Topic: Led on Led send (Read 3486 times) previous topic - next topic
Tricky12
Hi
I have this dryer that I attach A Piezo sensor,  Op Amp and some resistor.  From the OP Amp to pin 2 of the analog in on my arduino.  So when the dryer is on and running,  the Serial.printIn Reads tap.
What I need help is with this =  When I turn on the Arduino,  I want (led1) to turn on for 2 sec. then go off.  Than that
same (Led1)  to blink when dryer is on and running,  if dryer is off, no blink.  (Led2) I want to read the dryer state,  from
minute to minute.  If the dryer in the minute is running the (Led2) will be off.  If the dryer is off in that minute to minute,
then I want the (Led2) to blink of one sec.  and then go off.
Here is the code.  Its not working all right
int sensor = 2; // Analog in
int val =0; // Current reading for analog pin
int avg; // Running average of the wave amplitude
int MIDPOINT = 520; // Base reading
const int led1 =  13;
const int led2 =  8;
avg = MIDPOINT; // set average at midpoint
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
val = analogRead(sensor);
if (val > MIDPOINT) {
val = val - MIDPOINT;
val = MIDPOINT - val;
avg = (avg * 0.5) + (val * 0.5);
if (avg > 70) {
// vibration detected!
Serial.println("TAP");
digitalWrite(led1, HIGH);
digitalWrite(led1, Low);
delay(100); //
PaulS
What is up with MIDPOINT and manipulating val? What is up with the averaging code?
The code code does something. You have not described that.
You want it to do something more. You haven't described what it doesn't do.
The delay() is going to kill you. Read, understand, and embrace the code in Blink Without Delay.
Tricky12
I am trying to use the  Piezo sensor to read the vibration of the dryer being on and running.
I want led1 to tell you that the piezo sensor is working and I want led2 to send A 0 or 1 telling you the dryer is off, after it's
full cycle of running.
here is new code that led1 works good.
int led1 = 13;
int led2 = 8;
// Compute wave amplittue
if (avg > 70) {
delay(1);
digitalWrite(led1, LOW);
delay(100);
Tricky12
#3
Feb 09, 2013, 07:33 pm Last Edit: Feb 09, 2013, 07:40 pm by Tricky12 Reason: 1
I have A  Piezo sensor,  Op Amp and some resistor and going to pin 2, to the Arduino.
Here is what I am shooting for = http://diy.viktak.com/2012/07/washing...
Op Amp setup
http://www.instructables.com/files/deriv/FAH/K0W2/FOHTR2JS/FAHK0W2FOHTR2JS.MEDIUM.jpg
UKHeliBob
Your link does not work but this one does http://diy.viktak.com/2012/07/washing-machine-monitor.html
Tricky12
Is there A way in my code that I can read the input of the (avg),  and put (if (avg < 22)  digitalWrite(led2, HIGH);
const int led2 =  8;
if (avg > 70) {
delay(100); //
PaulS
Yes.
What is the purpose of Serial.begin() in setup() if you have no Serial.print() statements anywhere in the code? More importantly, why don't you have them?
Tricky12
How do I read the avg as numbers on the Serial.println.
PaulS
I have no clue what you are talking about. The Serial.println() statements prints values, like avg, as simple text. If you can't read that, I can't help you.
Unless you post code, I can't help you.
Tricky12
This is all I want from you people.  Piezo sensor, Op Amp and some resistor and going to (analog in) pin 2, to the Arduino.   Take pin2 input and make it running this program,  but when the Piezo sensor is not moving then have one led light up and then turn off.  That is what I want, that I don't know how to program.  If you can help give me good input,  not make fun of me,  you are here to help,  I think.....
if (avg > 70) {
delay(100); //
PaulS
Why don't you start simple, then, and learn to program.
You have not yet explained what this shifting and averaging stuff is about. Either the sensor senses vibration, or it does not.
Delete all that stuff, and just Serial.print() a prefix and the value read from the sensor. Does that number make any sense? Until you KNOW what the sensor is reporting, you can't begin to make use of the value.
UKHeliBob
As Paul suggests, keep it simple to begin with.  Try this
  pinMode(sensor, INPUT);
  Serial.println(val);
  delay(100);
It is basically your program with the stuff that is irrelevant at the moment taken out and a pinMode() command for the sensor, which was missing, added in.  What sort of output do you get under different conditions ?
PaulS
What use is a function that affects digital pins only, to an input-only analog pin? The pinMode() statement was correctly omitted from OP's code.
UKHeliBob
Whoops.
Mea culpa.
Apologies all round, but I will be interested to see the output.
Tricky12
To  UKHeliBob
When I use the simple program.  In the ( Serial.println(val);)  the val comes up as 264.   When I tap on the  Piezo sensor
the val 873.  So how do I get A constant # for the val?  So I can make the led turn on or off.
