Topic: RC servo control (Read 1 time) previous topic - next topic
Giles WALKER
Hello, I am completely new to Arduino. I am trying to control a RC hobby servo with Arduino. I have pasted in the 180 sweep available from the library and it works fine. However, I am wanting the servo to sweep from various angles and at various speeds. I have modified the code so that it does this....but I also want it to pause for a few seconds every now and again so it is not constantly moving. I can't seem to get it to do this..any ideas? Thanks.
ash901226
Simplest way is to impliment delay. But for a more profesional looking code use what the technique shown on blink without delay. How abou u post yourcode for us to really help you
Giles WALKER
Thanks for the reply. I'm sorry but I have not got any code yet (except the 180 degree sweep from the library). Could you explain how to alter this code...or give me an example of say..0 to 180 degrees sweep with a 5 second pause at the 180, then to 90 with a 3 sec delay..then back to 0. I reckon I will then be able to make my own adjustments to the code to get the effect I'm after. Thanks.
JimboZA
Try something like this....
(See my comments in there....)
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
               // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
 myservo.attach(9);  // attaches the servo on pin 9 to the servo object
 for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
 {                                  // in steps of 1 degree
   myservo.write(pos);              // tell servo to go to position in variable 'pos'
   delay(15);                       // waits 15ms for the servo to reach the position
delay(5000) //5000 = 5 sec  <<<<<<<<<<<<<<<<<<<<<<< new
 for(pos = 180; pos>=90; pos-=1)     // goes from 180 degrees to 90 degrees   <<<<<<<<<<<<< changed
delay(3000) //3000 = 3 sec  <<<<<<<<<<<<<<<<<<<<<<< new
 for(pos = 90; pos>=0; pos-=1)     // goes from 90 degrees to 0 degrees   <<<<<<<<<<<<< changed
73 de ZS6JMB
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Giles WALKER
Thank you JIMBOZA,
That looks just what I need....only I can't get it to 'verify' in the Arduino software. Any chance you could have a quick loo and see what the problem is? Thanks again for your time and knowledge.
JimboZA
#5
Feb 10, 2013, 02:33 pm Last Edit: Feb 10, 2013, 02:37 pm by JimboZA Reason: 1
Ooops... that's the trouble with typing and not testing.... I left the ; off the delays. They all ought to look like this one:
delay(3000); //<<<<<<<<< ; was missing
Edit... I put the ;'s in on mine and it compiles- not tested it on an actual Arduino with a servo though
73 de ZS6JMB
Giles WALKER
That's verified. Thanks I'll give it a go.
Giles WALKER
That has worked fine. Thanks for that.
Just another quick question...if you want to put a delay in between the 'loops' can you? So it runs through a sequence, then pauses for some seconds...?
Thanks.
JimboZA
Yep... you could add a delay() as the last line of loop(), before the closing }.
If you're keen on delays  8) you should have a look at the Blink without delay sketch: the delay() command is eschewed because while the Arduino is sitting in the delay, nothing else can happen. Blink without delay allows you to "delay" without really delaying.
73 de ZS6JMB
Giles WALKER
Ok. Thanks. I'll have a look.
