Topic: Arduino vehicle OBD-II data logger (Read 17347 times) previous topic - next topic
stanleyhuang
Feb 08, 2013, 06:50 pm Last Edit: Mar 19, 2013, 05:28 pm by stanleyhuang Reason: 1
I've been making an OBD-II data logger with Arduino, which logs data like vehicle speed, engine RPM etc., to a SD card. With my OBD-II adapter for Arduino, this is not difficult implement. I used a small OLED display module to display status and some realtime data of the vehicle.
Currently it looks like this:
Logged data is rendered with HighCharts like following. Actually I am going to make the rendering a web service so everyone can view the data easily.
I have published my sketch and some more details on here on my website. The source code of this OBD-II data logger uses following Arduino libraries:
  • SD Library (for accessing SD card)
  • Wire Library (for communicating with I2C OLED display module)
  • Arduino OBD-II Library (for accessing vehicle data through OBD-II port)
My Arduino blog: http://arduinodev.com/blog
robtillaart
Did you drive in the same gear ?
it looks like between 11:00 and 11:15 you switched gears, correct?
Rob Tillaart
stanleyhuang
I was driving a VW Scirocco with 7-DSG gearbox, so the gear is changing quite often.
stanleyhuang
barrowrichard7
Hi, I'm just getting started and woud like to know how much engine data is available via OBD-II, I tried following the link to your website  but no luck
Regards Richard
Chagrin
Regards Richard
Pretty much all of it. The biggest dependency is your vehicle and whether or not it reports a specific piece of data, but you can assume all the basics (RPM, MPH, temp, etc.) will be available, and of course any time your "check engine" light comes on there's an OBD code associated with that as well.
