Leighton Buzzard, UK
« on: February 08, 2013, 04:18:14 am » |
what is the best way to remove flux residue after soldering SMD devices everything is working, just doesn't look very nice with muddy stains all over the boards?
cheers Mike
there are only 10 types of people them that understands binary and them that doesn't
UK
« Reply #1 on: February 08, 2013, 04:32:21 am » |
« Reply #2 on: February 08, 2013, 05:08:27 am » |
Norfolk UK
« Reply #3 on: February 08, 2013, 06:29:25 am » |
Florida, USA
« Reply #4 on: February 08, 2013, 10:27:16 am » |
I have used acetone and 90% Isopropyl alcohol before with success... however you must be careful with plastics as both of these chemicals react with some plastics. It should be fine on a PC board though.
Hugo
Left Coast, CA (USA)
Measurement changes behavior
« Reply #5 on: February 08, 2013, 11:31:02 am » |
cheers Mike
I just use water and a tooth brush, works fine with a little patience. I've found too many times that some chemicals like Isopropyl alcohol on some PCBs cause a smeary mess that's hard to clean off. Lefty
Knowledge is proportional to the number of parts destroyed.
« Reply #6 on: February 08, 2013, 11:32:22 am » |
I've used denatured alcohol (aka methylated spirits) for over 30 years with good success. It's safe for most plastics, with ABS (changes the color) and Lexan (makes it cloudy) being the exceptions I know of. It's readily available, dries quickly and is relatively cheap. I use it with a small, stiff plastic-bristled brush to scrub the boards after soldering. Isopropyl alcohol also works well. Make sure you get actual high-concentration (85% or better) Isopropyl (or Isopropanol) and not the commonly available "rubbing alcohol", which contains glycerine and will leave a residue. DON'T be lazy and just soak the boards in alcohol. Despite being relatively mild solvents, given enough time they will disolve a lot of things. There are also many commercial electronic spray cleaners that remove flux. Some will severely damage (even dissolve) plastic despite being labeled "safe for most plastics". They never seem to say exactly what plastics are included in "most", so I recommend you test them first. The older formulations from 20 years ago worked great but were either carcinogenic or ozone-depleting and have been banned. The newer concoctions don't seem to work as well to me so I've gone back to using alcohol and a brush. BTW, use in a well-ventilated area and away from spark or flame. Alcohol flames are nearly invisible. Isopropyl alcohol in a spray can. Probably cheaper to just buy a bottle.
« Reply #7 on: February 08, 2013, 11:37:43 am » |
90% alcohol from Walgreens. ... and a toothbrush.
Before the alcohol dries, you need to dry it with a dampcloth. Otherwise, the flux that you brushed and got dissolved in alcohol, will remain on the board after the alcohol evaporates... leaving a film mess.
Sometimes it takes a second scrubbing (and helps if you also brush all the alcohol off the board, so it's taking with it all the dissolved flux)
Remember, before the alcohol evaporates, it needs to be patted down with a cloth. That's the trick for me.
« Reply #8 on: February 08, 2013, 12:19:18 pm » |
thanks for all the feedback will give some a try
« Reply #9 on: February 08, 2013, 12:27:19 pm » |
One plastic that is very intolerant of most solvents is polycarbonate - even the oils in citrus peel will dissolve it!
If you are using solderpaste to solder SMT components then look for "no-clean" solder paste - the flux evaporates I think, leaving hardly any residue.
For rosin flux a two-stage cleaning process seems to work for me - first spray on and scrub to break up any hard lumps. Secondly apply more solvent and allow to drain from the side of the board, this tends to carry away most of the rosin (which will just precipitate out again if the solvent dries in place - so do this cold to reduce evaporation (the first application tends to reduce the board temperature nicely!)
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
« Reply #10 on: February 08, 2013, 12:27:49 pm » |
If you use a water soluble flux cleaning is easy. 1. Lather, 2. rise, 3. Repeat... If not and you use a solvent containing water (AKA Alcohol) you must wait until or dry the PCB first, A heat gun works very well. {Edit RKJ} AS MarkT pointed out above orange oil is the best solvent for that purpose.
Bob
« Last Edit: February 08, 2013, 12:33:56 pm by Docedison »
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Samplefinger
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
« Reply #11 on: February 08, 2013, 12:47:57 pm » |
 Plus a toothbrush, or if you want to be really cool:
« Last Edit: February 08, 2013, 12:52:34 pm by JoeN »
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
« Reply #12 on: February 08, 2013, 05:42:48 pm » |
Denatured ethanol or tetrachloroethylene, a toothbrush, and an air compressor. Brake cleaner (Brakleen brand in the red can, not the green can) is tetrachloroethylene, and works well. Best used outdoors.
« Reply #13 on: February 10, 2013, 08:31:02 am » |
Any chlorinated solvent should be used with plenty of ventilation... Or avoided(!)
« Reply #14 on: February 10, 2013, 11:42:08 am » |
We like to say, "Better living through Chemistry!"
