Loading...
Pages: [1]   Go Down
Author Topic: SumoBot help  (Read 127 times)
Offline Offline
Newbie
View Profile
I am using a ping with an official arduino motor sheild. I have a sparkfun magicians chassis. I am new to programing with arduino in the regular IDE. Could someone write a program incuding these items. Everytime I try a program I get errors on everything. I am only good with using digital outputs not inputs. Help would be much appreciated.  smileyThanks  smiley-lol
Logged
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
Post an example of your code and the errors so that we can see what is wrong.
Logged
Offline Offline
Jr. Member
View Profile
I have no clue because you did not post code.   However if you want to get the Ping sensor to work there is an example code that comes along with the IDE for that.
In the Arduino IDE menu click File -> Examples -> 06.Sensors -> Ping.
This code assumes your Ping sensor is hooked up to digital pin 7.  If it isn't then scroll to the line that says:  const int pingPin = 7;
Change the 7 to be the digital pin you connect the Ping sensor to.
As for the code for the Arduino Motor controller look at this tutorial:  http://www.instructables.com/id/Arduino-Motor-Shield-Tutorial/?ALLSTEPS
Logged
Offline Offline
Newbie
View Profile
Nevermind I found a code that will work but thanks for the help
Logged
Pages: [1]   Go Up
Print
Jump to:
