Topic: Checksum error (Read 3287 times) previous topic - next topic
kelidel
I am having an error somewhere with this checksum, and I cannot see where I've gone wrong with my code.
void mdb_expansion(void) {
    static uint8_t data[30] = {0,0,0,0,0,0,0,0,0,0,
                               0,0,0,0,0,0,0,0,0,0};
    uint8_t checksum = MDB_EXPANSION;
    if(buffer_level(MDB_USART,RX) < 60) return;
    #if DEBUG == 1
    send_str_p(UPLINK_USART, PSTR("EXPANSION\r\n"));
    #endif
    for(uint8_t i=0; i<30; i++) {
        data = (uint8_t) recv_mdb(MDB_USART);
        #if DEBUG == 1
        mdb_dump(RX,data);
        #endif
        if(i != 30) {
            checksum += data;
    // validate checksum
    if(checksum != data[30]) {
        mdb_active_cmd = MDB_IDLE;
        mdb_poll_reply = MDB_REPLY_ACK;
        send_str_p(UPLINK_USART,PSTR("Error: invalid checksum [EXPANSION]\r\n"));
        return;
    send_mdb(MDB_USART, 0x009);
    checksum = 0x09;
    #if DEBUG == 1
    mdb_dump(TX,0x009);
    #endif
    for(uint8_t j=1; j<29; j++) {
        send_mdb(MDB_USART,data[j]);
        checksum += data[j];
        #if DEBUG == 1
        mdb_dump(TX,data[j]);
        #endif
    send_mdb(MDB_USART,checksum);
    #if DEBUG == 1
    mdb_dump(TX,checksum);
    #endif
The output is:
EXPANSION
RAW RX MDB: 0x000
RAW RX MDB: 0x041
RAW RX MDB: 0x050
RAW RX MDB: 0x049
RAW RX MDB: 0x030
RAW RX MDB: 0x031
RAW RX MDB: 0x032
RAW RX MDB: 0x033
RAW RX MDB: 0x034
RAW RX MDB: 0x035
RAW RX MDB: 0x036
RAW RX MDB: 0x037
RAW RX MDB: 0x038
RAW RX MDB: 0x039
RAW RX MDB: 0x030
RAW RX MDB: 0x031
RAW RX MDB: 0x053
RAW RX MDB: 0x054
RAW RX MDB: 0x055
RAW RX MDB: 0x044
RAW RX MDB: 0x049
RAW RX MDB: 0x04f
RAW RX MDB: 0x04c
RAW RX MDB: 0x049
RAW RX MDB: 0x04e
RAW RX MDB: 0x045
RAW RX MDB: 0x052
RAW RX MDB: 0x056
RAW RX MDB: 0x000
RAW RX MDB: 0x069
RAW RX MDB: 0x070
RAW RX MDB: 0x117
Please help me see where I am getting this wrong.  Thank you.
nickgammon
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Index 30 is outside the array.
marco_c
An array of size 30 has indices 0 to 29, so you probably mean 29 if you intend the last character.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
kelidel
Hi, I have changed that, thanks, but still receiving the same error.
Thank you
Regards
AWOL
Please post your corrected code using code tags, not bold tags.
kelidel
I apologize.  Herein is my code
    static uint8_t data[30] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
    #if DEBUG == 1
    #endif
        data[i] = (uint8_t) recv_mdb(MDB_USART);
        #if DEBUG == 1
        mdb_dump(RX,data[i]);
        #endif
        if(i != 29) {
            checksum += data[i];
    if(checksum != data[29]) {
        return;
    checksum = 0x09;
    #if DEBUG == 1
    mdb_dump(TX,0x009);
    #endif
        #if DEBUG == 1
        #endif
    #if DEBUG == 1
    #endif
Thank you
AWOL
RAW RX MDB: 0x117
I'm having problems seeing a three digit value fitting in a two digit variable.
Often it is easier to see the problem if one can see the whole picture.
marco_c
#7
Feb 08, 2013, 12:13 pm Last Edit: Feb 08, 2013, 12:15 pm by marco_c Reason: 1
... And there is no way that a byte quantity can have 3 digits.
Are you sure that you are printing the value in hex all the time? Can't see mdb_dump anywhere.
Helpful debug would also be to print the value it should be when the test fails. That may give you a clue.
Checksums may not include every character received, for example the start of a packet, so are you sure you are using the right data?
kelidel
The mdb_dump displays this:
RAW RX MDB: 0x070
RAW RX MDB: 0x117
EXPANSION
RAW RX MDB: 0x000
RAW RX MDB: 0x041
RAW RX MDB: 0x050
RAW RX MDB: 0x049
RAW RX MDB: 0x030
RAW RX MDB: 0x031
RAW RX MDB: 0x032
RAW RX MDB: 0x033
RAW RX MDB: 0x034
RAW RX MDB: 0x035
RAW RX MDB: 0x036
RAW RX MDB: 0x037
RAW RX MDB: 0x038
RAW RX MDB: 0x039
RAW RX MDB: 0x030
RAW RX MDB: 0x031
RAW RX MDB: 0x053
RAW RX MDB: 0x054
RAW RX MDB: 0x055
RAW RX MDB: 0x044
RAW RX MDB: 0x049
RAW RX MDB: 0x04f
RAW RX MDB: 0x04c
RAW RX MDB: 0x049
RAW RX MDB: 0x04e
RAW RX MDB: 0x045
RAW RX MDB: 0x052
RAW RX MDB: 0x056
RAW RX MDB: 0x000
RAW RX MDB: 0x069
PeterH
When posting code it's always best to post a complete sketch that demonstrates the problem. If the problem is in a large sketch then if possible extract the code with the problem into a separate minimal sketch that demonstrates the problem in the simplest possible way. Quite often, the act of doing this will show up some false assumption you've made which will enable you to spot the fault for yourself, but if not then you've saved everyone else wasted effort in trawling through code that is not relevant to the problem.
