Topic: Arduino Controlled 12 Volt Ground Supply for RC Drone Ground Station (Read 679 times) previous topic - next topic
AlanGP
I am looking for a safe way to interface a high current low voltage relay to an Arduino. I had in mind a large FET but what type? I am uncertain whether or not to include an opto isolator.
I have various low voltage and high current alarms in the sketch which will drive the digital output when the output should switched on or off but the final piece of the circuit is evading me.
Any Ideas gratefully received. I would upload the sketch and circuit to share but I don't know how.
Alan
PeterH
The diagram suggests you're only switching a relay - how much is a 'large current'?
AlanGP
If I just switch the relay - a few hundred milliamperes. However, a more elegant idea would be to solid state switch the entire load of up to 30 amps. The problem is the same, I am not sure how to achieve it without frying something.
Alan
retrolefty
There are small inexpensive automotive relays designed for that kind of current.
http://www.allelectronics.com/make-a-store/item/RLY-351/12VDC-SPDT-40A-AUTOMOTIVE-RELAY/1.html
Lefty
AlanGP
@Lefty - Thanks, but the problem is how to switch them from an arduino
