because 123/10 is 12.3, which is 12 remainder 3 (0.3 x 10 = 3)
ZS6JMB
