Topic: IR PC Remote Hack (Read 996 times) previous topic - next topic
mjkzz
I just finished a sketch as part of another development effort -- turning a PC remote control into a mouse pad or joystick pad.
Here is the code to decode IR signals from this remote
// Written by Peter Y Lin, a.k.a MJKZZ
// Do whatever you want to do with this code but use this code at your own risk
#include <avr/io.h>
#include <avr/interrupt.h>
#include "LedMatrix.h"
#define TICK_IR_BREAK 5000
#define TICK_IR_ONE_MIN 400
#define TICK_IR_ONE_MAX 600
#define MAX_IR_PULSE 24
#define MAX_IR_DATA 8
#define MAX_IR_REPEAT 1
#define PIN_IR 2
#define IR_CODE_UP 0xC500
#define IR_CODE_DOWN 0xC480
#define IR_CODE_LEFT 0xC560
#define IR_CODE_RIGHT 0xC460
#define IR_CODE_UPLEFT 0xC562
#define IR_CODE_UPRIGHT 0xC462
#define IR_CODE_DOWNLEFT 0xC566
#define IR_CODE_DOWNRIGHT 0xC466
#define IR_CODE_UPARROW 0xC590
#define IR_CODE_DOWNARROW 0xC4D0
#define IR_CODE_LEFTARROW 0xC430
#define IR_CODE_RIGHTARROW 0xC420
volatile unsigned int g_tkPulse = 0;
volatile unsigned int g_ctPulse = 0;
volatile unsigned int g_arPulse[MAX_IR_PULSE];
volatile unsigned int g_irCode = 0;
volatile unsigned int g_irTemp = 0;
volatile unsigned int g_ctCode = 0;
LedMatrix ledDisplay = LedMatrix(5, 6, 7, 16, 16);
// This is a bitmap for a sprite
// The first two bytes specify width and height of
// sprite and the rest are bitmaps for sprite
byte g_sprite[6] =
0x03, // width
0x04, // height
0b10110000,
0b01001000,
0b01000100,
0b10100010,
volatile unsigned char g_x = 0;
volatile unsigned char g_y = 0;
void isr_ir()
g_tkPulse = TCNT1;
TCNT1 = 0;
if (g_tkPulse > TICK_IR_BREAK)
g_ctPulse = 0;
else if (g_ctPulse < MAX_IR_PULSE)
g_arPulse[g_ctPulse] = g_tkPulse;
g_ctPulse++;
if (g_ctPulse == 16)
g_irTemp = 0;
for(int i=0; i<g_ctPulse; i++)
if (g_arPulse[i] > TICK_IR_ONE_MIN && g_arPulse[i] < TICK_IR_ONE_MAX)
g_irTemp |= 1;
g_irTemp = g_irTemp << 1;
if (g_irTemp == g_irCode)
if (g_ctCode < MAX_IR_REPEAT)
g_ctCode++;
g_ctCode = 1;
g_irCode = g_irTemp;
TCCR1A = 0b00000000;
TCCR1B = 0b00000011;    // Clk*64 = 4uS
TCCR1C = 0b00000000;
pinMode(PIN_IR, INPUT);
attachInterrupt(0, isr_ir, FALLING);
ledDisplay.init(8);
ledDisplay.blank();
ledDisplay.sprite(g_x, g_y, (const char *)g_sprite, 6, GRAPHIC_DRAW_SRC);
ledDisplay.update();
if (g_ctCode == MAX_IR_REPEAT)
//Serial.print("Code = ");
//Serial.println(g_irCode, HEX);
ledDisplay.sprite(g_x, g_y, (const char *)g_sprite, 6, GRAPHIC_DRAW_XOR);
switch(g_irCode)
case IR_CODE_LEFT:
case IR_CODE_LEFTARROW:
if (g_x)
g_x--;
break;
case IR_CODE_RIGHT:
case IR_CODE_RIGHTARROW:
if (g_x < ledDisplay.getWidth()-3)
g_x++;
break;
case IR_CODE_UP:
case IR_CODE_UPARROW:
if (g_y)
g_y--;
break;
case IR_CODE_DOWN:
case IR_CODE_DOWNARROW:
if (g_y < ledDisplay.getHeight()-4)
g_y++;
break;
case IR_CODE_UPLEFT:
if (g_y)
g_y--;
if (g_x)
g_x--;
break;
case IR_CODE_UPRIGHT:
if (g_y)
g_y--;
g_x++;
break;
case IR_CODE_DOWNLEFT:
g_y++;
if (g_x)
g_x--;
break;
case IR_CODE_DOWNRIGHT:
g_y++;
g_x++;
break;
Serial.println(g_x, DEC);
g_irCode = 0;
g_ctCode = 0;
Search for "mjkzz" on eBay :-)
mjkzz
here is a video showing how it works . . .
http://player.youku.com/player.php/sid/XNTEyNTYzMDQw/v.swf
