Topic: Can I Bypass a proprietary DC Adapter Tip? (Read 939 times) previous topic - next topic
jpro
I have a project I am working on that uses an old portable CD player. I want the device to run off wall power but the port for the DC Adapter must need a proprietary tip to fit in the hole. I have tried the multi-tip DC adapters with the adjustable voltage but non of the tips fit. The player I have torn apart calls for 4.5v DC In. Can I work around the weird fitting for the tip?
JimboZA
Well seeing as you've already ripped it open, why not cut the weird one off and solder on one of these?
MarkT
Well it might take a bit of soldering to add a new power lead - bring it out through the hole where the
old power socket was and use an inline DC power socket (one of the more common sizes like 2.1mm
would be a good choice).
Be sure to note the polarity and that the adapter is really generating 4.5V with enough current.
[ I won't respond to messages, use the forum please ]
Quick5pnt0
If it has a regular round plug then I seriously doubt it is a proprietary size, more than likely your adapter just doesn't have the right size. With that said, if you open it up you can easily solder right to the same terminals the plug is soldered to. You can also install your own plug.
jpro
It is a round plug. It is a Sony brand CD player. I looked on eBay for used Sony adapters. Some say 500mA and some say 400mA. Most of the listings say the tip is positive. I guess I could buy another multi-tip adapter and hope I find a tip that fits. The one I had before was either too loose or wouldn't fit over the center pin.
jpro
One other question. I do have a PSP power adapter and the tip fits in the CD player. However the PSP adapter says it outputs 5v. Is the difference between 4.5v and 5v enough to do serious damage to the player if I plug the PSP adapter in briefly to see if it will at least power on?
Thanks for the help thus far
JimboZA
Have you looked on the player to see if there's a sticker giving the power requirements?
jpro
There is a sticker on the bottom that says DC 4.5v External DC Supply, Battery Supply 1.5vx2 R6 Size AA or Equivalent
zoomkat
Radio Shack has dc power plugs, including the size that fits the arduino external power jack.
http://www.radioshack.com/search/index.jsp?kwCatId=13384949&kw=dc%20power%20plug&origkw=DC+Power+Plug&sr=1
Google forum search: Use Google Advanced Search and use Http://forum.arduino.cc/index in the "site or domain:" box.
JimboZA
Hmmmm, back when I was at school, 1.5 x 2 was 3....  8) .... assume that's a typo.
.... usually those stickers show the external supply polarity
wizdum
I ran into this on an Energizer external battery pack. The plug ended up having a 4.7mm outer diameter (and 2.1mm inner diameter) instead of the typical 5.0mm. You might want to get a caliper out and see if you can measure it. Small parts suppliers could probably get you one.
Or just do what I did and solder wires to it instead.
"Anyone who isn't confused really doesn't understand the situation."
Electronic props for Airsoft, paintball, and laser tag -> www.nightscapetech.com
Riva
You would need a bit of overhead if the power tip is feeding a voltage regulator.
I might seem like an idiot but remember it takes one to know one.
Forum user generally fall into three categories (the good, the bad & the a**hole) what category do you fit in?
JimboZA
Good point, and I should know that, since that's exactly why we have to supply upwards of 7v to a 5v Arduino through its barrel...
