Topic: Arduino's GUI (Read 2324 times) previous topic - next topic
francescoprisco
Hi dear,
I have an ask.How i can show data of speed sensor (magnet) to processing gui?Now i have flash show of data
Processing
Code: [Select]
import processing.serial.*;
int width = 800;
int height = 600;
String inByte;
int button1X;
int button1Y;
int button1Width = width/10;
int button1Height = height/20;
int button2X;
int button2Y;
int button3X;
int button3Y;
int button2Width = button1Width;
int button2Height = button1Height;
int button3Width = button1Width;
int button3Height = button1Height;
float buttonFont = button1Height/1.5;
float wordFont = button1Height;
Serial arduino;
color buttonColor, buttonHighlight, buttonPressed;
PFont font;
boolean button1Over = false;
boolean button2Over = false;
boolean button3Over = false;
  size(width,height);
  smooth();
  font = loadFont("CourierNew36.vlw");
  buttonColor = color(255);
  buttonHighlight = color(200);
  buttonPressed = color(50);
  button1X = width/10 - button1Width/2;
  button1Y = height/5 - button1Height/2;
  button2X = 2*width/10 - button1Width/2;
  button2Y = height/5 - button1Height/2;
    button3X = 3*width/10 - button1Width/2;
  button3Y = height/5 - button1Height/2;
  arduino = new Serial(this,"COM3", 9600);
    arduino.bufferUntil('\n'); // SerialEvent for new line
  arduino.clear();
void draw() {
  update(mouseX,mouseY);
  background(0);
  if(button1Over) {
    fill(buttonHighlight);
    fill(buttonColor);
  stroke(0);
  rect(button1X,button1Y, button1Width, button1Height);
  if(button2Over) {
    fill(buttonColor);
  stroke(0);
  rect(button2X,button2Y, button2Width, button2Height);
    if(button3Over) {
    fill(buttonColor);
  stroke(0);
  rect(button3X,button3Y, button3Width, button3Height);
  textFont(font, buttonFont);
  fill(0);
  text("On t",button1X + button1Width/3.9,button1Y + button1Height/1.3);
  text("On nt",button2X + button1Width/10.9,button1Y + button1Height/1.3);
    text("Off nt",button3X + button1Width/10.9,button1Y + button1Height/1.3);
      while (arduino.available () > 0) {
inByte = arduino.readStringUntil('\n');
if ( inByte != null ) {
  println(inByte);
  fill(125);
        text(inByte,width/2, height/2);
  textFont(font, wordFont);
  fill(255);
  text("Accendi/Spegni Led ",button3X + button1Width + width/20,button1Y + button1Height/1.2);
void update(int x, int y) {
  if(overButton(button1X,button1Y,button1Width,button1Height)){
    button1Over = true;
  if(overButton(button2X,button2Y,button2Width,button2Height)){
    button2Over = true;
  if(overButton(button3X,button3Y,button3Width,button3Height)){
    button3Over = true;
void mousePressed() {
  if(button1Over) {
    println("Button1 pressed");
    arduino.write('S');
    fill(buttonPressed);
  if(button2Over) {
    println("Button2 pressed");
     arduino.write('N');
  if(button2Over) {
    println("Button3 pressed");
     arduino.write('Z');
boolean overButton(int x, int y, int width, int height) {
  if(mouseX >= x && mouseX <= x+width && mouseY >= y && mouseY <= y+height) {
    return true;
    return false;
arduino code:
Code: [Select]
const int pinled=13;
int val;
#define reed A0//pin connected to read switch
//storage variables
int reedVal;
long timer;// time between one full rotation (in ms)
float mph;
float radius = 13.5;// tire radius (in inches)
float circumference;
int pass;
int passs=0;
int maxReedCounter = 100;//min time (in ms) of one rotation (for debouncing)
int reedCounter;
void setup(){
  pinMode(pinled, OUTPUT);
  pinMode(A1, INPUT);
    reedCounter = maxReedCounter;
  circumference = 2*3.14*radius;
  pinMode(reed, INPUT);
  // TIMER SETUP- the timer interrupt allows precise timed measurements of the reed switch
  //for more info about configuration of arduino timers see http://arduino.cc/playground/Code/Timer1
  cli();//stop interrupts
  //set timer1 interrupt at 1kHz
  TCCR1A = 0;// set entire TCCR1A register to 0
  TCCR1B = 0;// same for TCCR1B
  TCNT1  = 0;
  // set timer count for 1khz increments
  OCR1A = 1999;// = (1/1000) / ((1/(16*10^6))*8) - 1
  // turn on CTC mode
  TCCR1B |= (1 << WGM12);
  // Set CS11 bit for 8 prescaler
  TCCR1B |= (1 << CS11);
  // enable timer compare interrupt
  TIMSK1 |= (1 << OCIE1A);
  sei();//allow interrupts
  //END TIMER SETUP
   ISR(TIMER1_COMPA_vect) {//Interrupt at freq of 1kHz to measure reed switch
  reedVal = digitalRead(reed);//get val of A0
  if (reedVal){//if reed switch is closed
    if (reedCounter == 0){//min time between pulses has passed
      mph = (56.8*float(circumference))/float(timer);//calculate miles per hour
      timer = 0;//reset timer
      reedCounter = maxReedCounter;//reset reedCounter
    else{
      if (reedCounter > 0){//don't let reedCounter go negative
        reedCounter -= 1;//decrement reedCounter
  else{//if reed switch is open
  if (timer > 2000){
    mph = 0;//if no new pulses from reed switch- tire is still, set mph to 0
  else{
    timer += 1;//increment timer
void displayMPH(){
  Serial.println(mph , BYTE);
delay(3000);
    if(Serial.available() >0)
       val= Serial.read();
      if(val == 'S')
  digitalWrite(pinled, HIGH);
  digitalWrite(pinled, LOW);
  }else if(val == 'N')
      }else if(val=='Z')
//pass = digitalRead(A1);
  //Serial.println(pass);
//  print mph once a second
  displayMPH();
PaulS
I have a
    very hard time
         reading code
  that jerks all
                       over the place.
Put each { on a new line and use Tools + Auto Format to format your code BEFORE posting.
Separate functions with a blank line. Jamming all the code together is not really necessary.
I also don't understand what your problem is. What does "Now i have flash show of data" mean?
Does the data appear, and then disappear? Performing serial data processing in draw is wrong. You should have a serialEvent() callback that reads the data, doing whatever it needs with the data. Then, draw() should simply use the data, based on serial data that just arrived or based on serial data that arrived three hours ago.
francescoprisco
Yes.The data appear and then disappear
