Pages: [1] 2   Go Down
Author Topic: WProgram.h: No such file or directory  (Read 1640 times)
I want to download MAX6675 library.But I'm getting the following error:
In file included from Single_Temp.pde:6:
C:\Users\salim\Documents\Arduino\libraries\max6675arduinolibrary/MAX6675.h:9:22: error: WProgram.h: No such file or directory
Single_Temp.pde:21:4: error: #else without #if
Single_Temp.pde:23:4: error: #endif without #if
Single_Temp:11: error: conflicting declaration 'int SCK'
C:\Program Files\arduino-1.0.3\hardware\arduino\variants\mega/pins_arduino.h:38: error: 'SCK' has a previous declaration as 'const uint8_t SCK'
Single_Temp:19: error: 'CS0' was not declared in this scope
How I can fix this problem?
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
You have to go into the .h and .cpp files and change "WProgram.h" to Arduino.h
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
I tried, but nothing can be changed
Queens, New York
Then you didn't try hard enough, sorry to say. Do you have Notepad or some rendition of it? Try to download Notepad++ notepad-plus-plus.org/
Once you have notepad, go to your library folder, find the library your using and open the .h and .cpp file in notepad.
I've tried everything.Please help the library users
Queens, New York
Were you able to open the .h and .cpp files? Did you change the WProgram.h to Arduino.h? Did you save the files and reset the program?
What exactly did you do, when you say everything? Maybe attach the two codes below, so I can see what you have done.
i  fixed this problem but This time I'm getting the following error:
Single_Temp:19: error: 'MAX6675' does not name a type
Single_Temp.pde: In function 'void loop()':
Single_Temp:31: error: 'temp0' was not declared in this scope
.cpp file:
  MAX6675.cpp - Library for reading temperature from a MAX6675.
  Created by Ryan McLaughlin <ryanjmclaughlin@gmail.com>
#include <Arduino.h>
#include <MAX6675.h>
MAX6675::MAX6675(int CS_pin, int SO_pin, int SCK_pin, int units, float error)
  pinMode(CS_pin, OUTPUT);
  pinMode(SO_pin, INPUT);
  pinMode(SCK_pin, OUTPUT);
  digitalWrite(CS_pin, HIGH);
  _CS_pin = CS_pin;
  _SO_pin = SO_pin;
  _SCK_pin = SCK_pin;
  _units = units;
  _error = error;
float MAX6675::read_temp(int samples)
  int value = 0;
  int error_tc = 0;
  float temp = 0;
  for (int i=samples; i>0; i--){
    digitalWrite(_CS_pin,LOW); // Enable device
    /* Cycle the clock for dummy bit 15 */
    digitalWrite(_SCK_pin,HIGH);
    digitalWrite(_SCK_pin,LOW);
    /* Read bits 14-3 from MAX6675 for the Temp
       Loop for each bit reading the value and
       storing the final value in 'temp'
    for (int i=11; i>=0; i--){
      digitalWrite(_SCK_pin,HIGH);  // Set Clock to HIGH
      value += digitalRead(_SO_pin) << i;  // Read data and add it to our variable
      digitalWrite(_SCK_pin,LOW);  // Set Clock to LOW
    /* Read the TC Input inp to check for TC Errors */
    error_tc = digitalRead(_SO_pin); // Read data
    digitalWrite(_CS_pin, HIGH); //Disable Device
  value = value/samples;  // Divide the value by the number of samples to get the average
     Keep in mind that the temp that was just read is on the digital scale
     from 0ËšC to 1023.75ËšC at a resolution of 2^12.  We now need to convert
     to an actual readable temperature (this drove me nuts until I figured
     this out!).  Now multiply by 0.25.  I tried to avoid float math but
     it is tough to do a good conversion to ËšF.  THe final value is converted
     to an int and returned at x10 power.
  value = value + _error;                  // Insert the calibration error value
  if(_units == 0) {                        // Request temp in ËšF
    temp = ((value*0.25) * (9.0/5.0)) + 32.0;   // Convert value to ËšF (ensure proper floats!)
  } else if(_units == 1) {                  // Request temp in ËšC
    temp = (value*0.25);                  // Multiply the value by 0.25 to get temp in ËšC
  /* Output -1 if there is a TC error, otherwise return 'temp' */
  if(error_tc != 0) {
    return -1;
    return temp;
thanks for your helps...
Moderator edit: [code] ... [/code] tags added. (Nick Gammon)
« Last Edit: February 08, 2013, 04:49:42 pm by Nick Gammon » Logged
Queens, New York
Where is your sketch?
UK
In MAX6675.h, I changed "WProgram.h" to "Arduino.h"
In MAX6675.cpp, I changed "WProgram.h" to "Arduino.h" (or you can delete the #include completely)
In the "read_temp" example, I changed
int SCKpin = 13;             // SCK pin of MAX6675
int units = 2;            // Units to readout temp (0 = raw, 1 = ˚C, 2 = ˚F)
float temperature = 0.0;  // Temperature output variable
// Initialize the MAX6675 Library for our chip
MAX6675 temp(CS,SO,SCKpin,units);
and I got the error message
Binary sketch size: 5264 bytes (of a 14336 byte maximum)
(Compiling on 1.0 for a 2009)
OP, please use code tags when posting code.
i'm sorry awol. I didn't know. Can we solve this problem?
UK
Yes, I just told you in the PM, we can solve this problem.
But only when you post your sketch in code tags on the forum, plus the exact error message you're getting.
I don't do PM help-desk.
« Last Edit: February 08, 2013, 11:08:10 am by AWOL » Logged
I want to use max6675 library but ı have compile error.
this error:
In file included from Single_Temp.ino:6:
C:\Users\f\Documents\Arduino\libraries\max66library/MAX6675.h:9:22: error: WProgram.h: No such file or directory
Can you help me?
Melbourne, Australia
Shannon Member
Lua rocks!
Read this before posting a programming question
Read point 2.
Shannon Member
Lua rocks!
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
UK
Please read reply #8
Pages: [1] 2   Go Up
