Topic: Software Serial library + example compile errors (Read 1 time) previous topic - next topic
I just tried IDE 1.0.3 and then 1.5.2.  In both cases if I open "SoftwareSerialExample" and run Sketch->Verify/Compile, I get errors.  I'm not able to use SoftwareSerial anymore at this point. I don't have clue what these errors mean.
In file included from SoftwareSerialExample.ino:28:
C:\Users\Doug\Documents\Arduino\libraries\SoftSerial/SoftwareSerial.h:95: error: conflicting return type specified for 'virtual void SoftwareSerial::write(uint8_t)'
C:\arduino-1.5.2\hardware\arduino\avr\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
This is the example code (nothing has been changed. Exactly as it is from a fresh zip file):
Code: [Select]
  Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 10 (connect to TX of other device)
* TX is digital pin 11 (connect to RX of other device)
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
  if (Serial.available())
Looks like you have a third-party SoftwareSerial library installed in C:\Users\Doug\Documents\Arduino\libraries\SoftSerial
Get rid of it.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Confirm your email address
Thank you for subscribing!
via Egeo 16
Torino, 10131
