Loading...
Pages: [1]   Go Down
Author Topic: LCD Touch Display calibration problem  (Read 546 times)
Trento
Offline Offline
Newbie
View Profile
hi guys, i've got a problem: i'm using an Iteaduino MEGA + LCD Touch Display from Itead Studio (ITDB02-5.0) + UTouch Library (UTFT too).
I've run the calibration sketch and replaced the strings in the UTouchCD.h file. When I upload the ButtonTest sketch the Iteaduino doesn't recognize the place where I touch, but recognizes that I actually touch the screen, I think this isn't an hardware problem. So I hope you can help me.
Cheers from Italy  smiley-mr-green
Logged
Trento
Offline Offline
Newbie
View Profile
Come on guys, we need your help! smiley-eek-blue
Logged
0
Offline Offline
Sr. Member
what?
View Profile
Posting your code would help, in particular have you set the screen orientation?
The calibration program i think needs to be in PORTRAIT but might be different depending on which library your using
Code:
  myGLCD.InitLCD(PORTRAIT);
  myTouch.InitTouch(PORTRAIT);
Logged
Trento
Offline Offline
Newbie
View Profile
Thx for reply man, this is the code I'm using:
// UTouch_ButtonTest (C)2010-2012 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a quick demo of how create and use buttons.
// This program requires the UTFT library.
// It is assumed that the display module is connected to an
// appropriate shield or that you know how to change the pin
// numbers in the setup.
#include <UTFT.h>
#include <UTouch.h>
// Declare which fonts we will be using
extern uint8_t BigFont[];
// Uncomment the next two lines for the Arduino Mega
UTFT myGLCD(SSD1963_800,10,11,12,13);
UTouch myTouch(4,5,6,7,8);
int x, y;
char stCurrent[20]="";
int stCurrentLen=0;
char stLast[20]="";
**   Custom functions   **
void drawButtons()
// Draw the upper row of buttons
  for (x=0; x<5; x++)
    myGLCD.setColor(0, 0, 255);
    myGLCD.fillRoundRect (10+(x*60), 10, 60+(x*60), 60);
    myGLCD.setColor(255, 255, 255);
    myGLCD.drawRoundRect (10+(x*60), 10, 60+(x*60), 60);
    myGLCD.printNumI(x+1, 27+(x*60), 27);
// Draw the center row of buttons
  for (x=0; x<5; x++)
    myGLCD.fillRoundRect (10+(x*60), 70, 60+(x*60), 120);
    myGLCD.drawRoundRect (10+(x*60), 70, 60+(x*60), 120);
    if (x<4)
      myGLCD.printNumI(x+6, 27+(x*60), 87);
  myGLCD.print("0", 267, 87);
// Draw the lower row of buttons
  myGLCD.fillRoundRect (10, 130, 150, 180);
  myGLCD.drawRoundRect (10, 130, 150, 180);
  myGLCD.print("Clear", 40, 147);
  myGLCD.fillRoundRect (160, 130, 300, 180);
  myGLCD.drawRoundRect (160, 130, 300, 180);
  myGLCD.print("Enter", 190, 147);
  myGLCD.setBackColor (0, 0, 0);
void updateStr(int val)
  if (stCurrentLen<20)
    stCurrent[stCurrentLen]=val;
    stCurrent[stCurrentLen+1]='\0';
    stCurrentLen++;
    myGLCD.setColor(0, 255, 0);
    myGLCD.print(stCurrent, LEFT, 224);
    myGLCD.setColor(255, 0, 0);
    myGLCD.print("BUFFER FULL!", CENTER, 192);
    myGLCD.print("            ", CENTER, 192);
// Draw a red frame while a button is touched
void waitForIt(int x1, int y1, int x2, int y2)
  myGLCD.drawRoundRect (x1, y1, x2, y2);
  while (myTouch.dataAvailable())
    myTouch.read();
**  Required functions  **
// Initial setup
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  myGLCD.setFont(BigFont);
  myGLCD.setBackColor(0, 0, 255);
  drawButtons();
  while (true)
    if (myTouch.dataAvailable())
      myTouch.read();
      x=myTouch.getX();
      y=myTouch.getY();
      if ((y>=10) && (y<=60))  // Upper row
        if ((x>=10) && (x<=60))  // Button: 1
          waitForIt(10, 10, 60, 60);
          updateStr('1');
        if ((x>=70) && (x<=120))  // Button: 2
          waitForIt(70, 10, 120, 60);
          updateStr('2');
        if ((x>=130) && (x<=180))  // Button: 3
          waitForIt(130, 10, 180, 60);
          updateStr('3');
        if ((x>=190) && (x<=240))  // Button: 4
          waitForIt(190, 10, 240, 60);
          updateStr('4');
        if ((x>=250) && (x<=300))  // Button: 5
          waitForIt(250, 10, 300, 60);
          updateStr('5');
      if ((y>=70) && (y<=120))  // Center row
        if ((x>=10) && (x<=60))  // Button: 6
          waitForIt(10, 70, 60, 120);
          updateStr('6');
        if ((x>=70) && (x<=120))  // Button: 7
          waitForIt(70, 70, 120, 120);
          updateStr('7');
        if ((x>=130) && (x<=180))  // Button: 8
          waitForIt(130, 70, 180, 120);
          updateStr('8');
        if ((x>=190) && (x<=240))  // Button: 9
          waitForIt(190, 70, 240, 120);
          updateStr('9');
        if ((x>=250) && (x<=300))  // Button: 0
          waitForIt(250, 70, 300, 120);
          updateStr('0');
      if ((y>=130) && (y<=180))  // Upper row
        if ((x>=10) && (x<=150))  // Button: Clear
          waitForIt(10, 130, 150, 180);
          stCurrent[0]='\0';
          stCurrentLen=0;
          myGLCD.setColor(0, 0, 0);
          myGLCD.fillRect(0, 224, 319, 239);
        if ((x>=160) && (x<=300))  // Button: Enter
          waitForIt(160, 130, 300, 180);
          if (stCurrentLen>0)
            for (x=0; x<stCurrentLen+1; x++)
              stLast
  • =stCurrent
            stCurrent[0]='\0';
            stCurrentLen=0;
            myGLCD.fillRect(0, 208, 319, 239);
            myGLCD.print(stLast, LEFT, 208);
            myGLCD.print("BUFFER EMPTY", CENTER, 192);
Logged
Trento
Offline Offline
Newbie
View Profile
...and this is the code for calibration:
// UTouch_Calibration (C)2012 Henning Karlsen
// This program can be used to calibrate the touchscreen
// of the display modules.
// This program requires the UTFT library and a touch
// screen module that is compatible with UTFT.
// Instructions will be given on the display.
#include <UTFT.h>
#include <UTouch.h>
// Define the orientation of the touch screen. Further
// information can be found in the instructions.
#define TOUCH_ORIENTATION  LANDSCAPE
extern uint8_t SmallFont[];
// DO NOT EDIT ANYTHING BELOW THIS LINE
uint32_t cx, cy;
uint32_t rx[10], ry[10];
uint32_t clx, crx, cty, cby;
float px, py;
int dispx, dispy, text_y_center;
uint32_t calx, caly, cals;
char buf[13];
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(SmallFont);
  myTouch.InitTouch(TOUCH_ORIENTATION);
  myTouch.setPrecision(PREC_LOW);
  dispx=myGLCD.getDisplayXSize();
  dispy=myGLCD.getDisplayYSize();
  text_y_center=(dispy/2)-6;
void drawCrossHair(int x, int y)
  myGLCD.drawRect(x-10, y-10, x+10, y+10);
  myGLCD.drawLine(x-5, y, x+5, y);
  myGLCD.drawLine(x, y-5, x, y+5);
void readCoordinates()
  int iter = 2000;
  int cnt = 0;
  uint32_t tx=0;
  uint32_t ty=0;
  boolean OK = false;
  while (OK == false)
    myGLCD.print("*  PRESS  *", CENTER, text_y_center);
    while (myTouch.dataAvailable() == false) {}
    myGLCD.print("*  HOLD!  *", CENTER, text_y_center);
    while ((myTouch.dataAvailable() == true) && (cnt<iter))
      myTouch.read();
      tx += myTouch.TP_X;
      ty += myTouch.TP_Y;
      cnt++;
    if (cnt>=iter)
      OK = true;
      tx = 0;
      ty = 0;
      cnt = 0;
  cx = tx / iter;
  cy = ty / iter;
void calibrate(int x, int y, int i)
  drawCrossHair(x,y);
  myGLCD.setBackColor(255, 0, 0);
  readCoordinates();
  myGLCD.print("* RELEASE *", CENTER, text_y_center);
  myGLCD.setColor(80, 80, 80);
  drawCrossHair(x,y);
  rx=cx;
  ry=cy;
  while (myTouch.dataAvailable() == true)
    myTouch.read();
void waitForTouch()
    myTouch.read();
    myTouch.read();
void toHex(uint32_t num)
  buf[0] = '0';
  buf[1] = 'x';
  buf[10] = 'U';
  buf[11] = 'L';
  buf[12] = 0;
  for (int zz=9; zz>1; zz--)
    if ((num & 0xF) > 9)
      buf[zz] = (num & 0xF) + 55;
      buf[zz] = (num & 0xF) + 48;
    num=num>>4;
void startup()
  myGLCD.fillRect(0, 0, dispx-1, 13);
  myGLCD.drawLine(0, 14, dispx-1, 14);
  myGLCD.print("UTouch Calibration", CENTER, 1);
  myGLCD.setBackColor(0, 0, 0);
  if (dispx==220)
    myGLCD.print("Use a stylus or something", LEFT, 30);
    myGLCD.print("similar to touch as close", LEFT, 42);
    myGLCD.print("to the center of the", LEFT, 54);
    myGLCD.print("highlighted crosshair as", LEFT, 66);
    myGLCD.print("possible. Keep as still as", LEFT, 78);
    myGLCD.print("possible and keep holding", LEFT, 90);
    myGLCD.print("until the highlight is", LEFT, 102);
    myGLCD.print("removed. Repeat for all", LEFT, 114);
    myGLCD.print("crosshairs in sequence.", LEFT, 126);
    myGLCD.print("Touch screen to continue", CENTER, 162);
    myGLCD.print("INSTRUCTIONS", CENTER, 30);
    myGLCD.print("Use a stylus or something similar to", LEFT, 50);
    myGLCD.print("touch as close to the center of the", LEFT, 62);
    myGLCD.print("highlighted crosshair as possible. Keep", LEFT, 74);
    myGLCD.print("as still as possible and keep holding", LEFT, 86);
    myGLCD.print("until the highlight is removed. Repeat", LEFT, 98);
    myGLCD.print("for all crosshairs in sequence.", LEFT, 110);
    myGLCD.print("Further instructions will be displayed", LEFT, 134);
    myGLCD.print("when the calibration is complete.", LEFT, 146);
    myGLCD.print("Do NOT use your finger as a calibration", LEFT, 170);
    myGLCD.print("stylus or the result WILL BE imprecise.", LEFT, 182);
    myGLCD.print("Touch screen to continue", CENTER, 226);
  waitForTouch();
  myGLCD.clrScr();
void done()
  myGLCD.clrScr();
  if (dispx==220)
    myGLCD.print("To use the new calibration", LEFT, 30);
    myGLCD.print("settings you must edit the", LEFT, 42);
    myGLCD.setColor(160, 160, 255);
    myGLCD.print("UTouchCD.h", LEFT, 54);
    myGLCD.print("file and change", 88, 54);
    myGLCD.print("the following values. The", LEFT, 66);
    myGLCD.print("values are located right", LEFT, 78);
    myGLCD.print("below the opening comment.", LEFT, 90);
    myGLCD.print("CAL_X", LEFT, 110);
    myGLCD.print("CAL_Y", LEFT, 122);
    myGLCD.print("CAL_S", LEFT, 134);
    toHex(calx);
    myGLCD.print(buf, 75, 110);
    toHex(caly);
    myGLCD.print(buf, 75, 122);
    toHex(cals);
    myGLCD.print(buf, 75, 134);
    myGLCD.print("CALIBRATION COMPLETE", CENTER, 30);
    myGLCD.print("To use the new calibration", LEFT, 50);
    myGLCD.print("settings you must edit the", LEFT, 62);
    myGLCD.print("UTouchCD.h", LEFT, 74);
    myGLCD.print("file and change", 88, 74);
    myGLCD.print("the following values.", LEFT, 86);
    myGLCD.print("The values are located right", LEFT, 98);
    myGLCD.print("below the opening comment in", LEFT, 110);
    myGLCD.print("the file.", LEFT, 122);
    myGLCD.print("CAL_X", LEFT, 150);
    myGLCD.print("CAL_Y", LEFT, 162);
    myGLCD.print("CAL_S", LEFT, 174);
    toHex(calx);
    myGLCD.print(buf, 75, 150);
    toHex(caly);
    myGLCD.print(buf, 75, 162);
    toHex(cals);
    myGLCD.print(buf, 75, 174);
  startup();
  drawCrossHair(dispx-11, 10);
  drawCrossHair(dispx/2, 10);
  drawCrossHair(10, 10);
  drawCrossHair(dispx-11, dispy/2);
  drawCrossHair(10, dispy/2);
  drawCrossHair(dispx-11, dispy-11);
  drawCrossHair(dispx/2, dispy-11);
  drawCrossHair(10, dispy-11);
  myGLCD.print("***********", CENTER, text_y_center-12);
  myGLCD.print("***********", CENTER, text_y_center+12);
  calibrate(10, 10, 0);
  calibrate(10, dispy/2, 1);
  calibrate(10, dispy-11, 2);
  calibrate(dispx/2, 10, 3);
  calibrate(dispx/2, dispy-11, 4);
  calibrate(dispx-11, 10, 5);
  calibrate(dispx-11, dispy/2, 6);
  calibrate(dispx-11, dispy-11, 7);
  if (TOUCH_ORIENTATION == LANDSCAPE)
    cals=(long(dispx-1)<<12)+(dispy-1);
    cals=(long(dispy-1)<<12)+(dispx-1);
  if (TOUCH_ORIENTATION == PORTRAIT)
    px = abs(((float(rx[2]+rx[4]+rx[7])/3)-(float(rx[0]+rx[3]+rx[5])/3))/(dispy-20));  // PORTRAIT
    px = abs(((float(rx[5]+rx[6]+rx[7])/3)-(float(rx[0]+rx[1]+rx[2])/3))/(dispy-20));  // LANDSCAPE
    clx = (((rx[0]+rx[3]+rx[5])/3));  // PORTRAIT
    crx = (((rx[2]+rx[4]+rx[7])/3));  // PORTRAIT
    clx = (((rx[0]+rx[1]+rx[2])/3));  // LANDSCAPE
    crx = (((rx[5]+rx[6]+rx[7])/3));  // LANDSCAPE
  if (clx<crx)
    clx = clx - (px*10);
    crx = crx + (px*10);
    clx = clx + (px*10);
    crx = crx - (px*10);
    py = abs(((float(ry[5]+ry[6]+ry[7])/3)-(float(ry[0]+ry[1]+ry[2])/3))/(dispx-20));  // PORTRAIT
    py = abs(((float(ry[0]+ry[3]+ry[5])/3)-(float(ry[2]+ry[4]+ry[7])/3))/(dispx-20));  // LANDSCAPE
    cty = (((ry[5]+ry[6]+ry[7])/3));  // PORTRAIT
    cby = (((ry[0]+ry[1]+ry[2])/3));  // PORTRAIT
    cty = (((ry[0]+ry[3]+ry[5])/3));  // LANDSCAPE
    cby = (((ry[2]+ry[4]+ry[7])/3));  // LANDSCAPE
  if (cty<cby)
    cty = cty - (py*10);
    cby = cby + (py*10);
    cty = cty + (py*10);
    cby = cby - (py*10);
  calx = (long(clx)<<14) + long(crx);
  caly = (long(cty)<<14) + long(cby);
    cals = cals + (1L<<31);
  done();
  while(true) {}
Logged
UK
Offline Offline
Sr. Member
View Profile
I'm having the same problem as this but I outputted the x y coordinates via serial.  It appears that every screen touch is recognised but the device thinks that it is always at the same point...
Were the first two calibration strings the same?
I am looking at the possibility that the connections are wrong on the CTE shield in relation to my 32 pin TFT.
Logged
Pages: [1]   Go Up
Print
Jump to:
