Topic: About Metaboard (Read 861 times) previous topic - next topic
auro
Feb 09, 2013, 06:43 am Last Edit: Feb 09, 2013, 06:48 am by auro Reason: 1
i have recently made a metaboard. the hardware is OK. i m using ATmega8 with 16MHz crystal. i have downloaded the bootloader but dont know how to upload it in ATmega8. Please help me!!! :(
Thank you!!!
johnwasser
http://arduino.cc/en/Hacking/Bootloader?from=Main.Bootloader
"Burning the Bootloader
To burn the bootloader, you'll need to buy an AVR-ISP (in-system programmer), USBtinyISP or build a ParallelProgrammer. The programmer should be connected to the ICSP pins (the 2 by 3 pin header) - make sure you plug it in the right way. The board must be powered by an external power supply or the USB port.
Make sure you have the right item selected in the Tools | Board menu. Then, just launch the appropriate command from the Tools > Burn Bootloader menu of the Arduino environment. Burning the bootloader may take 15 seconds or more, so be patient.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
auro
Thank You very much sir!!! i already have a AVR serial programmer and a usbasp programmer. But my problem is i have downloaded the firmware from http://www.obdev.at/downloads/vusb/USBaspLoader.2012-12-08.zip as it is mentioned in the metaboard's website. after downloading the zip file don't know how to compile and upload the hex file into the controller.
Please help me!!!
thank you again!!!
johnwasser
If you are installing firmware into your USBasp you need another ISP device:
http://www.fischl.de/usbasp/Readme.txt
auro
thanks, can you tell me how to use avrdude and winavr?
johnwasser
No.  I have not used a Windows machine for years.
auro
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
