Pages: [1] 2 3   Go Down
Author Topic: Need to power small dc motor car for specific distance and stop  (Read 1316 times)
I am a middle school teacher writing on behalf of a group of students. I have a G&T class that has a task to power 5 small cars for a specific distance using different power sources and stop within an 18" square . No return, just go when switched on and stop on their own.
We have a small RC car and an Arduino for one of the cars.
We want to use the Arduino as a timer to send power to a relay to switch on the motor and switch it off after a specified time. We plan to test for run time / distance to hopefully get consistent results.
We have a very basic knowledge of programming but we have done a few blinking led sketches from a book.
Can someone please answer the following questions?
Is there a template that we can follow that will do this task?
What relay should we use?
Can we power the Arduino from the 2 AAA car batteries or should we use a 9v battery?
Is there a better way to do this with these components?
Thanks in advance
FT DI
Do you have a Arduino Uno ?
That runs at 16MHz, and because of that it needs 5V.
The microcontroller ATmega328P on the Arduino Uno can run on 2 AAA batteries, but only with a lower clock speed.
The relay depends on how much current is switched.
A small cheap 5V relay would be probably be good enough.
You could also use a logical power mosfet or a (darlington) transistor.
To measure the distance, you would need to measure the rotation of an axis or a wheel. This can be done with a magnet and a hall sensor or optical. If you have it working it would be nice to stick a white dot to a wheel and try to measure it with the Arduino and a optical sensor.
Johannesburg UTC+2
Welcome.... usually it's the students asking for help  smiley-cool
Have a look at these tutorials: This one drives a motor with a transistor, and this one drives a relay. One day you can get fancy and have speed and direction control, like this!
I'm thinking for simplicity, use the transistor one.... You'll see from the pic that the transistor is switched by an Arduino digital pin via a resistor: that's really no different from the Arduino driving a LED. Don't leave out that diode.....
You can't power the Arduino from 2x AAAs, that's only 3V, so yes you could use a 9V PP3 on the barrel jack, and power the motor from the car battery.
Edit... You could use a delay in the code between switching on and off, adjusting the delay value as your experimenting dictates. Put the code in setup() not loop() so that it only runs once:
write a high to the digital pin
delay for x time, ie have motor running for x
write a low to the pin.
Or as Krodal says, get really fancy with distance measuring but I got the impression you'll home in on an "on-time" by trial and error?
« Last Edit: February 08, 2013, 12:20:46 pm by JimboZA » Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
UK
I have a G&T class
I'm guessing that's not "gin and tonic"?
Croatia
Online Online
Basically any relay will do since it appears it's quite a small DC motor. A transistor would most likely be sufficient as well.
However, I wouldn't rely on timing and guessing the run, but rather monitor it. A magnet on a wheel and a reed switch on the chassis will give you a signal for each rotation of the wheel (or, if you want even better precision, put multiple magnets). Multiply number of signals by the circumference of the wheel (or part of the circumference if you use multiple magnets) and you get the distance traveled more consistently than with timing (batteries deplete, motor runs more slowly, car doesn't cover the desired distance).
Johannesburg UTC+2
I have a G&T class
.... that's in the Staff Room, not the Class Room
IT Crowd:
Thanks for the input so far. To answer a few questions. The device is an Uno. G&T = Gifted and Talented. The kids are mostly 5th graders that were recommended for the program by their teachers. They are doing this for a Destination Imagination competition. I'm writing on their behalf because of our districts restrictions on the use of social media at school.
We don't meet again until next week so hopefully there will be lots of suggestions for them to try. In the mean time I plan to pick up whatever relay or transistors we need over the weekend. I think we will try the timer config first because it was their idea and seems simpler to start out. Then if time allows we'll look at more precise options.
Thanks again, all suggestions are appreciated.
FT DI Team
« Last Edit: February 08, 2013, 01:44:37 pm by GrisGris » Logged
Croatia
Online Online
Why don't you ask the kids to come up with ways to measure the distance traveled?
Serving them the answer sounds more "gifted" than "talented".
Then ask them to write the algorithm. Not the actual code, but what happens when and what is triggered in which condition.
When you have that writing the actual code, in this situation, is a breeze.
Make them compete against each other to see who can come up with the simplest method and way for each part of the problem.
Shpaget, perhaps the kids are using the internet during the weekend and reading this. I can think of ten ways to drive a toy car a certain distance. Let them come up with twenty ways.
That's what we did and the timer idea was the most realistic and attainable in the short run.
These are 5th graders. They have lots of ideas but some of them involve anti gravity.
At this level they pretty much need to read and follow directions.
They searched this forum and others but did not find anything that could readily adapt.
So concrete numbers are more useful than theory for now.
Maine
Caution: Explosives in use.
You could use a boost regulator like this: http://www.pololu.com/catalog/product/798 or this: http://www.pololu.com/catalog/product/799 to get 5v out of your AA batteries. Thats assuming the small cars use a small amount of power, the larger regulator is only rated for around 500mA with a 3v input and 5v output.
"Anyone who isn't confused really doesn't understand the situation."
Arduino-based airsoft props -> www.nightscapetech.com
Johannesburg UTC+2
Part of the kids' learning would be to note that eventually the same on-time gives too short a distance and they would chat about that and conclude it's as the battery goes flat.... then that could lead to a whole new chat and experimentation on different types and brands of batteries, looking into how to overcome the battery problem, solar power and blah and blah. They will, off their own bat, I'm pretty sure experiment on up- and down-slopes, different surfaces like pile carpet.
Pretty soon the 2013 equivalent of a 1970's Mopar fan will have the Arduino equivalent of a 426 Keith Black Hemi in there.
This is an awesome piece of learning... kudos to the G&T program.
IT Crowd:
Often times I find people on this site while commenting with the best intentions lose track of the target audience.  How small are the motors you're using?  If they draw less than 50 mA you can drive it directly from the arduino board with no added circuitry.  Otherwise, you can use a battery pack (2 AAAs as you mentioned) to drive the motor and a single transistor ( just about any will do, just make sure it can handle the voltages and currents you will need for the dc motor.  If it was there idea, it's a great place to start and it will work very well.  As people mentioned, the motor will spin slower as the batteries are drained, but that's part of the fun.
Transistors are very easy to explain to even a 5th grader, you simply use the small current from the arduino to turn a switch on and off that allows the motor to run (might not quite be true, but that's the basic idea).  For your own information, just google something like "how do I use a transistor" and look for a tutorial so you can learn about appropriate resistors and voltages.
And I just had A brilliant idea.  You can add a small potentiometer to the circuit after the transistor.  If you start it out with a moderate resistance, the students can use it to change the speed of the motor to fine tune their distance regardless of battery power (up to some limit obviously).  This also prevents you from having to reprogram the arduino every time you want to change the distance.
Good luck with the project, stop back and let us know how it all turns out!
UK
You know that tiny motor that just about manages to make your mobile phone vibrate?
That would almost certainly overload an AVR pin ( the limit is 40mA, not 50mA) - I've measured some over 130mA, though 70 to 100 is more likely.
Now imagine that vibra motor moving any kind of car bigger than a Hot Wheels.
Use a transistor.
Lost Wages
GrisGris (nice sobriquet)
I would be happy to help you. You have mentioned that the students -- at this time -- just need to read and follow instructions. Thus, you don't seem to have the luxury of the hard knocks method. If I am sensing your situation correctly (and I have been wrong in larger towns than this) here are some resources for you.
The car would have a Hall Effect Detector (HED) (such as this one at https://www.sparkfun.com/products/9312?) attached to the body/frame and a magnet placed on one of the wheels. I would suggest a non-drive wheel so that any slippage due to motor torque does not get counted.  If a HED is not available then a reed switch that closes to ground to produce a LOW when the magnet is aligned will do. The HED is much cleaner, more sensitive and reliable.
The DC motor would be connected with a 2n2222 npn transistor (or equivalent -- handling about 200mA max) between the motor and ground.  If your motor draws more than 200mA, then TO-220 NPN transistor (like the TIP31) will need to be used. Be sure to place a reversed diode (cathode toward +DCV) in parallel with the motor to handle any back-EMF when the motor is stopped. A 1N4001 is a defacto standard, methinks. Run a 4.7k ohm resistor from the Arduino pin to the base of the transistor (if you decide to use a lower beta power transistor, you might want to use a 1k resistor to assure saturation), the emitter goes to ground, and the collector goes to the bottom (negative) side of the motor. I would place a 0.1uFd capacitor in parallel with the motor and diode just to keep noise down.
Here is the code
** This code is intended to allow an Ardino Uno to control a model car having a small brushed DC motor
** and drive it forward a given distance and then stop
** It expects a latching Hall Effect sensor (such as the one at https://www.sparkfun.com/products/9312)
** attached to the body and a magnet attached to a non-drive wheel so that, as the wheel rotates, the
** magnet and sensor align once a revolution.
** The motor will draw too much current for the Arduino pin so an NPN transistor (such as a 2N2222)
** is driven through a 4.7k ohm resistor to drive the motor. If the motor draws more than 200mA, use
** a TO-220 power transistor.
** It first waits for the wheel to be turned to align the magnet and the sensor.
** Once it sees alignment, it turns ON the on-board Arduino LED that is attached to digital pin 13
** to notify the user that it is ready to run.
** It then awaits a SPST N.O. momentary switch to be pressed as a signal for the car to go.
** When pressed, it does a quick re-check to make sure the wheel is still in a known position.
** It starts the motor and then counts wheel revolutions until the required distance has been reached.
** It then turns OFF the motor
// pin declarations
// pins chosen to avoid PWM pins to leave them free in case the project is expanded
const int MOTOR_PIN = 7; // pin 7 is an OUTPUT that has an NPN transistor attached which turns ON and OFF the DC motor
const int GO_PIN = 8; // pin 8 is an INPUT looking for a LOW signal to start the car
const int WHEEL_PIN = 12; // pin 12 is an INPUT that has the Hall Effect sensor attached -- LOW = magnet is present
const int READY_PIN = 13; // pin 13 is an OUTPUT that has an LED which signals that the car is ready for a run
                                        // i.e. magnet is aligned with the Hall Effect sensor
// non-pin declarations
const int MAX_WHEEL = 10; // number of wheel rotations to the target area -- 10 is a dummy number that needs to be set after experimentation
const int READY = LOW; // a LOW on the ready pin means that the magnet and hall effect sensor are aligned
const int UNREADY = HIGH; // a HIGH on the ready pin means that the magnet and hall effect sensor are not aligned
// initialize pins
pinMode( GO_PIN, INPUT_PULLUP );
pinMode( WHEEL_PIN, INPUT_PULLUP );
pinMode( MOTOR_PIN, OUTPUT );
pinMode( READY_PIN, OUTPUT );
        // DEBUG
        Serial.println("---== start ==---");
   int loop_flg; // flag to exit do while loop
int i; // for loop index
// turn OFF motor & READY LED
digitalWrite(MOTOR_PIN, LOW);
digitalWrite(READY_PIN, LOW);
        Serial.println("init over -- begin looking for wheel");
// LOOP waiting for ready signal -- wheel turned till magnet aligned with Hall Effect sensor
do
     loop_flg = digitalRead(WHEEL_PIN);
// debounce pin
if( loop_flg == READY )
delay(150); // wait 150mS and check again
} while ( loop_flg == UNREADY );
// turn ON ready LED
digitalWrite( READY_PIN, HIGH );
        Serial.println("Found wheel -- turned ON ready led -- looking for go");
// LOOP waiting for GO signal -- LOW on pin 8
do
     loop_flg = digitalRead(GO_PIN);
// debounce pin
delay(50); // wait 50ms and check again
        Serial.println("found go -- rechecking wheel");
//here: we have been waiting for the GO signal, so re-check that wheel is still ready
                Serial.println("wheel rechecked ok -- turning on motor");
// turn ON the motor
digitalWrite(MOTOR_PIN, HIGH);
                Serial.println("motor on -- starting count");
// FOR LOOP counting wheel rotations
for( i = 0 ; i < MAX_WHEEL ; i++ )
// LOOP waiting for ready signal to go HIGH -- magnet no longer sensed by Hall Effect sensor
do
// debounce pin
if( loop_flg == UNREADY )
} while ( loop_flg == READY );
                        Serial.println("magnet gone");
//here: the Hall Effect no longer sees the magnet
// LOOP waiting for ready signal to go LOW -- magnet now aligned with Hall Effect sensor
do
// debounce pin
//here: the Hall Effect now sees the magnet = a revolution has been completed
                        // so complete interation of for loop
                        Serial.println("magnet present");
                        Serial.print("revolution number ");
                        Serial.println( i + 1 );
//here: the necessary revolutions have been executed
// turn OFF motor
digitalWrite( MOTOR_PIN, LOW );
                Serial.println("motor off");
                Serial.println("---== DONE ==---");
                Serial.println("----- wheel mis-aligned when go was pressed -- redo -----");
I think that it works, but don't have the hardware to fully test. If you need a schematic, I could rustle one up. For the transistor driving a DC motor look here http://www.jeremyblum.com/2011/01/31/arduino-tutorial-5-motors-and-transistors/ for a cool tutorial thanks to Jeremy Blum. There's a video and everything!
Let us know if you need more help, and let us know how it turns out. Photos or videos would be cool.
« Last Edit: February 10, 2013, 08:10:10 pm by MaJiG » Logged
Pages: [1] 2 3   Go Up
